    Creality CR-10 upgrade
    252
    54.1k
    • Agniusmundefined
      Agniusm
      Filament sensor did not work, was missing again S parameter. Is there a list of changes done to 1.21 as i just wasted a spool of filament.
      Also, i looks like it does not apply mesh map when printing. Do i have something wrong?:
      ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool on Sat Nov 11 2017 18:50:00 GMT+0200 (FLE Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P2 ; Set firmware compatibility to look like Marlin
      M584 X0 Y1 Z2:4 E3 P3 ; two Z motors connected to driver outputs 0, 1, 2 and 4
      M671 X-25:432 Y100:100 S5 ; leadscrews left and right
      M574 X1 Y1 Z0 S1 ; Define active low and unused microswitches
      M558 P4 I0 F300 X0 Y0 Z1 T7000 ;
      G31 P100 X17.73 Y-19.32 Z0.195 ; Z probe offset from the nozzle
      M557 X10:384 Y-20:370 S93.5 ; Define mesh grid 100
      M208 X407 Y417 Z350 S0 ; Set axis maxima
      M208 X-22 Y-12 Z0 S1 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
      M591 D0 P2 C4 S1 ; Filament runout
      ;M556 S79.95 X-0.1 Y0.5 Z0.55 ; Axes compensation
      M569 P0 S0 ; Drive 0 goes forwards
      M569 P2 S0 ; Drive 2 goes forwards
      M569 P3 S0 ; Drive 3 goes forwards
      M569 P4 S0 ; Drive 3 goes forwards
      M92 X80.03 Y80.22 Z402.43 E823.54 ; Set steps per mm X80.06 Y80.22
      M566 X380 Y380 Z12 E120 ; Set maximum instantaneous speed changes Jerk (mm/min) Z100
      M203 X12000 Y12000 Z1000 E1200 ; Set maximum speeds (mm/min) Z800
      M201 X1000 Y1000 Z1000 E9000; Set accelerations (mm/s^2) Z200
      M906 X1400 Y2800 Z1400 E1400 I20 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S10 ; Set idle timeout
      M143 S380 ; Set maximum hotend temperature to 380C
      M143 H0 S150 ; Set maximum bed temperature to 150C
      M307 H0 A202.7 C608.4 D3.0 B0 ; Use PID on bed heater
      M305 P1 X201 ; (PT100 thermocouple on channel 2)
      M563 P0 D0 H1 ; Define tool 0
      M550 PCreeX ; Set machine name
      M551 P ; Set password
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T40 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F500 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      ; M501 ; for tool offset
      • Agniusmundefined
        Agniusm
        You can see here at the back that nozzle is too low and next to it it prints almost alright.
        I have done gantry leveling and mesh compensation with 25 points and my plate is precision milled so it should not be that extreme.
          Do you use G29 S1 anywhere in your print start code to load the mesh grid compensation height map? You can add it to your config as well if you want it to be active always starting at power up.
          Can you post the image of the height map results?
          Agniusmundefined 1 Reply Last reply Reply Quote 0
            dc42 administrators @Agniusm
            @agniusm said in Creality CR-10 upgrade:
            The GitHub page for every release refers to https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md. Always read the upgrade notes for the release you are upgrading to and for any releases you have skipped.
            • Agniusmundefined
              Agniusm @Phaedrux
              @phaedrux I use G29 alone so it probes before each print.
              I will get the map posted as my printer is away
              • Agniusmundefined
                Agniusm
                Can someone explane how to call macro file in start gcode? Asked this and still have no answer.
                I am slicing with slic3r.
                Putting:
                M98 Pgantry_leveling.g
                does not work.
                Stephen6309undefined 1 Reply Last reply Reply Quote 0
                • Stephen6309undefined
                  Stephen6309 @Agniusm
                  @agniusm You need to use the full path.
                  M98 P/macros/gantry_leveling.g
                  • Agniusmundefined
                    Agniusm
                    Thank you. And its not this path:
                    M98 P/sys/gantry_leveling.g ?
                      It depends on which folder you put the macro in. If you put it in /sys then you should not need to use the full path.
                      • Agniusmundefined
                        Agniusm
                        Had a chance to film my first layer.
                        Using Prusa 5V induction probe on precision aluminium plate.
                        Cant remember exact deviation on mesh map but its 0.07 max.
                        I am using gantry leveling as well.
                        I always get front right quarter of the bed too high. I am lost as dont know why it would not compensate. Those induction probes as per Tom's YT channel are ones of the most acurate ones.
                        If anyone could chime in and point my error?
                        https://youtu.be/ZjNbv5uATFE
                          Is there any other metalwork near the front right corner that might be affecting the inductive sensor?
                          • Agniusmundefined
                            Agniusm
                            There is none. Its uniform. It has y carriage on 4 rail blocks. Bed is 8mm thick on 10mm standoffs from y carriage. Those induction probes are less sensitive to aluminium and my z offset is at ~0.2mm.
                            I know it should be far better than this.
                            I have enders with those uneven chinese heated beds running pinda's and they do work very good. Layers are smooth like butter.
                            I have a script where it parks hotend 60mm abobe the bed, blows part cooling fan full whack and heats the bed to print temp, then goes for mesh mapping.
                              True; but they are much more sensitive to magnetic materials, such as non-stainless steel screws. They are also somewhat sensitive to temperature and supply voltage.
                              • Agniusmundefined
                                Agniusm
                                There is no fluctuation from psu, unless dwc readouts are inacurate. I have no protruding bolts and all of my fittings are stainless exept for the frame but they are far away.
                                I know that probes are sensitive to heat and thats why i have a script to move it out of the way while heating.
                                Here is my bed and whats underneath:
                                https://youtu.be/XLu0cw31nQE
                                • Agniusmundefined
                                  Agniusm
                                  So i have checked and rechecked and M98 does not work.
                                  My macro file gantry_leveling.g is located in /Macros catalog and i place:
                                  It reports that file is not found. Was this function tested and confirmed working?
                                  Maybe there is syntax errors and rules that must be followed like space between P and path or CAP sensitive?
                                  • whosrdaddyundefined
                                    whosrdaddy
                                    M98 is known to work 🙂 but it is Case sensistive!
                                    did you try M98 Pgantry_leveling.g ?
                                      Do you have any other characters on that line after the final ".g" ?
                                      Are you certain that when you created the file, you didn't add an extra space after or before the filename?
                                      You can also try:
                                      M98 P"/macros/gantry_leveling.g"
                                      or:
                                      M98 P"gantry_leveling.g"
                                      whosrdaddyundefined 1 Reply Last reply Reply Quote 0
                                        whosrdaddy @dc42
                                        @dc42 : maybe update the wiki to reflect the fact that quotes are allowed for M98?
                                        • Agniusmundefined
                                          Agniusm
                                          OK, will try your suggestions. I guess my error will be with Case.
                                          I am sure i have no space after .g
                                          BTW, i think i have pinpointed my leveling issue.
                                          I have printed holders for Z motors and my right motor was getting hotter than left one to the point it melted plastic. I have ordered longer motors and some 50x50x5 aluminium angle to fabricate some brackets.
                                          I think it was just turning motor slightly so compensation was canceling out on melted saggy plastic.
                                          Wow, that took me some time to notice.
                                            Phaedrux Moderator @whosrdaddy
                                            @whosrdaddy In addition to knowing quotes are allowed it would be nice to know when they are required.
                                            Maybe I'm old school, but I always contain paths and strings in quotation marks. Especially if there is white space in it.
