    Looking for a ready to use printbed
    22
    2.6k
    • percarundefined
      percar
      I have been using PVA Glue (white carpenters glue) Water Mixture and have had no problems. I have a large build plate 300mm x 600mm and prior to using PVA had many problems with the part lifting off the build plate. I now can print large items with no problems....I do have a heated plate. The PVA is also easy to repair. I use 25% PVA the rest water
      • jmjcokeundefined
        jmjcoke @deckingman
        @deckingman Yep! 3DLac ended my seemingly endless search for adhesion.
        Joshua Coke
        Trick Laser Metal Max with Smart Effector
        Duet Wifi
        Zesty Nimble
        Mosaic Pallette+
        At work
        Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
          deckingman @jmjcoke
          @jmjcoke said in Looking for a ready to use printbed:
          Me too. I'd prefer to use nothing at all but a quick squirt of 3DLac just works every time, with every filament. Oh, I forgot to add this little video clip to my first post https://www.youtube.com/watch?v=vG1WqijJ634&t=44s. A 300 mm long tool rack printed on it's end, so very little contact area with the bed.
            A Former User @deckingman
            @deckingman said in Looking for a ready to use printbed:
            only issue with 3dlac is that unless you are in the UK or mainland EU no-one will ship it by air as its an aerosol it is considered dangerous goods in our H&S gone mad world, and trying to get even a box of 12 shipped by sea freight makes it uneconomical...
            deckingmanundefined jmjcokeundefined 2 Replies Last reply Reply Quote 0
              deckingman @A Former User
              @calvinx
              Yes that's a bu**er. I just checked the tin and it has stickers to say that it's highly inflammable (as well as being an aerosol). At the TCT show, RepRap World were giving away 100ml sample bottles of 3D Lac that were in a sort of pump action spray. Never seen them advertised for sale anywhere though.
              • peter247undefined
                peter247
                I'm using 3dlac , but found now I`m using a heated bed and glass the problem is not getting it to stick , but getting it off the bed without breaking it.
                So using bare glass and using 3dlac for the part which left.
                Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                • fmaundefined
                  fma
                  Strange, I always use 3DLac (a lot, I hate when it doesn't stick) on heated glass bed, and I don't have any problem to remove parts. I just remove the glass, put it on the floor for a quick cool down, and the part unstick by itself.
                  Before you ask, the mirror is a cheap one, and it never broke, even during winter when I put it in the garage (2-3°C).
                  Frédéric
                    deckingman
                    Yes likewise. I have 3 sheets of glass that I swap between so when one print is finished, I just swap out the glass , give it a quick squirt, and start another print. When the first piece has cooled, the part simply falls off, or at worst, require a slight tap. In fact with large parts, I sometimes hear an audible "crack" as the part contracts and then falls off of it's own accord.
                    • fmaundefined
                      fma
                      I have the exact same process ;o)
                      Frédéric
                      • jmjcokeundefined
                        jmjcoke @A Former User
                        @calvinx not now, https://designbox3d.com/products/3dlac-3d-printer-bed-adhesive.
                        Joshua Coke
                        Duet Wifi
                        Zesty Nimble
                        Mosaic Pallette+
                        At work
                        • Mikeundefined
                          Mike
                          @bartolomeus You have to try quite hard to scratch the coating off - I've never damaged it during 2 years of regular use. The one dent I've made was on a delta when I messed up my probe.
                          As for flatness... The same as with all the other tooling plate - within 0.1 mm on my 300x200 bed at least. I suspect it'll stay the same with larger plates.
                          bartolomeusundefined 1 Reply Last reply Reply Quote 0
                          • bartolomeusundefined
                            bartolomeus @Mike
                            @mike said in Looking for a ready to use printbed:
                            Thanks Mike, thats good info, I like the aio solution of a PEI coated plate and no clips to keep the print surface in place.
                            Mikeundefined 1 Reply Last reply Reply Quote 0
                            • Mikeundefined
                              Mike @bartolomeus
                              @bartolomeus Yeah, the lack of any maintenance needed apart from the occasional wipe is what sold it for me. But ideally I'd prefer something like the Prusa MK3 solution - a permanent PEI coating on a detachable surface. This way it's not that big of a problem if you do scratch or mess it up and it lowers the downtime between prints a great deal. All while enjoying the maintenance-free 3D print adhesion wonder that is PEI.
