    Firmware 2.0RC2b/1.21.1 RC2b released
    Firmware installation
    19
    52
    7.3k
    • Danalundefined
      Danal
      You guys are probably past this... but... just in case, I ran a simulation of the skew tower file. Ran to completion, no issues.
      7:29:27 PMFile 1526229129318-cfdmp_skew-tower.gcode will print in 3h 7m plus heating time
      7:27:27 PMM37 P"1526229129318-cfdmp_skew-tower.gcode"
      Simulating print of file 1526229129318-cfdmp_skew-tower.gcode
      • Dr_Ju_Juundefined
        Dr_Ju_Ju
        Updated successfully with no problems, but I'm having issues while printing (multiple times via USB or local gcode), in that 1\2 to 3\4 of the way through a print, I get "Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C".
        This results in two conditions, a local print, parks the toolhead to XY cordinates shuts off Bed & halts the printer and errors with Resume-after-power-fail state saved.
        If I'm printing from USB (Simplify3D), when the failure occurs, S3D knows somthing has gone wrong, but the printer keeps on moving, and keeps the bed heater running, but is unable to extrude.
        I accept that printer won't know what is being printed, but should the printer do a hard re-set on hard error to at least kill all running prints ??
        I was\am attempting to print ABS parts for Panobot on DBot 300x300x300 coreXY printer, driven by a DuetEthernet, so using Bed 110 Hotend 255.
        I've chased all the wiring\checked all connectors, at various points around the bed area, bending strains are reduced as I'm using cable chains.
        I'm almost at the point where either the problem is on the Board or the heater cartridge (E3D).
        Next chance I get I'll re-map the heater to E1, if that fails to fix it, I'll replace the cartridge. But its strange that everything works fine for long periods of time, fails, & the one time it has happened while I was near, a board re-set let it resume.
        Julian,
        Old goat, learning new things….
        • gen2engundefined
          gen2eng
          I've just completed a 10.5 hour print on this release without issue. It appears to be stable with the exception of the weird simulation hang. After a hard reset, the simulation ran fine.
          • zerspaner_gerdundefined
            zerspaner_gerd @dc42
            Does Duet actually choose the correct firmware version automatically? I actually went out of 1.21.1. Now I have 2.0, or have I selected the wrong file?
            @dc42 said in Firmware 2.0RC2b/1.21.1 RC2b released:
            M502 now resets all firmware parameters back to the values in config.g except network parameters
            Are there any other exclusions or only one?
            I get this message, is this correct?
            M502
            Error: Could not set WiFi hostname
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
            Firmware Electronics:	Duet WiFi 1.02 or later
            Firmware Version:	2.0(RTOS)RC2b (2018-05-13b3)
            WiFi Server Version:	1.21
            Web Interface Version:	1.21.1-RC4'''
            Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
            • brandonhundefined
              brandonh
              FWIW after upgrading I also experienced the heater fault issue; 4 times on an 8 hr print. Probably just bad luck with a loose connector, as after a reset and restore the print started right back up, and I didn't have the heater calibrated either, and I had seen this happen long ago too. Simulation worked fine with the updated PanelDue and it would be amazing to see the simulation done as a parallel thread to calculate upon print start. Originally had an issue with losing the web interface, but copying over a new web directory solved that.
              Saw a small improvement in WiFi transfer; now close to 500 KB/s, up from about 400 KB/s.
              Good work!
              • timcurtis67undefined
                timcurtis67
                So far the new firmware and DWC work great. Love the ability to upload files while homing the printer.
                A good test will come tonight, Ditto printing (IDEX) on a 8 hour print run.
                • BMMalundefined
                  BMMal
                  I've been using this since it was released and have not noticed any issues yet.
                  Duet Ethernet - Most likely the most recent Edge firmware
                  Duet X5
                  7" Panel Due V2
                  Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                    timcurtis67
                    Last night While printing a long running part, I uploaded a 17mb file at speeds of 700KB/s with no issues.
                    Well done David!
                    • Scachiundefined
                      Scachi
                      I installed RC3 (or RC2b) and printed a couple of small things (~2 hours prints each) without any problems.
                      The baby stepping command seems to be responding a bit faster than before 👍
                      • cgcaferundefined
                        cgcafer
                        I am using RTOS version and generally no problem. Today i add relay unit for controlling 24V line (M80 and M81).
                        It is work but when i first start the printer 7" Panel due still connection state, if i send M80 from DWC then paneldue's state change to idle. After that paneldue can send M80 and M81 without any problem.
                        Is this firmware problem or i made any mistake?
                        Thanks,
                        • Catalin_ROundefined
                          Catalin_RO
                          Did a run on WorkBee with 2.0RC2b and the part was identical to the one machined with 1.21.
                            dc42 administrators @cgcafer
                            @cgcafer said in Firmware 2.0RC2b/1.21.1 RC2b released:
                            Thanks,
                            The PanelDue firmware needs to be updated to support the new Off status returned by the firmware when VIN power is not present.
                            • cgcaferundefined
                              cgcafer
                              Thank you for your answer, tomorrow morning i will check it. Which version it should be?
                                The version that hasn't been released yet!
                                • Danalundefined
                                  Danal @Danal
                                  @danal said in Firmware 2.0RC2b/1.21.1 RC2b released:
                                  Loaded:
                                  Have now printed long-ish (couple of hours) and very short (10 minute) prints with no detectable issues. This is on the large-ish custom delta (600x600x600) at 24V with separate mains heatbed.
                                    dc42 administrators @Danal
                                    Thanks to all of you who have provide feedback on RC2B. I'm looking to fix a few old bugs before the 2.0 release, so there will probably be a RC3 next week.
                                    • Dr_Ju_Juundefined
                                      Dr_Ju_Ju
                                      I've now had a chance to swap Heater 1 for Heater 2, which has appeared to have fixed my issue with heater crashing & failing print, but it does mean the a board I bought in early January has problems (when I got the board, there were unsoldered joints !!).
                                      One issues I have with this is that the Web interface works as expected, but the PanelDue still shows a "phantom" heater H1, with Current\Active\Standby boxes as well as the re-mapped heater as expected.
                                      Julian,
                                        dc42 administrators @Dr_Ju_Ju
                                        @dr_ju_ju said in Firmware 2.0RC2b/1.21.1 RC2b released:
                                        If you believe your Duet was delivered and still is faulty, please ask for it to be replaced under warranty.
                                        Dr_Ju_Juundefined 1 Reply Last reply Reply Quote 0
                                        • otaku521undefined
                                          otaku521
                                          This post is deleted!
                                          • Dr_Ju_Juundefined
                                            Dr_Ju_Ju @dc42
                                            @dc42 I've flipped it back to H1, & started a long'ish print, just to confirm that it still fails. If it does, I'll request a replacement, but at least it looks like the wiring & cartridge etc. are all ok
                                            Julian,
