    Ceramic hotend...?
    34
    4.2k
    • OBELIKSundefined
      OBELIKS
      I will post results, but it will take some time. I am not planning the switch in near future.
      P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
      Original Prusa i3 MK3S
        deckingman
        I looked into these some while back. What you see is an annular (hollow cylinder) heater around an aluminium block. The ceramic part is just the insulation. The heating element is just nichrome wire wrapped around a ceramic core. So in that respect, it's much like a conventional cartridge heater but annular in shape. Oh , and the two wires are for the heater - you still need a thermistor (at least I haven't seen one with integrated thermistor).
          dc42 administrators @gavatron3000
          @gavatron3000 said in Ceramic hotend...?:
          I'd imagine it'd be not very good due to ceramics being insulators
          Actually, there are some ceramics that are good thermal conductors. I know this because while I was doing my PhD I had to build some waveguide carbon dioxide lasers, and I needed a material that was a good thermal conductor and good electrical insulator. Beryllium oxide is one of the best, but highly toxic. Alumina is not as bad as you might think, it conducts heat about 30 times better than glass. For the lasers I settled on hexagonal boron nitride, which has a thermal conductivity about 600 times better than glass (more than aluminium) along the layers and 30 times better perpendicular to the layers.
          My guess is that ceramic hot ends are made from either alumina or hexagonal boron nitride. Both are white. Alumina is hard, hexagonal boron nitride is soft like graphite.
          • fmaundefined
            fma @OBELIKS
            @obeliks said in Ceramic hotend...?:
            @gavatron3000 They solved this by putting the thermistor in the nozzle.
            I drilled my FNU to insert the thermistor as TriangleLabs does with there nozzle... That's maybe why I can see the temperature dropping when I extrude fast: when thermistor is in the heater block, you don't see fast variations.
            Frédéric
            OBELIKSundefined 1 Reply Last reply Reply Quote 0
            • OBELIKSundefined
              OBELIKS @fma
              @fma That makes sense. Maybe that nozzle is a bit better since it is bigger than usual E3D
              • gavatron3000undefined
                gavatron3000
                Interesting! I had a general view on ceramics and didn't know that David. Ceramic wrapped heater I think would be good. I guess similar in a way to how e3d put a silicon sock onto the heater block.
                Always good to keep an open mind
                • fmaundefined
                  fma
                  As soon as I receive the part from Zatsit, I try their nozzle.
                  Frédéric
                  • themelleundefined
                    themelle @Pat
                    @pat Looks similar to the hotend design M3D use in their Micro printer range.
                    • warbunniesundefined
                      warbunnies
                      Just to clear up any misunderstanding about how well these things heat. The ceramic hotends heat up much faster than e3d hotends. Usually pass 200 after 30 seconds with the deltaprintr one. Though I wouldnt suggest using their mini hotend. Originally they said they would be coming up with different nozzle sizes & 3 years later, nothing. emailed them last year and they pretended not to know anything about it & had no plans to do it. But it was a very very good hotend for the period of time i used it. The heater is so strong that it seems to react much faster to changes than the normal heating method.
                      I've been trying to find a good source of ceramic heaters myself and hopefully they will catch on. The fast heating/ cooling time is great for tool changing.
                      deckingmanundefined fmaundefined 2 Replies Last reply Reply Quote 0
                        deckingman @warbunnies
                        @warbunnies said in Ceramic hotend...?:
                        Let me know if do find a source. I've been looking myself with not much luck.
                        warbunniesundefined 1 Reply Last reply Reply Quote 0
                          warbunnies @deckingman
                          @deckingman
                          I will let the world know! Good lord I want them to catch on. I'm probably gonna try making my own at some point. It is just nichrome & a non conductive, high heat material after all...
                          Alibaba seems to be the only place which kinda sucks cause i cannot buy bulk at the volume they want to make me custom parts.
                            @deckingman
                            Yup. Been down that road too.
                            My only slight concern is that if one fails, it'll be a bit of a pain to replace compared to a "normal" drop in cartridge. For what I have in mind, disassembly for the purpose of replacing an annular heater could be problematic, unless I change the design - the jury is still out on that.......
                              @deckingman
                              Okay ya that is a fair point. they are more delicate, proper wire constraint is a MUST. It could be offset by a good supplier. The heater itself isn't that expensive to make. Along with a good design of the metal parts. The nozzles need to be easier to remove & the temp sensor should be close to but not in the nozzle. Combine a decent design with that heater & you got a winning hotend.
                              • fmaundefined
                                fma @warbunnies
                                Are your talking about M3D micro-extruder? I'm very tempted to buy one with the Pro nozzle...
                                https://store.printm3d.com/collections/parts/products/micro-extruder-core-assembly
                                https://store.printm3d.com/collections/parts/products/pro-4mm-nozzle-assembly
                                Frédéric
                                  warbunnies @fma
                                  @fma
                                  Nope I'm talking about these: https://www.deltaprintr.com/product/mini-hotend/
                                  they even have a damn picture labled "micro nozzles coming soon" bunch of lies.
                                  • fmaundefined
                                    fma
                                    Ok, I see.
                                    Frédéric
                                    • fmaundefined
                                      fma
                                      How are these micro-hotends build, inside? Are they using PTFE? Are they made of 1 block from top to nozzle?
                                      Frédéric
                                        warbunnies @fma
                                        @fma
                                        they are a full metal. the ptfe stops up in the cold end. the nozzle & heatblock are separate. the ceramic heater encloses a metal core that threads into the heatbreak & the nozzle threads into the metal core.
                                        • fmaundefined
                                          fma
                                          Thanks for your answer.
                                          Frédéric
                                          • Danalundefined
                                            Danal
                                            Web skills MAY have nothing to do with product quality... but... very "high bling" web site... who's security certificate expired four days ago...
                                            Sigh.
