    Firmware 2.0RC2b/1.21.1 RC2b released
    Firmware installation
    19
    52
    7.4k
      dc42 administrators @Dr_Ju_Ju
      @dr_ju_ju said in Firmware 2.0RC2b/1.21.1 RC2b released:
      I "may" have found my issue, as although I have an 80mm fan mounted under the duet board, and its enabled with:
      M106 P2 S0.5 T55 H100:101:102 ; Set fan 2 (Duet Board) to come on half power if any driver chip reaches 55 degrees
      it has not been coming on with this firmware ?? and some of the ic's including the heater power mosfet have been getting very hot to the touch.
      It used to work fine with the release firmware, but I don't know if anything has changed ??
      As I'm in the middle of a long print, for a stop-gap I've carefully sat a 40mm fan on top of the wiring from the drivers, driven from one of the "always on fans", which is keeping everything cool.
      I'll investigate further when the print completes (hopefully).
      The drivers don't actually report their temperatures, they report an over temperature warning if they exceed a threshold that is in the region of 120C 100C. In bench testing this happened quite quickly with 3 driver's running at 2.4A if idle current reduction was not allowed to take place and there was no fan cooling, but not at all if the current was reduced to 2.0A.
      • 4latheundefined
        4lathe @4lathe
        David, is this a 2.0 behavior change or a 1.21.1 rc4 issue?
          There is no intended behaviour change from earlier firmwares in this respect.
          • Dr_Ju_Juundefined
            Dr_Ju_Ju
            Then I'm surprised it isn't working as I set it, as I've not changed any motor currents etc. so I would still expect to see\feel that the fan is working, but patently it isn't.
            Julian,
            Old goat, learning new things….
              What motor currents are you using?
              • Dr_Ju_Juundefined
                Dr_Ju_Ju
                M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
                M906 X1000 Y1000 Z1000 E1100 I50 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S90 ; Set idle timeout
                Julian,
                  At 1A the stepper drivers won't get hot enough to trigger the thermal warning. See my earlier reply.
                  • Dr_Ju_Juundefined
                    Dr_Ju_Ju
                    I unstand what you are saying, so unless I drive the motors above their normal operating currents, then the fan will never come on.
                    But according to the datasheet (https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2660_datasheet.pdf) section 11.3, a flag is set when the chip reaches 100 degrees (OTPW), is this not trapped, so that external cooling can be applied ??
                    Granted this is not optimal, but as there is no local temperature probe, its all that's available to monitor the temperature of the Duet board, and effect some forced cooling.
                    Julian,
                    whosrdaddyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • whosrdaddyundefined
                      whosrdaddy @Dr_Ju_Ju
                      @dr_ju_ju : the board does a such a good job dissipating the heat of the drivers that 1A is not enough to overheat the drivers, hence it won't trip the flag...
                      • ShadowXundefined
                        ShadowX
                        Just lower the temperature threshold or have the fan be connected to an "always on" connection. Case closed. Next subject.
                        • r123undefined
                          r123 @r123
                          @r123 said in Firmware 2.0RC2b/1.21.1 RC2b released:
                          Is there a post somewhere explaining the virtues of an RTOS-based firmware? For developer and end-user alike?
                          @r123 nobody knows?
                            Yes that's the over temperature warning flag that we monitor as I described in my earlier reply. You need more than 2A motor current to set it off.
                            • timcurtis67undefined
                              timcurtis67
                              So far Idex is working well. Here is a short video and picture using ditto printing of 2 sets of parts.
                              https://photos.app.goo.gl/LogVpsspHeL29Qih2
                              • mperdueundefined
                                mperdue
                                When i level my bed before a print i’m Getting the following message, “Number of calibration factors (0) not equal to number of lead screws (4)”
                                These are the probes that I’m doing. this worked on 1.19 so I’m not sure what’s up with this.
                                G30 P0 X30 Y280 Z-999 ; probe near back left lead screw
                                G30 P1 X390 Y280 Z-999
                                G30 P2 X390 Y25 Z-999
                                G30 P3 X30 Y25 Z-999 S4 ; probe near a leadscrew and calibrate 4 motors
                                • mperdueundefined
                                  mperdue
                                  Anyone have any ideas on the leveling issue?
                                    The Z value in your G30 commands should be -9999 or -99999, not -999.
                                      Firmware 2.0RC5 is out, so I have started a new thread for it and I am closing this thread.
