    Blobs and under extrusion with S3D
    2.4k
    • pogo1213undefined
      pogo1213
      Hardware
      Titan and v6 direct
      Adjusted retraction distance and speed and with each retraction on the outside shows a blob and under extrusion after the blob. Any ideas?
        If you have firmware retraction setup for S3D you could try this to help make it easier to tune:
        https://forum.duet3d.com/topic/5993/firmware-retraction-tuning-with-macros/9
        What are you currently using for retraction and extruder speed settings?
        • pogo1213undefined
          pogo1213
          Started with .8mm retraction at 1200mm/min now up to 1.8 at 3600mm/min with no fix
            Phaedrux Moderator @pogo1213
            @pogo1213 What's your extruder max speed, accel, and jerk set to?
            What material and temp? What is your unretract speed? Pressure advance? Travel speed and acceleration? Are you using S3D coasting? Have you run a PID tune on your hot end heater? Have you measured your filament diameter and calibrated e steps? How fast are you trying to print?
            I can give you my settings I use for my Titan Aero, and while similar to the V6, there's no guarantee they will fix your issue. There's a lot of variables at play.
            M201 E8000                         	; Set maximum accelerations (mm/s^2)
            M203 E15000                        	; Set maximum speeds (mm/min)
            M204 P3000 T4500					; Set printing and travel accelerations
            M566 E3000                            	; Set maximum instantaneous speed changes (mm/min) (Jerk)
            M207 S0.8 R0 F7200 T1200 Z0.0  ; retraction settings
            M572 D0 S0.05 ; pressure advance for PLA direct drive
            • pogo1213undefined
              pogo1213
              I am currently testing this
              M566 X900 Y900 Z12 E3000 ; Set maximum instantaneous speed changes (mm/min) start 900
              M203 X6000 Y6000 Z180 E15000 ; Set maximum speeds (mm/min)
              M201 X500 Y500 Z250 E8000 ; Set accelerations (mm/s^2)
              M906 X800 Y800 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M572 D0 S0.05
              but so far still having blobs
                Your extruder speed and acceleration are set very high. Are you sure you are not getting missed steps during retraction?
                • pogo1213undefined
                  pogo1213
                  @dc42 I started far below as noted below:
                  M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                  M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  and I was getting similar results that was discussed here:
                  https://forum.duet3d.com/topic/849/tweaking-for-perfect-jerk-accel-pressure-advance-blob-removal/28
                  I have dropped my retraction all the way down to 0.2mm but after the retraction it under extrudes for ~15mm. I have a print running with a higher pressure advance to see if that makes a difference
                    Phaedrux Moderator @dc42
                    @dc42 I only got hiccups when testing 256 microstepping. With 16 Ive never noticed any.
                    • pogo1213undefined
                      pogo1213
                      i attempted 0.2 pressure advance and it looked better so Im attempting 0.5
                        @pogo1213 are you using a Bowden setup or direct drive? 0.5 is quite high for a direct drive.
                        • pogo1213undefined
                          pogo1213
                          direct but Im running out of possible solutions
                          • pogo1213undefined
                            pogo1213
                            0.5 was to much but 0.2 has worked pretty well but it hasn't solved it just made it look slightly better
                            • pogo1213undefined
                              pogo1213
                              I have retraction down to 0.2mm without stringing and no longer leaving blobs just leaving a void immediately after the retraction
                                dc42 administrators @pogo1213
                                @pogo1213 said in Blobs and under extrusion with S3D:
                                You can use "Extra restart distance" to avoid that.
                                • zerspaner_gerdundefined
                                  zerspaner_gerd
                                  I also have a larger Z-seam with S3D.
                                  With Cura I have much smaller nicer ones.
                                  I could not find any differences between the two gcode files.
                                  Here are the two gcode files:
                                  1_1532300304525_S3D.gcode
                                  0_1532300304525_Cura.gcode
                                  Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                                  pogo1213undefined 1 Reply Last reply Reply Quote 0
                                  • pogo1213undefined
                                    pogo1213 @zerspaner_gerd
                                    @zerspaner_gerd what type of extruder?
                                    • pogo1213undefined
                                      pogo1213
                                      This post is deleted!
                                      • pogo1213undefined
                                        pogo1213
                                        After a large amount of tweaking Retraction speed and distance (ending with 0.2mm distance and 5000mm/min speed), Pressure advance (0.05) and extra restart distance (ranging from 0 to 0.2, settling on 0) I still have a small seam. Any other suggestions?
                                        https://drive.google.com/file/d/176qYIU3DtLloxzfob3uDFD5SV3tU5ere/view?usp=sharing
                                        https://drive.google.com/file/d/1rS7onyxYcRK3mBEMIRk2-sgEGEXSywZ0/view?usp=sharing
                                        https://drive.google.com/file/d/1-vrav9f9cwBVXSd_euZr62YmYs5Tix7e/view?usp=sharing
                                          That's a quite good seam actually. You'll never completely eliminate it. Now the trick will be trying different options to hide it in the model. I'm not very familiar with simplify 3ds options but I assume it's similar to slic3r and Cura and gives you the option to try and hide it on the sharpest inside corner or align it to a specific place. It'll depend on the model on which will work best. On angular shapes I find it easier to align it to the sharpest corners. On more organic shapes I usually just align it to a single side.
                                          Have you also tested for stringing between travel.moves yet? 0.2mm is fairly low. How about an actual print?
                                          • pogo1213undefined
                                            pogo1213
                                            I ran a retraction test (4 spikes in a 20x20mm square) with great results at 0.2. I also printed a few parts in pla with no issue, PETG Im bumping it up to 0.5-0.8 to get great results.
