    Creality CR-10 upgrade
    252
    54.0k
      Version 2.01 is the last stable release if you'd like to try.
      Do you have more info about the bed switching off? Was there a heater fault?
        dc42 administrators @Agniusm
        @agniusm said in Creality CR-10 upgrade:
        I just read on another chaps rant that you dont support RC releases so perhaps i have upgraded too far up and some issues i am having are to do with that.
        That applies to beta and RC releases that have been superseded by a stable release. I do support users running the latest beta or RC release, and your feedback on them is very valuable.
        • Agniusmundefined
          Agniusm @tjb1
          @tjb1 it was working fine untill upgrade of the firmware. Maybe there is something new like with homing gcodes and s2's
          P.S. all is good regarding bed heater. When updating i uncommented so i dont have to way for the bed while doing test prints.
          Discard this
          • Agniusmundefined
            Agniusm
            Filament sensor did not work, was missing again S parameter. Is there a list of changes done to 1.21 as i just wasted a spool of filament.
            Also, i looks like it does not apply mesh map when printing. Do i have something wrong?:
            ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
            ; generated by RepRapFirmware Configuration Tool on Sat Nov 11 2017 18:50:00 GMT+0200 (FLE Standard Time)
            M111 S0 ; Debugging off
            G21 ; Work in millimetres
            M555 P2 ; Set firmware compatibility to look like Marlin
            M584 X0 Y1 Z2:4 E3 P3 ; two Z motors connected to driver outputs 0, 1, 2 and 4
            M671 X-25:432 Y100:100 S5 ; leadscrews left and right
            M574 X1 Y1 Z0 S1 ; Define active low and unused microswitches
            M558 P4 I0 F300 X0 Y0 Z1 T7000 ;
            G31 P100 X17.73 Y-19.32 Z0.195 ; Z probe offset from the nozzle
            M557 X10:384 Y-20:370 S93.5 ; Define mesh grid 100
            M208 X407 Y417 Z350 S0 ; Set axis maxima
            M208 X-22 Y-12 Z0 S1 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
            M591 D0 P2 C4 S1 ; Filament runout
            ;M556 S79.95 X-0.1 Y0.5 Z0.55 ; Axes compensation
            M569 P0 S0 ; Drive 0 goes forwards
            M569 P2 S0 ; Drive 2 goes forwards
            M569 P3 S0 ; Drive 3 goes forwards
            M569 P4 S0 ; Drive 3 goes forwards
            M92 X80.03 Y80.22 Z402.43 E823.54 ; Set steps per mm X80.06 Y80.22
            M566 X380 Y380 Z12 E120 ; Set maximum instantaneous speed changes Jerk (mm/min) Z100
            M203 X12000 Y12000 Z1000 E1200 ; Set maximum speeds (mm/min) Z800
            M201 X1000 Y1000 Z1000 E9000; Set accelerations (mm/s^2) Z200
            M906 X1400 Y2800 Z1400 E1400 I20 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S10 ; Set idle timeout
            M143 S380 ; Set maximum hotend temperature to 380C
            M143 H0 S150 ; Set maximum bed temperature to 150C
            M307 H0 A202.7 C608.4 D3.0 B0 ; Use PID on bed heater
            M305 P1 X201 ; (PT100 thermocouple on channel 2)
            M563 P0 D0 H1 ; Define tool 0
            M550 PCreeX ; Set machine name
            M551 P ; Set password
            M552 S1 ; Enable network
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F500 H1 T40 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S0 I0 F500 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            ; M501 ; for tool offset
            • Agniusmundefined
              Agniusm
              You can see here at the back that nozzle is too low and next to it it prints almost alright.
              I have done gantry leveling and mesh compensation with 25 points and my plate is precision milled so it should not be that extreme.
                Do you use G29 S1 anywhere in your print start code to load the mesh grid compensation height map? You can add it to your config as well if you want it to be active always starting at power up.
                Can you post the image of the height map results?
                Agniusmundefined 1 Reply Last reply Reply Quote 0
                  The GitHub page for every release refers to https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md. Always read the upgrade notes for the release you are upgrading to and for any releases you have skipped.
                  • Agniusmundefined
                    Agniusm @Phaedrux
                    @phaedrux I use G29 alone so it probes before each print.
                    I will get the map posted as my printer is away
                    • Agniusmundefined
                      Agniusm
                      Can someone explane how to call macro file in start gcode? Asked this and still have no answer.
                      I am slicing with slic3r.
                      Putting:
                      M98 Pgantry_leveling.g
                      does not work.
                      Stephen6309undefined 1 Reply Last reply Reply Quote 0
                      • Stephen6309undefined
                        Stephen6309 @Agniusm
                        @agniusm You need to use the full path.
                        M98 P/macros/gantry_leveling.g
                        • Agniusmundefined
                          Agniusm
                          Thank you. And its not this path:
                          M98 P/sys/gantry_leveling.g ?
                            It depends on which folder you put the macro in. If you put it in /sys then you should not need to use the full path.
                            • Agniusmundefined
                              Agniusm
                              Had a chance to film my first layer.
                              Using Prusa 5V induction probe on precision aluminium plate.
                              Cant remember exact deviation on mesh map but its 0.07 max.
                              I am using gantry leveling as well.
                              I always get front right quarter of the bed too high. I am lost as dont know why it would not compensate. Those induction probes as per Tom's YT channel are ones of the most acurate ones.
                              If anyone could chime in and point my error?
                              https://youtu.be/ZjNbv5uATFE
                                Is there any other metalwork near the front right corner that might be affecting the inductive sensor?
                                • Agniusmundefined
                                  Agniusm
                                  There is none. Its uniform. It has y carriage on 4 rail blocks. Bed is 8mm thick on 10mm standoffs from y carriage. Those induction probes are less sensitive to aluminium and my z offset is at ~0.2mm.
                                  I know it should be far better than this.
                                  I have enders with those uneven chinese heated beds running pinda's and they do work very good. Layers are smooth like butter.
                                  I have a script where it parks hotend 60mm abobe the bed, blows part cooling fan full whack and heats the bed to print temp, then goes for mesh mapping.
                                    True; but they are much more sensitive to magnetic materials, such as non-stainless steel screws. They are also somewhat sensitive to temperature and supply voltage.
                                    • Agniusmundefined
                                      Agniusm
                                      There is no fluctuation from psu, unless dwc readouts are inacurate. I have no protruding bolts and all of my fittings are stainless exept for the frame but they are far away.
                                      I know that probes are sensitive to heat and thats why i have a script to move it out of the way while heating.
                                      Here is my bed and whats underneath:
                                      https://youtu.be/XLu0cw31nQE
                                      • Agniusmundefined
                                        Agniusm
                                        So i have checked and rechecked and M98 does not work.
                                        My macro file gantry_leveling.g is located in /Macros catalog and i place:
                                        It reports that file is not found. Was this function tested and confirmed working?
                                        Maybe there is syntax errors and rules that must be followed like space between P and path or CAP sensitive?
                                        • whosrdaddyundefined
                                          whosrdaddy
                                          M98 is known to work 🙂 but it is Case sensistive!
                                          did you try M98 Pgantry_leveling.g ?
                                            Do you have any other characters on that line after the final ".g" ?
                                            Are you certain that when you created the file, you didn't add an extra space after or before the filename?
                                            You can also try:
                                            M98 P"/macros/gantry_leveling.g"
                                            or:
                                            M98 P"gantry_leveling.g"
                                            whosrdaddyundefined 1 Reply Last reply Reply Quote 0
