SOLVED - Help me solve some Z Banding
Common causes of Z banding include:
- Running the bed heater in bang-bang mode, which is the default until you tune it and save the new heater parameters.
- Leadscrew issues - in which case the banding will have the same pitch as the leadscrews.
@dc42 No bang bang here. It is PID tuned and stays within 1c of target. As for lead screws it does seem to match the 1mm pitch. But would that mean a bent lead screw? They appear to be straight when I roll them on a flat surface. What else could cause it?
Is the banding the Bulge, contract, bulge type, or the left, right left type? I mean if one side is banding out is the opposite side banding in or out at the same layer?
@phaedrux said in Help me solve some Z Banding:
Both ends of the z-screws were constrained on my machine but I was told by the vendor that I might want to leave the upper ends free.
It did seem to work better.
@t3p3tony it is definitely the bulge and contract type. Not left right wobble.
@fcwilt the lead screws are unattached at the top. Though when the bed is at Z0 the tops of the lead screws are even with the lead screw nuts. But the banding persists even when printing over 100mm when the tops of the lead screw would be exposed and free. Visually there doesn't appear to be able wobble in the lead screw as it rotates.
Try removing the wheels from the back corners. 4 wheels is an over constraint condition, liable to cause the bed to walk as it moves up and down. You really should only need the wheels at the corners closest to the leads screws that are on the right and left side in your first photo.
@mrehorstdmd I'll give it a shot.
@mrehorstdmd said in Help me solve some Z Banding:
Just to check if that was not lost in translation for me (and @Phaedrux already understood what you said anyway) and I am curious: are you proposing that on the backside the bed will only be "held up" by the leadscrew and otherwise kind of cantilevered mount only on the front side where the two leadscrews are?
@wilriker said in Help me solve some Z Banding:
No I don;t think that is what is being proposed. The bed will be held up by all three screws and 3 point define a plane, so it will stay level. If I understand correctly, Mark is saying (correctly in my opinion) that you only need 2 linear guides to constrain any side to side movement. 4 is overkill and there is a risk of binding if they aren't all perfectly aligned.
@phaedrux Given the problems you've had in the past with your OpenBuild wheels, are they all free to rotate? No flats like you've had in the past? Not over tightened the eccentric spacers by any chance?
@wilriker yes, like a cantilever with an extra screw to hold up the free, bouncy edge.
@deckingman said in Help me solve some Z Banding:
That's the first thing I checked. Some of the Z axis wheel bearings were indeed failing and leaking lubricant similar to the ones I found on the X and Y axis. However even after switching them back to working delrin wheels and bearings there was no difference.
I should also make clear that the polycarbonate and delrin V slot wheels were not OpenBuilds. They are from Xinlong Factory on AliExpress. I have some OpenBuilds V wheel bearings on the way though. Even with the bad bearings the movement was smooth by hand.
@mrehorstdmd I understand the overconstraint situation, but with everything aligned and properly tensioned the motion is very smooth and low friction. But I will definitely give the 2 wheel solution a try later today.
Thanks for the feedback.
It only takes a few 10s of um of error to create a visible defect in the print, which is why chasing this sort of problem is so difficult. You can't see what's causes the defect, so you have to use your imagination, test and test and test until you find/fix the problem.
@mrehorstdmd Well I got a chance to remove the back wheels and test again. No difference.
My replacement pulleys, belt, pillow blocks and bearings have arrived though, so I'll see if that helps at all. Unfortunately the pillow blocks I received KFL08 and KP08 have very poorly inserted bearings. I've tried tapping them straight but it seems to be a losing battle. So I think I'll stick to the printed bearing blocks for now.
Now I'm thinking that I should have just ordered some replacement lead screws as well and just change everything out at once, rather than do all the disassembly and assembly again if this doesn't work. I was foolish and wanted to save $22.
The openbuilds pulleys measure almost perfectly round to within 0.01mm. That's far better than the pulleys I had before, so that's promising. The 1534mm continuous loop GT2 belt from openbuilds seems to be of better quality as well. The previous belt seemed to have a bit of an odd cut angle to it. The new one has a flat cut edge and the teeth seem more pronounced. It also has the same texture and appearance to the genuine Gates belts I have. Though they don't have a stamp to indicate they are actually Gates belts. The new bearings are also higher quality. Completely silent and smooth and just feel more solid.
Really hoping this does it.
I fixed it!! It took a better part of the day to tear it down and build it back up but at least now I can print without being ashamed of the quality.
Left is before, right is after. Same gcode.I did a complete realignment of the bearing blocks and bed mounts to make sure they were lined up. I also tightened up the V wheel tensioners on all 4 corners and ensured that the bed raised and lowered smoothly and evenly by hand. Plus I replaced the 40T lead screw and drive pulleys with new ones from OpenBuilds. This time using a 20T drive pulley giving me a 2:1 gear ratio. The belt was also replaced. The cheap toothless flanged idler pulleys on the belt tensioner were replaced with flanged 605 bearings which ran much smoother and didn't rub the belt like the old idler did.
I don't know if it was just one or all of those things, but the banding is completely gone. I suspect that the biggest issue was the pulleys. There was visible wobble and movement with the old ones. That's all gone now. It's hard to put a finger on it, but visually the quality of the belt movement just looks better than before.
Thanks everyone for the suggestions.
