    problem with connection to duet3d
    3.0k
      If you send M552 to the Duet from YAT, what response does it give you?
      What browser are you using on your PC, tablet or smartphone, and what response do you get when you enter the IP address in the browser?
      • kuperundefined
        kuper
        this is the photo
        https://ibb.co/i0BpWJ
        I am using PC and I tried to connect with chrome and Microsoft edge, I got nothing "cannot reach the address".
        • Danalundefined
          Danal
          Can you ping that IP from the same PC?
          Open a command prompt and:
          ping 192.168.x.x
          And post the results here.
          • kuperundefined
            kuper
            I ping the IP this is the result,
            https://ibb.co/iO9ibJ
            • Dr_Ju_Juundefined
              Dr_Ju_Ju
              As well as the ping request, in a command window, try telnetting to the ip on port 80 e.g. telnet 192.168.0.170 80
              If you don't get a responce\hangs the web server is not working
              Julian,
              Old goat, learning new things….
              • kuperundefined
                kuper
                sorry, but I didn't understand.
                what command to right exactly? and which port I need to use for the command?
                thanks,
                Adi.
                • Dr_Ju_Juundefined
                  Dr_Ju_Ju
                  the command is:
                  telnet - ipaddress of target - port to try and connect to
                  telnet to ip address on standard web server port
                  Julian,
                    Please show us exactly what the Chrome address bar and main window show when you put the IP address into it, after doing a successful ping test like that one.
                    • kuperundefined
                      kuper
                      Microsoft edge:
                      https://ibb.co/kxDKJ8
                      chrome (nothing)
                      https://ibb.co/eQqoBT
                      I don't know which port number to use in telnet command.
                      this is the photo
                      https://ibb.co/bykGy8
                      thanks.
                      • 3DPMicroundefined
                        3DPMicro
                        is your router set up correctly?
                        see if this helps. what fixed it for me was the steps outlined in the first post
                        https://forum.duet3d.com/topic/4226/dwc-won-t-open-what-am-i-missing-solved
                        Duet controlled Lathe, micro mill, 3d printer and 1992 Haas VF2 VMC
                        • kuperundefined
                          kuper
                          I didn't find any IP address to change in a config file (sys folder)
                            Telnet is no longer provided with recent versions of Windows. I test Telnet using Putty, which is available as a free download.
                            I agree with @3DPMicro, it sounds as if your router is failing to forward the request to the Duet, or failing to pass the response back. However, he had a Duet Ethernet, and I think you have a Duet WiFi - is that correct? If so, please change the end-of-line sequence in YAT to "LF only" (press the "Text settings" button in the Settings screen to find this), then after M552 reports that the Duet is connected to the access point, run M122 to get a diagnostic report.
                            • Dougal1957undefined
                              Dougal1957 @dc42
                              @dc42 Actually Telnet is available in Win10Pro 64 bit (Latest Build) but it does need to be turned on in the Windows Features options
                              • kuperundefined
                                kuper
                                diagnostic report:
                                https://ibb.co/iaRZo8
                                https://ibb.co/iX9LT8
                                  That all looks OK to me, although the firmware you are running is 2 versions out of date. Please try upgrading both firmwares and DWC to 1.21.
                                  • kuperundefined
                                    kuper
                                    I updated to 1.21, I can enter now, thanks a lot.
                                    what is DWC?
                                      DWC is Duet Web Control.
                                      • kuperundefined
                                        kuper
                                        what can be the problem?
                                        https://ibb.co/njRg38
                                        https://ibb.co/jAt9ao
                                        I updated the firmware to 1.21, DWC not updated.
                                          The problem is failure to read the SD card:
                                          1. Please confirm that you have the SD card inserted directly into the slot, pressed in until it clicks.
                                          2. Are you able to read the same SD card on a PC?
                                          • kuperundefined
                                            kuper
                                            when I run the duet, the sd card must be inside? there must to some files?
                                            I tried to run the duet with the SD card(pressed until clicks) and without it.
                                            it still rejected.
                                            actually, when I connected the SD card to PC I had an error that was fixed by the computer, it seems that it works ok.
                                            maybe to try a different SD card?
