    Dave's so proud
    47
    4.8k
    • Danalundefined
      Danal @sjason1377
      This post is deleted!
      • sjason1377undefined
        sjason1377 Banned
        RepRapFirmware for Duet 2 WiFi/Ethernet
        Firmware Electronics: Duet Ethernet 1.02 or later
        Firmware Version: 2.01(RTOS) (2018-07-26b2)
        Web Interface Version: 1.21.2-dc42
          sjason1377 Banned
          M574 X1 Y1 S1 ; Set active low endstops
          M574 Z0
          M558 P9 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
          G31 P600 X0 Y12 Z.96; Set Z probe trigger value, offset and trigger height
          M557 X52:300 Y60:335 S40 ; Define mesh grid
          correct version and correct wording in config.g probe is unresponsive. a year of flawless performance under build 1.19.1 and now nothing.
          fcwiltundefined 2 Replies Last reply Reply Quote 0
          • Danalundefined
            Danal
            • fcwiltundefined
              fcwilt @sjason1377
              @sjason1377 said in Dave's so proud:
              M574 Z0
              The current docs for M558 report that the X, Y and Z parameters are obsolete.
              Perhaps that is causing some sort of problem?
                sjason1377 Banned
                I would never had upgraded except for those false heater faults he said was a bug from the old version. Now he's got no support for this problem because he won't admit there is one. That my issue. It take many failures from many user before he responds. History proves I was not at fault before. I'm not now either.
                  sjason1377 Banned
                  I'm not proud I'm not saying I have any answers. I know my spelling sucks. But I'm no liar. We depend on him to help with these issue. But where does that leave us when he won't help.
                  • botundefined
                    bot
                    Do you expect David to drop everything in his real life to help one of the rudest users ever to come on these boards?
                    You need to learn to be patient, and/or how to resolve issues yourself.
                    *not actually a robot
                    • Danalundefined
                      Danal
                      Ooops... just read the whole thread from the top.
                      BYE.
                      You want support from the community, you need a whole different attitude.
                      • fcwiltundefined
                        fcwilt @sjason1377
                        M574 Z0
                        Do you have a Z endstop in addition to the Z probe?
                        In the M574 Z0 there is no S parameter - which indicates an active high endstop - is that correct?
                          sjason1377 Banned
                          yes that's correct. I went back to p7 and it works now
                          fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            sjason1377 Banned @deckingman
                            @deckingman eat my load!
                            • fcwiltundefined
                              fcwilt @sjason1377
                              Did you try the latest version after removing the obsolete parameters from M558?
                              And you do have a Z endstop in addtion to the Z probe?
                                deckingman
                                @sjason1377 Thanks for this chat message
                                "hey decking eat my nut load bitch"
                                Like I said, I'd like to help you but only a qualified psychiatrist could do that.
                                  T3P3Tony administrators
                                  Following an email where I asked sjason1377 to stop abusing/attacking people on the forum he continued with this behaviour so I have banned him.
                                  1 Reply Last reply Reply Quote 5
                                    dc42 administrators @sjason1377
                                    From https://duet3d.dozuki.com/Wiki/Gcode:
                                    P5 (from RepRapFirmware 1.14) selects a switch by default (normally closed) for bed probing between the In and Gnd pins of the Z-probe connector (Duet 0.8.5 and Duet WiFi).
                                    P7 (from RepRapFirmware 1.20) selects a switch (by default normally closed) connected to the Z endstop input.
                                    P9 (from RepRapFirmware 1.21RC2) is as P5 but for a BLTouch probe that needs to be retracted and redeployed between probe points.
                                    So if P7 worked, he must have his BLTouch connected to the Z endstop input; whereas P9 requires it to be connected to the Z probe input.
                                    • fcwiltundefined
                                      fcwilt @dc42
                                      @dc42 said in [Dave's so proud]
                                      One thing I have noticed is that folks who are not good at attention to details often struggle with configuring 3D printers (and other things as well).
                                      Aside from the occasional mistake they we all make from time to time it is clear you very much know what you are doing.
                                      Thank you for your hard work, the Duet family of products has made building my printers so much easier and enjoyable.
                                      • dvmourikundefined
                                        dvmourik
                                        I think i can say i have some experience with Duet3D boards and Dave's software.
                                        For reference we produce printers from 3.5m tall and built more than enough of the smaller ones (60cm buildheight). All are using Dave's software. Never found a better supportive programmer than David!
                                        Ofcourse there are bugs. Tell him and he will try to fix it. Don't expect it next day, but believe me he will try his best!
                                        I see Jason is banned allready and that's good! If you don't know how much time is given by people for free! and are bashing them for it? Please leave...
                                        Guys we all have alot of respect for you! Keep up the great work!
                                        Bigger and bigger… sky is the limit.
                                        • Mikeundefined
                                          Mike
                                          That has quickly devolved into some weird drama, but for what it's worth... This level of entitlement and lack of gratitude is simply astounding. Duet forums are amazing as far as support goes. I haven't seen any big open source projects where the lead dev is so quick to respond and help users with very mundane problems. Not to mention that the whole project is very much alive, with constant firmware and hardware updates. And both are kept as open source as they can be. Simply amazing, hope you guys can keep it up.
                                          deckingmanundefined 1 Reply Last reply Reply Quote 4
                                            deckingman @Mike
                                            @mike It was just one individual. The one who started the thread and who behaved so badly that he ended up getting himself banned. No real drama.
