    Firmware 2.0RC2b/1.21.1 RC2b released
    Firmware installation
    19
    52
    7.4k
    • Dr_Ju_Juundefined
      Dr_Ju_Ju
      I unstand what you are saying, so unless I drive the motors above their normal operating currents, then the fan will never come on.
      But according to the datasheet (https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2660_datasheet.pdf) section 11.3, a flag is set when the chip reaches 100 degrees (OTPW), is this not trapped, so that external cooling can be applied ??
      Granted this is not optimal, but as there is no local temperature probe, its all that's available to monitor the temperature of the Duet board, and effect some forced cooling.
      Julian,
      Old goat, learning new things….
      whosrdaddyundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • whosrdaddyundefined
        whosrdaddy @Dr_Ju_Ju
        @dr_ju_ju : the board does a such a good job dissipating the heat of the drivers that 1A is not enough to overheat the drivers, hence it won't trip the flag...
        • ShadowXundefined
          ShadowX
          Just lower the temperature threshold or have the fan be connected to an "always on" connection. Case closed. Next subject.
          • r123undefined
            r123 @r123
            @r123 said in Firmware 2.0RC2b/1.21.1 RC2b released:
            Is there a post somewhere explaining the virtues of an RTOS-based firmware? For developer and end-user alike?
            @r123 nobody knows?
              dc42 administrators @Dr_Ju_Ju
              @dr_ju_ju said in Firmware 2.0RC2b/1.21.1 RC2b released:
              Yes that's the over temperature warning flag that we monitor as I described in my earlier reply. You need more than 2A motor current to set it off.
              • timcurtis67undefined
                timcurtis67
                So far Idex is working well. Here is a short video and picture using ditto printing of 2 sets of parts.
                https://photos.app.goo.gl/LogVpsspHeL29Qih2
                • mperdueundefined
                  mperdue
                  When i level my bed before a print i’m Getting the following message, “Number of calibration factors (0) not equal to number of lead screws (4)”
                  These are the probes that I’m doing. this worked on 1.19 so I’m not sure what’s up with this.
                  G30 P0 X30 Y280 Z-999 ; probe near back left lead screw
                  G30 P1 X390 Y280 Z-999
                  G30 P2 X390 Y25 Z-999
                  G30 P3 X30 Y25 Z-999 S4 ; probe near a leadscrew and calibrate 4 motors
                  • mperdueundefined
                    mperdue
                    Anyone have any ideas on the leveling issue?
                      The Z value in your G30 commands should be -9999 or -99999, not -999.
                        Firmware 2.0RC5 is out, so I have started a new thread for it and I am closing this thread.
