    Duet Web Control wishlist notes and priorities
    32
    116
    20.7k
    • wilrikerundefined
      wilriker @chrishamm
      @chrishamm said in Duet Web Control wishlist notes and priorities:
      TBH I never intended to make the move buttons configurable on the M291 dialog so this was in fact a bug which has been resolved in my current beta 2.
      In this case I see this new feature rather as a regression.
      For me 0.1mm as lowest value was always too large when doing manual mesh bed leveling (this might be personal preference over real need but yeah, that's me 😉 ).
      So I could at least use the option in UI settings to half the values of all Z-movement buttons everywhere.
      Now I am stuck with the previous defaults at the place where I would need modifying primarily but I am able to modify all other buttons - where I was happy with the default. 😞
      I know I can just modify reprap.htm.gz (and in fact that is what I did with the current DWC beta) but since these values are modifiable everywhere else I would find it more consistent to also be able to modify them on M291 dialogs - or at least get this "half Z-movements" option back.
      Ah! I see that the values for the M291 dialog are now bound to the same values that are used in Machine Control. That's something I can live with very well! Thank you. 🙂
      Manuel
      My Tool Collection
        Phaedrux Moderator @chrishamm
        @chrishamm Small issue.
        I updated to DWC 1.21.2 b1 and noticed that all of the list items for Gcodes and temperatures had been reset.
        I updated to DWC 1.21.2 b2 and your customized version of RTOS 2.0b1 and now the list items for custom gcodes have been replaced by numbers and there doesn't appear to be any way to add new ones.
        • Ethelredundefined
          Ethelred
          Unable to add new bed or extruder temperatures via the List Item page. DWC disconnects. Worked in older version.
          • zerspaner_gerdundefined
            zerspaner_gerd
            This is also a nice new feature:☺
            For some time now, I have always had a double FAN ("Tool Fan") slider
            Slider 1 and 2 is for the same fan.
            Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
            • wilrikerundefined
              wilriker
              I found a minor issue in the latest beta (possibly older versions, too):
              The text of the title attribute for
              Machine Status -> Sensors -> Vin lists minimum and maximum voltage but appends °C instead of V as a unit.
              Manuel
              My Tool Collection
                T3P3Tony administrators @wilriker
                @wilriker thanks, I think you mean the "hover text"?
                just clarifying so @chrishamm can find it easier!
                • wilrikerundefined
                  wilriker @T3P3Tony
                  @t3p3tony I actually referred to the HTML title attribute of the related <td> tag. 😉 So we are both right. 😁
                  P.S.: Updated original post to be more clear. 🙂
                  Manuel
                  My Tool Collection
                    @wilriker 🤦 apologies
                      @chrishamm I've been testing 1.21.2-b2 and your firmware build for a while and things seem to be working alright. One thing I have noticed is that the auto-complete in the G-code console seems to be rather aggressive. If you have several entries in the list and you try and manually enter a shorter version of the command you have to press escape to close the auto complete list before you can enter it.
                      Example, if the list has M566 X1000 Y1000, M566 E999, M566 X10 Y10, and you want to just enter M566 without any parameters the auto complete will insist on highlighting one of the previous values with parameters until you press escape. Once it's been entered once without parameters it will go into the list and will be selected going forward, but the first time you try and enter it can be rather confusing and frustrating.
                      • wilrikerundefined
                        wilriker
                        I can confirm what @Phaedrux reports about the auto-completion.
                        Manuel
                        My Tool Collection
                          dc42 administrators @wilriker
                          I can confirm this about the auto completion too, in addition it seems to be case-insensitive which can be a problem sometimes.
                          • chrishammundefined
                            chrishamm administrators
                            If you can, please update to my latest beta here: https://github.com/chrishamm/DuetWebControl/blob/dev/DuetWebControl-1.22-b1.zip The changelog this time is:
                            • Minor layout changes
                            • Removed fotomas's Dark theme in favour of standard Slate theme
                            • Improved theme support for standard Boostrap 3 themes
                            • Added a few new Bootstrap 3 themes from bootswatch.com
                            • Added MCU temperature to Sensors panel
                            • Added machine mode string to the Machine Status panel (requires latest RRF version)
                            • Made usage of localStorage optional
                            • Greatly improved automatic reconnect behaviour
                            • Added more movement buttons for XL displays (>= 1500px)
                            • Clicking on the axis coordinates allows setting them directly via G92
                            • Factory defaults of DWC can be stored as dwc_factory.json on the SD card in /www
                            • Bug fix: G-Code auto completion always selected the first entry
                            • Bug fix: Some elements were not named correctly causing the W3C validation to fail
                            • Bug fix: Units of min+max voltages were wrong
                            • Minor OEM enhancements
                            !! IMPORTANT !! I no longer support fotomas's dark theme, so please do not be surprised that the web interface looks fairly bad if you used it before. Instead of the Dark theme I suggest you change to the Slate theme which will look similar but cleaner IMHO. Also, there are plenty of Bootstrap 3 themes out there, so if find any other theme that looks nice with DWC, please let me know and I will add it provided the license is OK. To install it, just rename it to <themename>.theme.css and upload it on via the Upload button on DWC. After reloading the web interface, it should be available for selection.
                            If you notice any more problems, please let me know. AFAICS there is only one problem concerning the extruder drive positions that I am still trying to track down but if no other issues show up, I hope I can finally publish a "real" release for v1.22 soon.
                            @zerspaner_gerd The first two fans are identical because the default tool fan is #0. You could customise that via M563 though.
                            Duet software engineer
                            wilrikerundefined 1 Reply Last reply Reply Quote 1
                            • ShadowXundefined
                              ShadowX
                              Any chance of adding function to download all the macros as a zip file instead of just having a "delete" option only?
                              Phaedruxundefined 1 Reply Last reply Reply Quote 2
                                Phaedrux Moderator @ShadowX
                                @shadowx that would be handy. In the meantime the easiest way to download all the macros (or anything else on the SD card) without removing the card itself is to setup an FTP connection.
                                Filezilla is the recommended client.
                                ShadowXundefined 1 Reply Last reply Reply Quote 0
                                • wilrikerundefined
                                  wilriker @chrishamm
                                  @chrishamm Thanks for the new version! I can confirm that both the wrong units for voltages as well as the aggressiveness of the auto-completion have been fixed.
                                  I personally like the new Slate theme a lot over the old Dark theme. Only thing I will probably change is the background color for input fields as well as the text-editor modal to #AAA as the white background is too much of a contrast IMHO.
                                  I also like the new arrangement at the top.
                                  But I found an inconsistency (already in previous beta, not sure about earlier version) in the size of the baby-stepping buttons: They are asymmetric if there is not enough horizontal space
                                  I get that they need to adapt as they are responsive I just don't like that they adapt individually. I'd rather have both of them be tall instead just one of them. My CSS-fu is far from being good so I have no clue if this can even be achieved at all but my inner-symmetry-requirements would love to see this being changed. 😉
                                  EDIT: One more enhancement might be nice: in the sensors section if you hover the Vin value you get min and max for it as title text. The same could be done for MCU temp as the values are also provided with the full response.
                                  EDIT 2: Only just now realized: where is the Disconnect button gone to? I used that to disconnect from DWC when connected from remote to save bandwidth but it seems to be gone now.
                                  Manuel
                                  My Tool Collection
                                  • reahaxundefined
                                    reahax
                                    Delta auto delta calibration gui.
                                    • wilrikerundefined
                                      wilriker @reahax
                                      @reahax I can confirm this with a generic M291 Z1 ... command:
                                      In case it is not obvious: the negative values are some defaults and not the ones the user set (as can be seen for the positive values).
                                      EDIT: I just realized that these aren't default values but my custom ones just offset by two - which might come from additional buttons due to a wide screen...
                                      EDIT2: I tracked this down and created Negative buttons in M291 dialog have high-end values instead of low-end #87 at GitHub. It's just one value to be adjusted so I did not create a PR for this.
                                      Manuel
                                      My Tool Collection
                                      reahaxundefined 1 Reply Last reply Reply Quote 1
                                      • reahaxundefined
                                        reahax @wilriker
                                        @wilriker im pretty new with duet board. How can i adjust these values ?
                                        • wilrikerundefined
                                          wilriker @reahax
                                          @reahax On the Machine Control tab just right-click any value you want to change and it will open a dialog to enter the new value. Positive and negative values are always bound together. After all values have been adjusted go to Settings tab and hit the Apply button to save. Otherwise the values will be lost on reload.
                                          Manuel
                                          My Tool Collection
                                          reahaxundefined 1 Reply Last reply Reply Quote 0
                                          • reahaxundefined
                                            reahax @wilriker
                                            @wilriker Thanks, good to know. But i can't do this for delta auto delta calibration menu.
