    [not yet solved] Tevo Little Monster DuetWifi errors
    My Duet controlled machine
    10
    140
    21.7k
    • giostarkundefined
      giostark
      Phaedrux ,
      I have read all the document you have linked. And for what i can see the data should be coherent.
      The section where with the G91 command (for allow to move independent axis) to check if the motor work properly , is executed without errors. The motors seems work all fine.
      If i move down the x axis G1 S2 X-10 it go down and vice-versa if I move up the x with G1 S2 X10 it go up. the other two axis go fine.
      I don't know if is a Slicer problem. Im using Simplify3D with settings i used with the original Tevo . I just changed the firmware section for add the RepRap configuration be loaded.
      Then....
      in the homedelta.g there is this line:
      ; Move all towers to the high end stopping at the endstops (first pass)
      G1 X505 Y505 Z505 F1800 S1
      and in the config.g there is this one:
      M665 R155 L397.19 B155 H525 ; Set delta radius, diagonal rod length, printable radius and homed height
      The 505 above should be far height than that?
      In the kossel example with an height of 240mm volume the G1 command is settled on 320. If my printer have an height of volume of 525 how much i should add to 505?
      ; homedelta.g
      ; called to home all towers on a delta printer
      ; generated by RepRapFirmware Configuration Tool on Mon May 22 2017 22:56:20 GMT-0400 (Eastern Daylight Time)
      ; Use relative positioning
      G91
      ; Go down a few mm
      G1 X-5 Y-5 Z-5 F1800 S2
      ; Move all towers up once more (second pass)
      G1 X10 Y10 Z10 F360 S1
      ; Move down a few mm so that the nozzle can be centred
      G1 Z-5 F6000
      ; Switch back to absolute positioning and go to the centre
      G90
      G1 X0 Y0 F6000
      • giostarkundefined
        giostark
        Nothing to do , also Cura (last version) produce the same thing.
        The printer dont rise during printing on the Z axis. Stay on the same level all the time and the gear of the extruder consume the filament in same place blocking further extrusions.
        Suggestions?
        tnx
          It's just odd that the motors will move properly when commanded manually but not when printing. Can you verify the motor current while printing? Send M906 and then M913 without parameters in the console and it will report what the current is set to along with any percentage scaling. Maybe there is a rogue current reduction command happening somewhere.
          • giostarkundefined
            giostark
            M906
            Motor current (mA) - X:1800, Y:1800, Z:1800, E:1800:1800:1800:1800:1800:1800:1800:1800:1800, idle factor 30%
            M913
            Motor current % of normal - X:100, Y:100, Z:100, E💯100💯100💯100💯100:100
            I tried different voltages for the 4 motors. Are all identical and the default should be 1.8.
            I tried also 1200 and 1000. Nothing change.
            I tried also the firmware 2.0 but didnt work either. Exactly same attitude as the 2.01.
            The probe is settled well ,it perform a good calibration without errors reporting the graph of the surface. Of course not rising the z axis during the print generate a mess of plastic under the extruder.
            Im starting to feel a little sad...
            There is something that can inhibit the Z axis rising during the printing?
            • Dougal1957undefined
              Dougal1957 @giostark
              @giostark can you post the code file you are trying to print
              • giostarkundefined
                giostark
                0_1537811866488_stab.gcode
                0_1537812126970_Tevo_LM_Duet_Adapter_v1.gcode
                Maybe those files and setting are not perfect but the first (stab) with the original motherboard was printed several time.
                Im able to perform a "good" calibration without errors. For this reason I dont think is something related to the hardware. I settled the zprobe and the first layer is printed well. the second one come printed on the 1st and so on generating a mess of plastic.
                  This post is deleted!
                    Well I notice 2 things from your gcode file. First, you don't have a G28 in there to home the printer, so if it isnt already homed when you start the print it may cause problems. Second, your Z moves are all negative.
                    Dougal1957undefined 1 Reply Last reply Reply Quote 1
                    • giostarkundefined
                      giostark
                      My actual config.g:
                      Config.g
                      ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
                      ; generated by RepRapFirmware Configuration Tool on Sat Jul 07 2018 15:37:48 GMT-0700 (Pacific Daylight Time)
                      G21 ; Work in millimetres
                      ;M555 P2 ; Set firmware compatibility to look like Marlin
                      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
                      M665 R157 L397.1073 B175 H523 ; Set delta radius, diagonal rod length, printable radius and homed height
                      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
                      M550 PTEVO Little Monster ; Set machine name
                      M552 S1
                      G4 P1000
                      M587 S"----------" P"-----------"
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      ; Drives original ones with 1.8 degree
                      M92 X80 Y80 Z80 E425 ; Set steps per mm
                      M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
                      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
                      M906 X1800 Y1800 Z1800 E1800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 Z0 S1 ; Set minimum Z
                      M574 X2 Y2 Z2 S1 ; Set active high endstops
                      M557 R130 S20 ; Define mesh grid
                      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                      M558 P9 H5 F100 T2000 A5 R0.1 ; P9 for BLTouch, dive height 5mm, probe at 100mm/min, travel 6000mm/min, up to 5 probes, pause 0.1s
                      G31 X0 Y20 Z0 P25 ; Set Z probe trigger value, offset and trigger height
                      M557 R150 S45 ; Define mesh grid
                      M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                      M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M106 P2 S1 I0 F500 H0 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      M563 P0 D0 H1 ; Define tool 0
                      ; Automatic power saving
                      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                      ; Custom settings
                      M591 D0 C3 P2 E6.0
                      ; Filament Sensor - Add the following to config file anywhere before the M501 command
                      M591 D0 P1 C4 R20 ; configure extruder drive 0 to use E1 endstop (C4) with 20% tolerance
                      M591 D0 ; display filament sensor parameters for extruder drive 0
                      M501 ; Load saved parameters from non-volatile memory
                      ; deployprobe.g
                      ; called to deploy a physical Z probe
                      ;M280 P3 S160 I1
                      M280 P3 S10 I1
                      ; retractprobe.g
                      ; called to retract a physical Z probe
                      M280 P3 S90 I1
                      • giostarkundefined
                        giostark
                        Now every time I start a print I put the head in home by hand. Ill fix it.
                        Sorry , what you mean negative? and where? How should I set them properly ?
                          Dougal1957 @Phaedrux
                          @phaedrux the file I have checked have no Z Moves at all in fact the only Z character is at the start to zero the extruder no wonder everything is printed on top of each other it is as if the layer height has been set to 0
                          giostarkundefined 1 Reply Last reply Reply Quote 1
                            I was looking at the stab.gcode.
                            • giostarkundefined
                              giostark @Phaedrux
                              @phaedrux said in [help] Tevo Little Monster + DuetWiFi + DuetTouch7" errors:
                              Ah...ok
                              So what do you would insert as start script?
                              • giostarkundefined
                                giostark @Dougal1957
                                @dougal1957 said in [help] Tevo Little Monster + DuetWiFi + DuetTouch7" errors:
                                Ok im facing with all my ignorance...so do you mean the same as Phaedrux?
                                  Phaedrux Moderator @giostark
                                  @giostark at the minimum just g28
                                  Can you post some screen shots of your slicer configuration?
                                    Dougal1957
                                    I'll look at that next mine was the tevo_lm one
                                      Dougal1957
                                      the first one I looked at was cura the stab was S3d
                                      • giostarkundefined
                                        giostark @Phaedrux
                                        Sure...
                                        Those files come from the web...are not mine.
                                        The tab not reported are not configured (all unchecked)
                                        About the start and end script:
                                        Start: empty...i dont know is appropriate for the duetwifi
                                        end:
                                        M104 S0 ;extruder heater off
                                        M140 S0 ;heated bed heater off (if you have it)
                                        G91 ;relative positioning
                                        M83 ; RELATIVE EXTRUSION
                                        G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
                                        G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
                                        G28 ;move to endstops
                                        M84 ;steppers off
                                        G90 ;absolute positioning
                                        M82 ; RESTORE ABSOLUTE EXTRUSION
                                          Dougal1957
                                          OK if you downloaded the Code files from the web then I would discount them totally and work with raw STL files and slice them and see what you get
                                            Dougal1957
                                            Maybe start with a simple cube printed in vase mode or such you will soon see whats happening without wasting to much filament/time
