Ceramic hotend...?
34
4.2k
    Pat
    The ceramic ring is the heater, so i guess the time to reach the temp is at least the same or maybe even shorter.
    Way less mass to heat.
    undefined 1 Reply Last reply 15 Oct 2018, 11:09 Reply Quote 0
      gavatron3000
      Furnaces use ceramics so they don't lose heat to the environment. With a hotend you want a high thermal conductivity to keep the tip temperature accurate. Hence why the blocks are usually aluminium or copper.
      undefined 1 Reply Last reply 15 Oct 2018, 09:31 Reply Quote 0
        fma
        Correction: I only use the ceramic heater, not the nozzle... I may try it, though, as I have to order from them.
        Frédéric
          fma
          Looking closer, their nozzle does not seem to be in ceramic!
          Frédéric
            fma
            BTW, there is also this product, part of the all-in-one hotend: http://www.hotends.fr/fr/home/63-corps-de-chauffe-ae.html
            Frédéric
              OBELIKS @gavatron3000
              @gavatron3000 They solved this by putting the thermistor in the nozzle.
              For me it is an interesting design, so I am thinking to buy one, when I will switch to 24V
              P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
              Original Prusa i3 MK3S
              undefined undefined 2 Replies Last reply 15 Oct 2018, 09:32 Reply Quote 0
                gavatron3000 @OBELIKS
                @obeliks see how you go I'm interested to see your results
                  OBELIKS
                  I will post results, but it will take some time. I am not planning the switch in near future.
                    deckingman
                    I looked into these some while back. What you see is an annular (hollow cylinder) heater around an aluminium block. The ceramic part is just the insulation. The heating element is just nichrome wire wrapped around a ceramic core. So in that respect, it's much like a conventional cartridge heater but annular in shape. Oh , and the two wires are for the heater - you still need a thermistor (at least I haven't seen one with integrated thermistor).
                      dc42 administrators @gavatron3000
                      @gavatron3000 said in Ceramic hotend...?:
                      I'd imagine it'd be not very good due to ceramics being insulators
                      Actually, there are some ceramics that are good thermal conductors. I know this because while I was doing my PhD I had to build some waveguide carbon dioxide lasers, and I needed a material that was a good thermal conductor and good electrical insulator. Beryllium oxide is one of the best, but highly toxic. Alumina is not as bad as you might think, it conducts heat about 30 times better than glass. For the lasers I settled on hexagonal boron nitride, which has a thermal conductivity about 600 times better than glass (more than aluminium) along the layers and 30 times better perpendicular to the layers.
                      My guess is that ceramic hot ends are made from either alumina or hexagonal boron nitride. Both are white. Alumina is hard, hexagonal boron nitride is soft like graphite.
                        fma @OBELIKS
                        @obeliks said in Ceramic hotend...?:
                        I drilled my FNU to insert the thermistor as TriangleLabs does with there nozzle... That's maybe why I can see the temperature dropping when I extrude fast: when thermistor is in the heater block, you don't see fast variations.
                        Frédéric
                        undefined 1 Reply Last reply 15 Oct 2018, 10:32 Reply Quote 0
                          OBELIKS @fma
                          @fma That makes sense. Maybe that nozzle is a bit better since it is bigger than usual E3D
                            gavatron3000
                            Interesting! I had a general view on ceramics and didn't know that David. Ceramic wrapped heater I think would be good. I guess similar in a way to how e3d put a silicon sock onto the heater block.
                            Always good to keep an open mind
                              fma
                              As soon as I receive the part from Zatsit, I try their nozzle.
                              Frédéric
                                themelle @Pat
                                @pat Looks similar to the hotend design M3D use in their Micro printer range.
                                  warbunnies
                                  Just to clear up any misunderstanding about how well these things heat. The ceramic hotends heat up much faster than e3d hotends. Usually pass 200 after 30 seconds with the deltaprintr one. Though I wouldnt suggest using their mini hotend. Originally they said they would be coming up with different nozzle sizes & 3 years later, nothing. emailed them last year and they pretended not to know anything about it & had no plans to do it. But it was a very very good hotend for the period of time i used it. The heater is so strong that it seems to react much faster to changes than the normal heating method.
                                  I've been trying to find a good source of ceramic heaters myself and hopefully they will catch on. The fast heating/ cooling time is great for tool changing.
                                  undefined undefined 2 Replies Last reply 15 Oct 2018, 14:47 Reply Quote 0
                                    deckingman @warbunnies
                                    @warbunnies said in Ceramic hotend...?:
                                    Let me know if do find a source. I've been looking myself with not much luck.
                                    undefined 1 Reply Last reply 15 Oct 2018, 14:53 Reply Quote 0
                                      warbunnies @deckingman
                                      @deckingman
                                      I will let the world know! Good lord I want them to catch on. I'm probably gonna try making my own at some point. It is just nichrome & a non conductive, high heat material after all...
                                      Alibaba seems to be the only place which kinda sucks cause i cannot buy bulk at the volume they want to make me custom parts.
                                      undefined 1 Reply Last reply 15 Oct 2018, 15:18 Reply Quote 0
                                        @deckingman
                                        Yup. Been down that road too.
                                        My only slight concern is that if one fails, it'll be a bit of a pain to replace compared to a "normal" drop in cartridge. For what I have in mind, disassembly for the purpose of replacing an annular heater could be problematic, unless I change the design - the jury is still out on that.......
                                        undefined 1 Reply Last reply 15 Oct 2018, 15:27 Reply Quote 0
                                          @deckingman
                                          Okay ya that is a fair point. they are more delicate, proper wire constraint is a MUST. It could be offset by a good supplier. The heater itself isn't that expensive to make. Along with a good design of the metal parts. The nozzles need to be easier to remove & the temp sensor should be close to but not in the nozzle. Combine a decent design with that heater & you got a winning hotend.
                                          17 out of 34
