    Berd-Air pump configuration notes for Duet users
    46
    12.0k
      Duet boards with PCB revision 1.02 and later have flyback diodes already included on all fan outputs.
      • Hergonowayundefined
        Hergonoway @gen2eng
        @gen2eng
        So you've set M106 with F25500 as PWM frequency parameter? I've got the same configuration and mofset is well cooled, just asking before changing the configuration.
        Delta goes BrrrRRRRrrrrrRRRRrrr
        gen2engundefined 1 Reply Last reply Reply Quote 0
        • gen2engundefined
          gen2eng @Hergonoway
          @hergonoway said in Berd-Air pump configuration notes for Duet users:
          @gen2eng
          Correct, I'm using F25500 on a 24V (1.03 Duet Wifi) and 12V (0.85 Duet) without issue. I've got a flyback on both. The 0.85 needs the external flyback, but the 1.03 does not. I am not using the eSwitch module.
          • klcjr89undefined
            klcjr89
            @MSquared Any progress with the brushless pump? 🙂
            • ayudteeundefined
              ayudtee
              Ive got 2 Berd air systems that only need to be at 25% or so to give great part cooling. The sound of air whoosing out is louder than the pump. I am using a brass tube that is 3.75 mm outside diameter with a flattened tip and is positioned to point at the tip of the extruder. This size tube and opening is less restrictive on the pump than the supplied 2.4 mm tube so it runs quieter and supplies more air. Initial positioning of the tube took some trial and error (was quite fiddly as some would say), but once you've got it the results are impressive. My Duets are 0.85 and Wifi 1.0 or 1.01 and both are on 12v. I am not willing to risk running the Berd air pumps on my Duets without the eswitch and hope that no one who does regrets it.
              Hergonowayundefined 1 Reply Last reply Reply Quote 0
                Hergonoway @ayudtee
                @ayudtee
                Thinking about getting a bigger tube, for the same obvious reasons, air flow. 3,75mm is kind of uncommon did you have to flattened the tube (I think of using 1/8" because 4mm seems to big) ? And did you use a jig to bend the "circle" part?
                ayudteeundefined timcurtis67undefined 2 Replies Last reply Reply Quote 0
                • ayudteeundefined
                  ayudtee @Hergonoway
                  @hergonoway 1/8" is an improvement to the stock tube and is close to 3.75 (3.18). I flattened the tube by stripping a length of #12 AWG stranded and inserting as many wires as possible into one end. I flattened the end with a small hammer and pulled out each wire with pliers afterward. I am not using a circle, only the flattened tip.
                  • timcurtis67undefined
                    timcurtis67 @Hergonoway
                    @ayudtee
                    One way to bend soft tubing is to fill it with salt (table salt) and tape the ends shut. Pack it pretty tight and then you can bend it to as tight a circle as you need.
                    Then remove the tape and tap it until all the salt comes out. I blow air thru it as well afterwards.
                      Hergonoway @ayudtee
                      @ayudtee said in Berd-Air pump configuration notes for Duet users:
                      @timcurtis67 said in Berd-Air pump configuration notes for Duet users:
                      @ayudtee
                      Thanks I'll give a shot then !
                      One last question, did you choose a specific angle for the holes ? some people keep the same 90° angle but others use a 45° angle toward the hotend, is there really a benefit from one to another ? the current problem I have with Berdair are on overhang, I've gain airflow by directly connecting the 1/8" tube to the aluminium tube, and I'll certainly gain more air flow by increasing the metal tube, but does orientation in this little space will change anything, I don't know.
                      ayudteeundefined 1 Reply Last reply Reply Quote 0
                      • ayudteeundefined
                        ayudtee @Hergonoway
                        @hergonoway My 2 printers are using an E3D V6 and an Ormerod Quickset II hotend. I do not have enough room under either hotend to use a larger tube that is bent in the stock ring configuration. A larger tube would not fit under either hotend after if it was bent into a circle.
                          Hergonoway @ayudtee
                          @ayudtee Standard E3D nozzle has a clearance of 5mm between the tip and the heatbock. I suppose your using these ones.
                          In my case I'm currently using tungsten MakerBot type of nozzle which have ~8 mm of clearance, so 1/8" should work with a E3D sock, at least I hope from my test on fusion 360.
                          I'll post pictures if it works #FingerCrossed
                          • DocTruckerundefined
                            DocTrucker
                            Where in are people buying these systems in the UK?
                            • ayudteeundefined
                              ayudtee @DocTrucker
                              @doctrucker Do you have access to AliExpress?
                                DocTrucker
                                Never used it, no. Had a look at a couple of the shared links to that site and they were for vacuum pumps rather than posative pressure pumps with warnings about significantly reduced life spans if used to generate posative pressure?
                                c310undefined 1 Reply Last reply Reply Quote 0
                                • c310undefined
                                  c310 @DocTrucker
                                  @doctrucker
                                  recently i have ordered this one https://www.aliexpress.com/item/Aiyima-Micro-Vacuum-Pump-DC12V-24V-50Kpa-Low-Noise-Large-Flow-Splitter-Separator-Diaphragm-Suction-Mini/32862878409.html?spm=a2g0s.9042311.0.0.7bf64c4dkxuMgA
                                  24v pump, but not tested it yet... it looks like berd-air one.
                                    Hergonoway @MSquared
                                    @msquared
                                    Just set F25500 and it damn quiet now thanks for the tip.
                                    But adding a thermistor (the ref given by DC42) in series doesn't work at all, at least for Berdair 24v pump.
                                      dc42 administrators @Hergonoway
                                      @msquared
                                      I guess that pump doesn't draw enough current to heat the thermistor up. There is probably another thermistor in a smaller size that would work. I'll order a few different types and test them.
                                      Hergonowayundefined c310undefined 2 Replies Last reply Reply Quote 0
                                        Hergonoway @dc42
                                        thanks for your help ! unfortunately my multimeter is broken, I can't give additional feedback for the moment.
                                        • coredumpundefined
                                          coredump
                                          So, did anyone try the high frequency PWM with a module like this?
                                          In my test here, using F500 and keeping the pump running at 30-40% gave me a lot of air, and not a lot of noise (I am using this on both intake and outtake), but the F25000 took away my ability to control the pump speed and sounds a little higher. I haven't tested temperatures yet with the two different F values.
                                          I wonder if I should try to connect the pump directly to the DuetWifi. If there's not a lot to gain from that change in the noise department, I think keeping the module makes it safer.
                                          FLsun Kossel mini delta - Duet 0.6
                                          Corexy d-bot - duet wifi
                                          coredumpundefined 1 Reply Last reply Reply Quote 0
                                          • BenDieselundefined
                                            BenDiesel
                                            Have you cracked one of the mufflers open to see how it works?
