    Firmware 2.0RC2b/1.21.1 RC2b released
    Firmware installation
    19
    52
    7.4k
      Get it from https://github.com/dc42/RepRapFirmware/releases/tag/2.0RC3. The changes are:
      New features and changed behaviour:
      • M502 now resets all firmware parameters back to the values in config.g except network parameters
      • RRF attempts to pass the estimated print time and simulated print time from GCode files to DWC and PanelDue
      • When M37 is used to simulate a file, at the end of a successful simulation the simulated print time is appended to the file unless parameter F0 is included in the M37 command
      • The default folder for the M36 command is now 0:/gcodes instead of 0:/
      Bug fixes:
      • In RC2 it was no longer possible to turn a heater off by setting its temperatures to -273
      Currently the only way to access the estimated and simulated print times is to send M36 "filename" and extract the information from the JSON response, but in due course DWC and PanelDue will report them.
      zerspaner_gerdundefined 1 Reply Last reply Reply Quote 1
      • Dougal1957undefined
        Dougal1957
        Have upgraded both my Ethernet and Wifi cards with this but it reports as being RC2B 2018-05-13b
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS)RC2b ELECTRONICS: Duet Ethernet 1.02 or later + DueX5 FIRMWARE_DATE: 2018-05-13b3
        is this right or have I messed it up again
        • ShadowXundefined
          ShadowX
          Dave,
          I don't know if this is a bug, but during the delta calibration routine, if the Emergency Stop button is pressed on the PanelDue, the process does not stop. It continues to run until all the probe points are finished. The only way to stop is to hit the power button. I don't know if this is something that can be fixed in the next revision. It seems like a necessary function if something goes wrong during the calibration routine such as the probe not detecting the bed properly.
            dc42 administrators @Dougal1957
            @dougal1957 said in Firmware 2.0RC3/1.21.1 RC3 released:
            That's my fault, I updated the build date but not the RC version. RC2b it is.
              dc42 administrators @ShadowX
              @shadowx said in Firmware 2.0RC3/1.21.1 RC3 released:
              Dave,
              That's a known issue. Panel Due only sends Gcode commands, so the stop command gets queued with everything else.
                Dougal1957 @dc42
                @dc42 thank god for that thought I was being stupid but these things happen lol
                • gen2engundefined
                  gen2eng
                  RC3 is hanging when running a simulation on the attached file.
                  0_1526229112337_CFDMP_Skew Tower.gcode
                    dc42 administrators @gen2eng
                    @gen2eng said in Firmware 2.0RC2b/1.21.1 RC2b released:
                    It simulates OK on my Ormerod:
                    File 1526229129318-cfdmp_skew-tower.gcode will print in 2h 22m plus heating time
                    The simulation took 1min 40sec. At what point does it hang on your printer? Which electronics are you running?
                    gen2engundefined 1 Reply Last reply Reply Quote 0
                    • wilrikerundefined
                      wilriker
                      Installed RC3 (or RC2b) and whatever it was with RC2 that led to delayed reaction of the printer when clicking the move buttons while doing a manual G29 has been fixed. I saw no more delays while leveling my printer a couple of minutes ago. 🙂👍
                      Manuel
                      My Tool Collection
                      • gen2engundefined
                        gen2eng @dc42
                        It was hanging at about 41sec. I did a hard reset and simulation ran fine on a different file. After the current print job finishes, I will try again.
                        I tried the simulation immediately after the upgrade. Any chance it needed a hard reset?
                        I'm running on a 1.03 Duet Wifi.
                        • gen2engundefined
                          gen2eng @gen2eng
                          Ran it again, and it did not hang. The original hang was around 41% complete, not 41 sec.
                          • Danalundefined
                            Danal
                            Loaded:
                            Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
                            Firmware Electronics:	Duet WiFi 1.02 or later
                            Firmware Version:	2.0(RTOS)RC2b (2018-05-13b3)
                            WiFi Server Version:	1.21
                            Web Interface Version:	1.21.1-RC4
                            No prints (yet)
                            • Danalundefined
                              Danal
                              You guys are probably past this... but... just in case, I ran a simulation of the skew tower file. Ran to completion, no issues.
                              7:29:27 PMFile 1526229129318-cfdmp_skew-tower.gcode will print in 3h 7m plus heating time
                              7:27:27 PMM37 P"1526229129318-cfdmp_skew-tower.gcode"
                              Simulating print of file 1526229129318-cfdmp_skew-tower.gcode
                              • Dr_Ju_Juundefined
                                Dr_Ju_Ju
                                Updated successfully with no problems, but I'm having issues while printing (multiple times via USB or local gcode), in that 1\2 to 3\4 of the way through a print, I get "Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C".
                                This results in two conditions, a local print, parks the toolhead to XY cordinates shuts off Bed & halts the printer and errors with Resume-after-power-fail state saved.
                                If I'm printing from USB (Simplify3D), when the failure occurs, S3D knows somthing has gone wrong, but the printer keeps on moving, and keeps the bed heater running, but is unable to extrude.
                                I accept that printer won't know what is being printed, but should the printer do a hard re-set on hard error to at least kill all running prints ??
                                I was\am attempting to print ABS parts for Panobot on DBot 300x300x300 coreXY printer, driven by a DuetEthernet, so using Bed 110 Hotend 255.
                                I've chased all the wiring\checked all connectors, at various points around the bed area, bending strains are reduced as I'm using cable chains.
                                I'm almost at the point where either the problem is on the Board or the heater cartridge (E3D).
                                Next chance I get I'll re-map the heater to E1, if that fails to fix it, I'll replace the cartridge. But its strange that everything works fine for long periods of time, fails, & the one time it has happened while I was near, a board re-set let it resume.
                                Julian,
                                Old goat, learning new things….
                                • gen2engundefined
                                  gen2eng
                                  I've just completed a 10.5 hour print on this release without issue. It appears to be stable with the exception of the weird simulation hang. After a hard reset, the simulation ran fine.
                                  • zerspaner_gerdundefined
                                    zerspaner_gerd @dc42
                                    Does Duet actually choose the correct firmware version automatically? I actually went out of 1.21.1. Now I have 2.0, or have I selected the wrong file?
                                    @dc42 said in Firmware 2.0RC2b/1.21.1 RC2b released:
                                    Are there any other exclusions or only one?
                                    I get this message, is this correct?
                                    M502
                                    Error: Could not set WiFi hostname
                                    HTTP is enabled on port 80
                                    FTP is disabled
                                    TELNET is disabled
                                    Web Interface Version:	1.21.1-RC4'''
                                    Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                                    • brandonhundefined
                                      brandonh
                                      FWIW after upgrading I also experienced the heater fault issue; 4 times on an 8 hr print. Probably just bad luck with a loose connector, as after a reset and restore the print started right back up, and I didn't have the heater calibrated either, and I had seen this happen long ago too. Simulation worked fine with the updated PanelDue and it would be amazing to see the simulation done as a parallel thread to calculate upon print start. Originally had an issue with losing the web interface, but copying over a new web directory solved that.
                                      Saw a small improvement in WiFi transfer; now close to 500 KB/s, up from about 400 KB/s.
                                      Good work!
                                      • timcurtis67undefined
                                        timcurtis67
                                        So far the new firmware and DWC work great. Love the ability to upload files while homing the printer.
                                        A good test will come tonight, Ditto printing (IDEX) on a 8 hour print run.
                                        • BMMalundefined
                                          BMMal
                                          I've been using this since it was released and have not noticed any issues yet.
                                          Duet Ethernet - Most likely the most recent Edge firmware
                                          Duet X5
                                          7" Panel Due V2
                                          Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                                            timcurtis67
                                            Last night While printing a long running part, I uploaded a 17mb file at speeds of 700KB/s with no issues.
                                            Well done David!
