    [not yet solved] Tevo Little Monster DuetWifi errors
    My Duet controlled machine
    10
    140
    21.7k
    • giostarkundefined
      giostark
      My actual config.g:
      Config.g
      ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
      ; generated by RepRapFirmware Configuration Tool on Sat Jul 07 2018 15:37:48 GMT-0700 (Pacific Daylight Time)
      G21 ; Work in millimetres
      ;M555 P2 ; Set firmware compatibility to look like Marlin
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R157 L397.1073 B175 H523 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M550 PTEVO Little Monster ; Set machine name
      M552 S1
      G4 P1000
      M587 S"----------" P"-----------"
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ; Drives original ones with 1.8 degree
      M92 X80 Y80 Z80 E425 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1800 E1800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M557 R130 S20 ; Define mesh grid
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F100 T2000 A5 R0.1 ; P9 for BLTouch, dive height 5mm, probe at 100mm/min, travel 6000mm/min, up to 5 probes, pause 0.1s
      G31 X0 Y20 Z0 P25 ; Set Z probe trigger value, offset and trigger height
      M557 R150 S45 ; Define mesh grid
      M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H0 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ; Custom settings
      M591 D0 C3 P2 E6.0
      ; Filament Sensor - Add the following to config file anywhere before the M501 command
      M591 D0 P1 C4 R20 ; configure extruder drive 0 to use E1 endstop (C4) with 20% tolerance
      M591 D0 ; display filament sensor parameters for extruder drive 0
      M501 ; Load saved parameters from non-volatile memory
      ; deployprobe.g
      ; called to deploy a physical Z probe
      ;M280 P3 S160 I1
      M280 P3 S10 I1
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P3 S90 I1
      • giostarkundefined
        giostark
        Now every time I start a print I put the head in home by hand. Ill fix it.
        Sorry , what you mean negative? and where? How should I set them properly ?
        • Dougal1957undefined
          Dougal1957 @Phaedrux
          @phaedrux the file I have checked have no Z Moves at all in fact the only Z character is at the start to zero the extruder no wonder everything is printed on top of each other it is as if the layer height has been set to 0
          giostarkundefined 1 Reply Last reply Reply Quote 1
            I was looking at the stab.gcode.
            • giostarkundefined
              giostark @Phaedrux
              @phaedrux said in [help] Tevo Little Monster + DuetWiFi + DuetTouch7" errors:
              Ah...ok
              So what do you would insert as start script?
              • giostarkundefined
                giostark @Dougal1957
                @dougal1957 said in [help] Tevo Little Monster + DuetWiFi + DuetTouch7" errors:
                Ok im facing with all my ignorance...so do you mean the same as Phaedrux?
                  Phaedrux Moderator @giostark
                  @giostark at the minimum just g28
                  Can you post some screen shots of your slicer configuration?
                    Dougal1957
                    I'll look at that next mine was the tevo_lm one
                      Dougal1957
                      the first one I looked at was cura the stab was S3d
                      • giostarkundefined
                        giostark @Phaedrux
                        Sure...
                        Those files come from the web...are not mine.
                        The tab not reported are not configured (all unchecked)
                        About the start and end script:
                        Start: empty...i dont know is appropriate for the duetwifi
                        end:
                        M104 S0 ;extruder heater off
                        M140 S0 ;heated bed heater off (if you have it)
                        G91 ;relative positioning
                        M83 ; RELATIVE EXTRUSION
                        G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
                        G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
                        G28 ;move to endstops
                        M84 ;steppers off
                        G90 ;absolute positioning
                        M82 ; RESTORE ABSOLUTE EXTRUSION
                          Dougal1957
                          OK if you downloaded the Code files from the web then I would discount them totally and work with raw STL files and slice them and see what you get
                            Dougal1957
                            Maybe start with a simple cube printed in vase mode or such you will soon see whats happening without wasting to much filament/time
                            • giostarkundefined
                              giostark
                              0_1537814313478_stab.stl
                              0_1537814322221_Tevo_LM_Duet_Adapter_v1.stl
                              Thanks really ,
                              What I should insert as "start script" ?
                              The Z negative make sense if it stay always on the same layer...(the 1st lower)
                                Dougal1957
                                From what I have studied the code whoever did it has a large negative offset which could account for it looking that way but it does seem to increment by 0.2 each layer but if you start at - 0.5 wish then it is doomed to failure if you need to start at 0.1 say I think you need to forget downloading other peoples gcode and start from your own
                                • giostarkundefined
                                  @dougal1957
                                  So the fact that the print dont rise on the Z axis depend on the slicer?
                                  Those settings work before with the original mobo. With this duetWifi not.
                                  Probably because are completely different hardware and software.
                                  In any case if someone can suggest the starting script or something for avoid the negative Z should be really useful 🙂
                                  I found the cube... I'll try some test...
                                  https://www.thingiverse.com/thing:38108/files
                                    @giostark Delta's aren't really my thing so maybe @Dougal1957 can tell you more specifically what to put in your start script but at the very least you need to home the printer. The slicer will handle the temperatures.
                                    • giostarkundefined
                                      giostark
                                      Nothing to do. Nor the cube , nor the stab.
                                      The same mess. I tried to print from S3d via usb and I have seen Z negative all the time and positive just when retracting....
                                      • giostarkundefined
                                        giostark
                                        Hi there...i was close to give up. But ! I tried Matter control and it seems to make rise the head as it should be (via usb). It use the Matter Slice slicer embedded in it. I could try also with the cura engine and SD variant and report if it work.
                                        The phenomenon that now happen is strange (but probably common for you "expert") , the printer print the fist few layer(in real i dont understand well when the material is posed) than it seems that the extruder block it self and consume the filament in the same place. Is like the extrusion and retraction didnt work regularly.
                                        Of course if i try the extruder by it self it work well. Also the retraction work well.
                                        Im printing ABS with nozzle at 250 and glass bed at 110. (are working settings with the past configuration). Fan 0%.
                                        Just in case . Can you suggest a good extruder for my tevo? Any hardware upgrade is well accepted. The link on the guide is broken. It seems that is no more available the extruder suggested. https://www.bondtech.se/en/product-category/extruders/
                                        Maybe the nozzle? A titan original one?
                                        If you need more info just ask thanks
                                        At the end of this I'll make a summary that can be useful for other ...
                                        • giostarkundefined
                                          giostark
                                          Progress , I'll update with all the necessary info and Ill' open a new 3ds.
                                          I calibrated the extruder (steps for mm and multiplier) . The MatterControl seems to work for rising the Z axis.
                                          Also , I still continue to have trouble with consumed filament . I suppose is because a wrong setting in retraction but i have to still figure it out if is retraction or something else.
                                          Just because i followed this howto and the settings should be fine, the culprit can be in the fist layer too close the bed....
                                          Im looking for this howto that explain the cause of this "bite" on the filament:
                                          https://airwolf3d.com/3d-printing-tips/mouse-bite/
                                          https://www.matterhackers.com/articles/retraction-just-say-no-to-oozing0_1538080534437_20180927_195744.jpg
                                            @giostark There are a few reasons it could be grinding into the filament like that.
                                            • e steps not calibrated properly and it's trying to over extrude too much and it can't push the filament out fast enough
                                            • trying to extrude at too low a temperature perhaps because the thermistor is reading too low
                                            • extruder tensioner arm is too tight or too loose
                                            • Nozzle too close to the surface to extrude properly
