    Better safe than sorry: mains voltage AC controlled bed
    22
    3.2k
    • jackatom74undefined
      jackatom74
      I have a decent grasp on electricity, most of my expirience is at higher voltages, but something I incorporated into my bed beyond what you have already done is a thermal cut out fuse. It should be sized amp wise to not blow before you other protection engages, but the temperature it opens at should be dependant on where it is installed. Mine is on us voltage 5A or 100C is the one I am using and it is soldered in line and covered by heat shrink, right after my SSR, on the way to my 500w bed. It sits 1 " below my bed. If the SSR fails closed, and nothing else stops it that fuse will heat and open.
      This is the same thing that protects rice cookers and other like devices. They can be found by sourcing parts to repair that type of item.
      Disclaimer: just sharing how I did it, using a fuse like this is totally dependant on the location it is installed in, a different temp or size may needed on a different machine or setup
      bartolomeusundefined 1 Reply Last reply Reply Quote 0
      • bartolomeusundefined
        bartolomeus @jackatom74
        @jackatom74 So far I have only found 10a thermal fuses with a wide selection of choices in max temperatures. Voltage here is 230v.
        @dc42 This is my RCD:
        denkeundefined 1 Reply Last reply Reply Quote 0
        • Dougal1957undefined
          Dougal1957
          that is a 30mA Trip RCD so should be fine
          • Mikeundefined
            Mike
            My take on the bed safety relies on ordering your silicone heater from Keenovo. With them you can usually specify that you want an bimetallic thermal switch built in, which basically acts as a resettable fuse. I ended up asking for a 155 (triggers at 155/resets at 135) degree fuse for one heater and 165 for the other. And they ended up adding them for free.
            If it's too late for that, I'd recommend using a bimetallic switch as opposed to a thermal fuse. Those fuses are a pain to solder without triggering and you'd have to rip it off if it's triggered. I personally have attached them to the bed heater with some RTV silicone cement, as opposed to fixing a fuse to the bed - that ensures that the failsafe triggers even if the heater somehow manages to fall off the bed.
            And my last note... You're running it off 220V, there's no reason to use a 40A SSR. I'd rather go for a 20-25A version, but from a reputable brand and from a seller that offers genuine parts. Those knockoff SSRs are always a surprise - you may get a decent one, or a complete dog that isn't even filled with epoxy. It's the most likely and the scariest point of failure in the whole system, I'd really recommend spending like 20-30 money units on a decent SSR.
            Oh, and the very last point - make sure that everything is grounded.
            • denkeundefined
              denke @bartolomeus
              @bartolomeus
              This device should suffice, just don't forget to test them from time to time.
              I have come across a few which went bad for no apparent reason (and I did not take the time to pry them open and ivestigate ... looking back I should have).
              If you push the test button it's supposed to trip to off position. If it does not do that, then they need to be replaced.
                bartolomeus @Mike
                @mike Do you attach the bimetallic switch straight to the bed?
                @denke Thanks! I'll open it up when I get it. I did see some comparable ones that did show epoxy filling in the ad
                Mikeundefined 1 Reply Last reply Reply Quote 0
                • Mikeundefined
                  Mike @bartolomeus
                  @bartolomeus Not to the bed, to the silicone heater - I've bought a tube of high-temp RTV silicone and literally moulded the fuse in. The RTV silicone is very chemically similar to the heater, which makes for a very reliable contact.
                  • DocTruckerundefined
                    DocTrucker
                    If your framework is aluminium I'd consider sanding back the ground points to shiney metal and assemble the contacts onto the frame with dielectric grease to delay oxidation of the alloy as long as possible. May need to play attention to the temperature limits of the grease and may wish to print some earth point shields to save your clothing!
                    Consider tying the stepper bodies to the ground points to, particularly if on printed motor mounts.
                    It's on my todo list. I'm only on 24V heater so not urgent.
                      bartolomeus
                      Lots of good info. Thanks.
                      @Mike I just sent a message to keenovo for a custom pad, 300x300mm 600W@220v with an integrated bimetallic switch.
                      • fmaundefined
                        fma @peter247
                        @peter247 said in Better safe than sorry: mains voltage AC controlled bed:
                        I would say to be safe fit a 5 amp fuse for all the printer AND ALWAYS switch or fuse the live side.
                        I would put one on each side, as you can't be sure where is the live side. It depends where you plug it, and even if your house is well wired, a simple splitter can reverse neutral and live.
                        Frédéric
                        • peter247undefined
                          peter247
                          I guess it boils down to , fit the correct rated fuse , check that you have good earth continuity , it is recommended to fit a earth leakage trip and try not to use cable extensions until they have been tested for earth / correct wiring .
                          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                            bartolomeus
                            Is it ok to connect the AC heated bed and 24v PSU to the same AC switch with fuse?
                              dc42 administrators @bartolomeus
                              @bartolomeus said in Better safe than sorry: mains voltage AC controlled bed:
                              That's what I do. The PSU almost certainly has an internal mains fuse too.
                                bartolomeus @dc42
                                @dc42 Thanks!
