    Multi color printing with Prusa's MMU V2 & Duet?
    91
    23.1k
    • bartolomeusundefined
      bartolomeus @resam
      Small reference on github: https://github.com/prusa3d/Arduino_Boards/blob/master/IDE_Board_Manager/package_prusa3d_index.json
      But, maybe possible to use without prusa's board? Just directly connect to Duet and just use the mechanics?
      • Cataundefined
        Cata
        Any here buy the mmu2 and plans to use without the original prusa?
        • BenDieselundefined
          BenDiesel
          Looks like prusa released a promotion video
          https://youtu.be/E1ZxTCApLrs
          • Red Sand Robotundefined
            Red Sand Robot
            Also interested in (eventually) trying to get this to work with my cartesian printer for use with dissolvible support material, anyone find out any more info on how it would be possible to get it working with the Duet?
            almost an engineer
            • fmaundefined
              fma
              Look at the main board sources:
              https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.4.0-RC2
              there are 2 files, mmu.h and mmu.cpp which handle the com with the MMU board. Looks like they use a serial port.
              I guess it is possible to include support in the Duet? It would require to use the PanelDue connector...
              Frédéric
                bartolomeus
                Wouldn't it be easier to just plug the steppers into a duex expansion board and write some custom macro's? That way you don't need prusa's electronics.
                • fmaundefined
                  fma
                  Yes. As David said, this solution can be implemented without any modifications. But you will loose some features, like checking if the filament is correctly engaged (with the switch made from a metal ball and inductive sensor) or so. And no feedback at all: if it jams, the Duet won't be noticed, and will continue to print...
                  Frédéric
                  bartolomeusundefined 1 Reply Last reply Reply Quote 0
                    bartolomeus @fma
                    @fma couldn't you plug that sensor in the duet?
                    • fmaundefined
                      fma
                      Yes, but how to manage it? There is not condition testing in G-Codes...
                      Frédéric
                      • fmaundefined
                        fma
                        A good point in this MMU v2 is the non Bowden configuration: the multiplexer is only used to load/unload filaments to the extruder.
                        I'm wondering if we could use it without the carriage selector, and use the passive splitter of the v1? This would need more tubes between the unit and the extruder, but it would be much faster to switch from one filament to another, and reduce the chance of jamming (at the input of the carriage)?
                        And the Duet integration would be much easier.
                        What do you think?
                        Frédéric
                          Phaedrux Moderator @fma
                          @fma I think part of the multi color precision of the v2 comes from being direct drive versus bowden. So there's that.
                          I'm not sure you need conditional gcode and variables to make it work... couldn't it be scripted with macros as they are?
                          Even so, conditional gcode is being hinted at for the near future, so maybe it won't be long to wait.
                          fmaundefined 1 Reply Last reply Reply Quote 0
                          • fmaundefined
                            fma @Phaedrux
                            @phaedrux said in Multi color printing with Prusa's MMU V2 & Duet?:
                            My suggestion does not change that point: the MMU is still used to load/unload filament, extruder remaining on the printer carriage. But instead of having the moving selector, and only 1 PTFE tube, there is n PTFE tubes, and a splitter n-to-1 above the extruder.
                            That's good news!
                            Frédéric
                              bartolomeus
                              Firmware for the MMU board has been published, as also the schematics of the board.
                              Looking at the slic3r profiles, there is a 'ramming' function. Apparantly this is to retract filament with a clean cone and no strings to avoid jamming.
                              • fmaundefined
                                fma
                                Great!
                                Does anyone understand how 'ramming' params work?
                                Frédéric
                                  bartolomeus
                                  Regarding conditionals, couldn't something like this be used with the filament sensor of the MMU: https://reprap.org/wiki/G-code#M226:_Wait_for_pin_state
                                  or: https://reprap.org/wiki/G-code#M577:_Wait_until_endstop_is_triggered
                                  or: https://reprap.org/wiki/G-code#M583:_Wait_for_pin
                                  • fmaundefined
                                    fma
                                    Yes, but what if the input is never triggered?
                                    Frédéric
                                      bartolomeus @fma
                                      @fma why would the sensor not be triggered?
                                      • fmaundefined
                                        fma
                                        If case the filament does not engage correctly in the carriage, because of melted end (blob).
                                        Frédéric
                                          bartolomeus
                                          I guess that's why 'ramming' needs to be tuned properly.
                                          Anyway, with those available gcodes should it not be possible to write some custom macro's?
                                          • fmaundefined
                                            fma
                                            Yes, sure! This is simple motors, so a couple of G1 commands should do the job. And the carriage needs to be homed.
                                            Frédéric
