Duet Wifi went Bang on first startup
1.3k
    mmoram
    Hi There,
    Not sure if anyone can help, but just purchased my New Duet Wifi. Ive set it up via my computer, all working fine. Installed it on my E3D Bigbox. Turned it back on, and the board went bang and a chip on the board caught fire. As excepted the board now doesnt work and if i plug it back into the computer it doesnt see it and comes up with an USB error. The PanelDue also doesnt come on as well when plugged into the Duet, and works fine via the micro USB but doesnt connect.
    Please Help
      elmoret
      Which chip? Picture?
      My money's on 24v getting fed into the 3.3v rail.
        mmoram
        No sure, theres not much of it left, Its small square chip close to the fan inputs and the jumpers infront of them.
          elmoret
          Sounds like U2, which is the Vin -> 3.3v regulator. It goes bang when backfed 24v on the 3.3v rail. Most likely the rest of the board is non-functional now, as all the 3.3v parts have been fed 24v.
            mmoram
            I cant see the component number for the chip, but its very close to U3, if that helps
              fcwilt
              Sorry to hear you fried your Duet.
              It really helps to be a little OCD when wiring up things like the Duet.
              I don't double check my connections, I triple check them, sometimes more.
              And then I check them all again. 🙂
                mmoram
                Thats the frustrating thing I did double/triple check the wiring, this is the problem, i cant see where i went wrong, everything looked correct
                undefined 1 Reply Last reply 6 Sept 2018, 18:15 Reply Quote 0
                  elmoret
                  If you post some photos of your wiring/setup, might be able to spot something.
                  A possible cause is +24v getting into the heaterblock, and the heaterblock touching the IR sensor (which is on the 3.3v rail).
                    fcwilt @mmoram
                    @mmoram said in Duet Wifi went Bang on first startup:
                    As suggested post some photos. It is likely that there is a wiring error OR perhaps a short.
                    Anything on the underside of the board that could have shorted something?
                    undefined 1 Reply Last reply 7 Sept 2018, 15:02 Reply Quote 0
                      I'm sorry to hear that your board has failed. Please post a photo of the damage so that I can identify which chip has failed.
                      undefined 2 Replies Last reply 7 Sept 2018, 08:45 Reply Quote 0
                        mmoram @dc42
                        @dc42 Yes not a problem, ill send over some photos this afternoon after i finish work, Thankyou
                          mmoram @fcwilt
                          @fcwilt Hi There
                          Here are the photos, hopefully you will be able to see if ive wired it wrong, but i think everything is correct. The board is also on 10mmplastic standoff son that nothing can short out the underneath.0_1536332333988_IMG_1634.JPG 0_1536332418386_IMG_1635.JPG 0_1536332487067_IMG_1636.JPG
                            mmoram @dc42
                            @dc42 Hi There
                              Thanks. I don't think that failure was caused by your wiring. Please ask for your Duet to be replaced under warranty, referencing this thread. See https://www.duet3d.com/warranty.
                              undefined 1 Reply Last reply 7 Sept 2018, 15:16 Reply Quote 0
                                mmoram @dc42
                                @dc42 OK, thankyou, i purchased the board through E3D so will i need to contact them instead, or can i go through you on this occassion
                                undefined 1 Reply Last reply 7 Sept 2018, 16:28 Reply Quote 0
                                  T3P3Tony administrators @mmoram
                                  @mmoram please go through e3d.
                                  8 out of 16
