Blobs and under extrusion with S3D
2.4k
    Phaedrux Moderator @pogo1213
    @pogo1213 What's your extruder max speed, accel, and jerk set to?
    What material and temp? What is your unretract speed? Pressure advance? Travel speed and acceleration? Are you using S3D coasting? Have you run a PID tune on your hot end heater? Have you measured your filament diameter and calibrated e steps? How fast are you trying to print?
    I can give you my settings I use for my Titan Aero, and while similar to the V6, there's no guarantee they will fix your issue. There's a lot of variables at play.
    M201 E8000 ; Set maximum accelerations (mm/s^2)
    M203 E15000 ; Set maximum speeds (mm/min)
    M204 P3000 T4500 ; Set printing and travel accelerations
    M566 E3000 ; Set maximum instantaneous speed changes (mm/min) (Jerk)
    M207 S0.8 R0 F7200 T1200 Z0.0 ; retraction settings
    M572 D0 S0.05 ; pressure advance for PLA direct drive
      pogo1213
      I am currently testing this
      M566 X900 Y900 Z12 E3000 ; Set maximum instantaneous speed changes (mm/min) start 900
      M203 X6000 Y6000 Z180 E15000 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E8000 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M572 D0 S0.05
      but so far still having blobs
        Your extruder speed and acceleration are set very high. Are you sure you are not getting missed steps during retraction?
        undefined 1 Reply Last reply 21 Jul 2018, 06:41 Reply Quote 0
          pogo1213
          @dc42 I started far below as noted below:
          M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
          M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
          M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          and I was getting similar results that was discussed here:
          https://forum.duet3d.com/topic/849/tweaking-for-perfect-jerk-accel-pressure-advance-blob-removal/28
          I have dropped my retraction all the way down to 0.2mm but after the retraction it under extrudes for ~15mm. I have a print running with a higher pressure advance to see if that makes a difference
            Phaedrux Moderator @dc42
            @dc42 I only got hiccups when testing 256 microstepping. With 16 Ive never noticed any.
              pogo1213
              i attempted 0.2 pressure advance and it looked better so Im attempting 0.5
              undefined 1 Reply Last reply 21 Jul 2018, 06:45 Reply Quote 0
                @pogo1213 are you using a Bowden setup or direct drive? 0.5 is quite high for a direct drive.
                  pogo1213
                  direct but Im running out of possible solutions
                    pogo1213
                    0.5 was to much but 0.2 has worked pretty well but it hasn't solved it just made it look slightly better
                      pogo1213
                      I have retraction down to 0.2mm without stringing and no longer leaving blobs just leaving a void immediately after the retraction
                      undefined 1 Reply Last reply 21 Jul 2018, 07:58 Reply Quote 0
                        dc42 administrators @pogo1213
                        @pogo1213 said in Blobs and under extrusion with S3D:
                        You can use "Extra restart distance" to avoid that.
                          zerspaner_gerd
                          I also have a larger Z-seam with S3D.
                          With Cura I have much smaller nicer ones.
                          I could not find any differences between the two gcode files.
                          Here are the two gcode files:
                          1_1532300304525_S3D.gcode
                          0_1532300304525_Cura.gcode
                          Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                          undefined 1 Reply Last reply 24 Jul 2018, 02:37 Reply Quote 0
                            pogo1213 @zerspaner_gerd
                            @zerspaner_gerd what type of extruder?
                              pogo1213
                              This post is deleted!
                                pogo1213
                                After a large amount of tweaking Retraction speed and distance (ending with 0.2mm distance and 5000mm/min speed), Pressure advance (0.05) and extra restart distance (ranging from 0 to 0.2, settling on 0) I still have a small seam. Any other suggestions?
                                https://drive.google.com/file/d/176qYIU3DtLloxzfob3uDFD5SV3tU5ere/view?usp=sharing
                                https://drive.google.com/file/d/1rS7onyxYcRK3mBEMIRk2-sgEGEXSywZ0/view?usp=sharing
                                https://drive.google.com/file/d/1-vrav9f9cwBVXSd_euZr62YmYs5Tix7e/view?usp=sharing
                                  That's a quite good seam actually. You'll never completely eliminate it. Now the trick will be trying different options to hide it in the model. I'm not very familiar with simplify 3ds options but I assume it's similar to slic3r and Cura and gives you the option to try and hide it on the sharpest inside corner or align it to a specific place. It'll depend on the model on which will work best. On angular shapes I find it easier to align it to the sharpest corners. On more organic shapes I usually just align it to a single side.
                                  Have you also tested for stringing between travel.moves yet? 0.2mm is fairly low. How about an actual print?
                                    pogo1213
                                    I ran a retraction test (4 spikes in a 20x20mm square) with great results at 0.2. I also printed a few parts in pla with no issue, PETG Im bumping it up to 0.5-0.8 to get great results.
                                      I'd say you're good to go then. Print a benchy or some other actual model and see how things look for further tuning.
                                        pogo1213
                                        After playing with retraction and pressure advance everything looks good when its not moving between parts. When it is it comes out like this
                                        https://drive.google.com/file/d/13OBB-CuOU5PKmGub2PCu8fpjo6xvNbqS/view?usp=sharing
                                        Any suggestions?
                                          What is your travel speed in the slicer?
                                          In your config.g do you have an M204 command to specify print acceleration and travel acceleration?
                                          200mm/s or more for travel moves is probably desirable and acceleration values 4000 to 6000mm/min. Greatly reduces the time available for strings to ooze out.
                                          M204 P1000 T5000
                                          13 out of 23
