    Core XY movement issues
    103
    14.3k
    • FxxTooundefined
      FxxToo @deckingman
      @deckingman
      Maybe dc42 or Tony can explain this. I just know that my issue went away when I put the M92 for the proper setting for x16 microstepping and then set microstepping with M350, as per the post I read from dc42. Still have a lot to learn about this. -rj
      • JoergS5undefined
        JoergS5 @FxxToo
        @fxxtoo maybe your problem reappears when you change to 1/64 stepping, because this was your original setting.
          Yes I would be interested to see if you can now recreate the problem to verify the fix.
          FxxTooundefined 1 Reply Last reply Reply Quote 0
          • FxxTooundefined
            FxxToo @Phaedrux
            @phaedrux , @joergs5
            I just tried this in my config.g
            M92 X80 Y80 Z80 E420 ; Set steps per mm x80 y80 z175 z80 z85
            M350 x64 y64 Z128 ; Configure microstepping with interpolation
            ;M92 Y320 Y320 Z1400 E420 ;mod to test 64 micro stepping This resulted in the normal movement.
            changed to this:
            ;M92 X80 Y80 Z80 E420 ; Set steps per mm x80 y80 z175 z80 z85
            M92 Y320 Y320 Z1400 E420 ;mod to test this resulted in movement on the Y while doing a G1 x100
            So the answer is , Yes I can duplicate it.
            Other than my reply earlier, I have no clue why this is happening. I just know that I can move forward now..
            RJ
            JoergS5undefined 1 Reply Last reply Reply Quote 1
            • JoergS5undefined
              JoergS5 @FxxToo
              @fxxtoo you mean, when you use 1/64, the fix does not work?
              work?
              • FxxTooundefined
                FxxToo @JoergS5
                @joergs5 I am not sure what you are asking me.
                the first example puts the step rate at 1/16 M92 X80 Y80 followed by the M350 changing the step rate to 1/64 (letting the firmware adjust the steps per mm). This works correctly.
                The second example puts the step rate at 1/64 (M350 X64 Y64) followed by the M92 command, which gives the same thing, but spells out the steps per mm. This does not work correctly. Maybe doing it this way causes the firmware to miss a variable or miscalculate the steps due to the order it gets the settings. I am thinking of posting this question to dc42. He might have some knowledge why this happens.
                rj
                JoergS5undefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                • JoergS5undefined
                  JoergS5 @FxxToo
                  @fxxtoo thank you for explanation, this was the information I wanted.
                  So the configuration tool and the two documentations are wrong in this respect. It should be wrong for cartesian printers also.
                    deckingman @FxxToo
                    @fxxtoo said in Core XY movement issues:
                    rj
                    That's what's puzzling us all because it works fine for me (and everyone else). The configuration tool is correct and the documentation is correct. If it wasn't there would hundreds if not thousands (depending on how many boards have been sold) of disgruntled users and complaints.
                      deckingman @JoergS5
                      @joergs5 said in Core XY movement issues:
                      No. The configuration tool is correct and so is the documentation.
                      • JoergS5undefined
                        JoergS5 @deckingman
                        @deckingman
                        just my 2ct:
                        maybe only an effect in Corexy, because only there in CoreXYKinematics.cpp is a CartesianToMotorSteps and MotorStepsToCartesian where rounding errors could occur between int motorPos and the other floats. If you calculate with first, then second function, result will not be 0 as should be with inverted functions.
                        Thesis: In Move.cpp those functions are called for every segment, so more microsteps will sum up rounding errors faster.
                          deckingman @JoergS5
                          @joergs5 Well OK but as I said in an earlier post, just for the hell of it, I tried configuring my CoreXY both ways and can't replicate the OPs problem.
                          FxxTooundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
                          • FxxTooundefined
                            FxxToo @deckingman
                            @deckingman
                            So your tried this and couldn't replicate the movement? Here is my modded config file, with some notes. Maybe I have messed something else up as well..and just waiting to bite me.
                            M111 S0 ;DEBUGGING OFF
                            M555 P2 ; Set firmware compatibility to look like MARLIN
                            M667 S1 ; Select CoreXY mode
                            M550 PRJPRINT ; Set machine name
                            ;M552 S1 ; Enable network
                            M552 S1 P192.168.1.99 ;SET IP ADDRESS
                            M553 P255.255.255.0 ;SET SUBNET MASK
                            M586 P0 S1 ; Enable HTTP
                            M586 P1 S0 ; Disable FTP
                            M586 P2 S0 ; Disable Telnet
                            M208 X325 Y415 Z0 S0 ; Set axis maxima
                            M208 X0 Y0 Z-600 S1 ; Set axis minima
                            ; Drives M569: Set motor driver direction, enable polarity and step pulse timing Parameters
                            ;M584 X1 Y0 ; test for Ian Swapping the A & B connectors test
                            M569 P0 S1 ; Drive 0 goes FORWARDS Rnnn Driver enable polarity: 0 = active low, 1 = active high (default 0)
                            M569 P2 S0 ; Drive 2 goes forwards
                            ; If I put the M350 command here and comment out the existing M350 (2 lines down)
                            M92 X80 Y80 Z80 E420 ; Set steps per mm @ 1/16 step rate
                            M350 x128 y128 Z128 ; Configure microstepping with interpolation
                            ;M92 Y320 Y320 Z1400 E420 ;mod to test 64 micro stepping <----this one will cause the movement on Y while moving x
                            ;M92 X320 Y319 z1400 E420 ; to test to see if it corrects the speed <----This one stops the Y movement while moving x
                            M566 X600 Y600 Z100 E120 ; Set maximum instantaneous speed changes (mm/min)
                            M203 X6000 Y6000 Z4000 E1200 ; Set maximum speeds (mm/min) CHANGED FROM 6000 TO 600 Z NO CHG
                            M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
                            M906 X1500 Y1500 Z1500 E800 I40 ; Set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            M574 Z1 S0 ; Set active low endstops
                            M574 X1 Y1 Z2 S0
                            ;M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
                            ;M558 P0 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
                            ;G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                            ;M557 X15:327.9 Y15:391 S20 ; Define mesh grid
                            M140 H1 ; Remap heated bed to heater 1
                            M301 H1 P-1 ; Set heater 1 to bang-bang mode
                            M305 P0 X200 ; Configure thermocouple for heater 0
                            M305 P1 X201 ; Configure thermocouple for heater 1
                            M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M563 P0 D0 H0 ; Define tool 0
                            ; Automatic power saving
                            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                            • JoergS5undefined
                              JoergS5 @deckingman
                              @deckingman did you try the firmware version FxxToo uses? There was a bugfix in 1.21 for M350, maybe this or another change has an effect.
                                deckingman @JoergS5
                                Read my earlier post - 18th July 11:44
                                • JoergS5undefined
                                  JoergS5 @deckingman
                                  @deckingman
                                  Ok, I will try to understand and compare the different firmware versions and verify whether there are errors in it. My guess is, that processing M92-M350 produces different rounding errors than M350-M92.
                                  You said that a lot of people are using the code and an error would be detected. But if the rounding error is small enough for most settings, nobody will mention, but push it to mechanical deficiencies.
                                    dc42 administrators @JoergS5
                                    @deckingman
                                    Any rounding errors would be far too small to have this much effect, and when using the same microstepping and steps/mm on the X and Y motors, they would affect both motors equally anyway.
                                    Can you confirm that if you swap the order of the M350 and M92 commands back to your original order, and adjust the M92 values as needed, the problem returns?
                                    • FxxTooundefined
                                      FxxToo @dc42
                                      Yes I can. I posted that result here : https://forum.duet3d.com/post/55484
                                      I had found a post that you had done about putting the M92 Xxx Yxx, with the steps set for 1/16 step rate before the M350 command. I changed that and my issue with the Y moving with the X and vice versa, Stopped. I was asked if I could replicate it. I tried and I could. I thought maybe I had something else that could effect it in my config file, so I posted it after I had changed it, leaving the original statements marked in it, obviously commented out.
                                      Firmware Electronics: Duet Ethernet 1.02 or later
                                      Firmware Version: 1.21 (2018-03-21)
                                      Web Interface Version: 1.21Firmware Name: RepRapFirmware for Duet 2 WiFi/Ethernet
                                      RJ
                                      • JoergS5undefined
                                        JoergS5 @dc42
                                        @dc42 how about enable logging M929 (or more) and printing a simple line, this should give information whether the second stepper moves unexpectedly.
                                        According to:
                                        https://duet3d.dozuki.com/Wiki/Logging
                                        I believe you that the rounding errors are not applicable, but it's maybe another reason in the code.
                                        • JoergS5undefined
                                          JoergS5 @FxxToo
                                          M574 X1 Y1 Z2 S0
                                          I think it has nothing to do with the thread problem, but I am confused by a config setting: why are there two Z endstops, one for Z1 and one for Z2, low end and high end?
                                          (If the second is a Z-probe, I thought you need to set it as S2 instead of as Z2)
                                          • FxxTooundefined
                                            FxxToo @JoergS5
                                            @joergs5
                                            I was going to try it with the end stop on either end the of the Z. So I had done that before my issue was discovered. I haven't gotten to those tweaks or others, like the accelerations, jerk factor and lots of others. Still learning about a lot of this. I do appreciate the input.
                                            RJ
