Running Bed Mesh Compensation
3.8k
    Billsrf @dc42
    @dc42 here is the M122 report0_1535484057809_M122 Report.txt
    www.dpp3d.com , pellet fed large format 3d printers
      Billsrf @dc42
      @dc42 any luck?
        The report indicates output buffer overflow and starvation. Please try firmware 2.01 or 2.02beta1, which include fixes to avoid this situation.
        undefined 2 Replies Last reply 30 Aug 2018, 15:03 Reply Quote 0
          Billsrf @dc42
          @dc42 I uploaded the latest firm ware and still the same issue
            Billsrf @dc42
            @dc42 I am using 1.22.1 with the Duet2combinedfirmware.bin
            undefined 1 Reply Last reply 30 Aug 2018, 16:10 Reply Quote 0
              dc42 administrators @Billsrf
              @billsrf said in Running Bed Mesh Compensation:
              Latest firmware for Duet WiFi/Ethernet is 2.01, or 2.02beta1. Perhaps the 1.22.1 number you reported is the Duet Web Control version? Send M115 to check the firmware version.
              undefined 1 Reply Last reply 31 Aug 2018, 13:40 Reply Quote 0
                Billsrf @dc42
                  So you are actually running firmware version 1.21. I suspect that you have a very old version of iap4e.bin in /sys on the SD card. Try uploading the version from https://github.com/dc42/RepRapFirmware/releases/tag/2.0, then try upgrading the firmware again.
                  undefined 2 Replies Last reply 31 Aug 2018, 15:01 Reply Quote 0
                    Billsrf @dc42
                    @dc42 ok thank you
                      Billsrf @dc42
                      @dc42 uploaded the iap4e as you suggested. Nothing changed, still disconnects from wifi and only does the corner from 0-570Y, 0-570X
                      undefined 1 Reply Last reply 5 Sept 2018, 15:04 Reply Quote 0
                        @billsrf, after uploading iap4e you need to upload the new firmware again. Then check the firmware version again to see if it has been upgraded.
                        undefined 3 Replies Last reply 5 Sept 2018, 21:04 Reply Quote 0
                          Billsrf @dc42
                          @dc42 will do
                            Billsrf @dc42
                            @dc42 did as you suggested, it now stays connected to wifi but I'm still only getting 1/4th of the table probed. Here is what it is telling me.0_1536240398551_Screen Capture.png
                              Billsrf @dc42
                              @dc42 Oh, it never tries to go to the other points
                                Here's your problem
                                G31 P500 X570 Y570 Z2.25 ; Set Z probe trigger value, offset and trigger height
                                From your config.g your G31 command has crazy values for X and Y offsets. They should be the distance from your nozzle tip to the probe tip. Mesh compensation is skipping those points because it thinks it can't move the probe there because it thinks it's 570mm away from your nozzle.
                                undefined 1 Reply Last reply 6 Sept 2018, 18:57 Reply Quote 0
                                  Billsrf @Phaedrux
                                  @phaedrux that fixed it! Thank you so much!!!
                                  undefined 1 Reply Last reply 6 Sept 2018, 19:28 Reply Quote 0
                                    Phaedrux Moderator @Billsrf
                                    @billsrf Glad it's sorted out.
                                    32 out of 39
