    Laser Filament Monitor - test results
    Filament Monitor
    16
    139
    21.7k
    • fmaundefined
      fma @brunofporto
      @brunofporto said in Laser Filament Monitor - test results:
      @fma Well.... That should work but then there is the issue of finding a paint or marker that does not add color, mess with filament properties or is chemically innert to most of them, is opaque to IR and worldwide available 😄
      I would like to make some tests, with different stuff. My idea is to use some sort of gear to put something at regular steps. What length of filament does sensor see? Just to design the gear pitch...
      Frédéric
        dc42 administrators @fma
        @fma said in Laser Filament Monitor - test results:
        My guess is not very much, because the laser spot should be small. Unfortunately the data sheet doesn't specify the beam divergence. It does say that the distance between the sensor and the target should be at least 3mm to get maximum resolution.
        • fmaundefined
          fma
          Ok, thanks. I'll try to make a small pitch...
          Frédéric
          • Snypesundefined
            Snypes
            This post is deleted!
            • Snypesundefined
              Snypes
              Has anyone considered uncoupling the filament from the laser and having the laser read a constant metallic surface for example (much like an idler bearing maybe?)?
              That's pretty much the solution used by jtx on his skelestruder and it would at least allow all filaments to be calibrated against a constant....
              https://www.thingiverse.com/thing:3091625
              • kraegarundefined
                kraegar
                I may have a new "least accurate filament" - Atomic Marble PLA
                Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -1.1, brightness 96, shutter 17, measured minimum 12%, average 71%, maximum 167% over 92403.1mm
                T3P3Tonyundefined Alexander Mundyundefined 2 Replies Last reply Reply Quote 0
                • brunofportoundefined
                  brunofporto
                  I do also compare the slicer predicted filament usage with the measures filament usage and have a very unusual inverse relation where the ones with the worst reading % also have the most accurate measurement of total filament usage!
                    T3P3Tony administrators @kraegar
                    @kraegar wow. so opaque to visible light but possibly not to IR...? strangely bad!
                      T3P3Tony administrators @Snypes
                      @snypes well the magnetic monitor does that and if we add that complexity then it's easier to use the hall sensor than the laser
                        brunofporto
                        How can I register the readings of the entire print instead of max, min and avg?
                        I would like to see the full information, alongside retract and extrusion commands.
                        then I will be able to really visualize skipping/clogging effects and separate them from the "normal flow" average and deviation to better tune the thresholds.
                          T3P3Tony administrators @brunofporto
                          @brunofporto thats not a function in the firmware right now. the documentation:
                          https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_LaserVersion
                          explains the protocol used however it would need to be a firmware feature request to have some way of logging/outputting this information. When the filament is detected as moving there is a movement data packet sent ever 40ms, fair bit of information to handle.
                          brunofportoundefined 1 Reply Last reply Reply Quote 0
                            brunofporto @T3P3Tony
                            @t3p3tony
                            Would hurt the duet's processor asks a lot of M591 and log with M929? I mean, it is possible to use these commands to register the readings over time?
                            • Alexander Mundyundefined
                              Alexander Mundy @kraegar
                              @kraegar Sorry to be off topic, but curious if you have you set non linear extrusion or pressure advance for the Atomic Marble? The PETG version is way different than other PETG's extrusion wise.
                              • kraegarundefined
                                kraegar
                                That was the PLA marble, and I left the pressure advance at the same setting as my other filaments. No other changes.
                                  T3P3Tony administrators @wilriker
                                  @wilriker I have finally updated the design here:
                                  https://www.youmagine.com/designs/duet3d-laser-filament-monitor-housing-v2
                                  • wilrikerundefined
                                    wilriker @T3P3Tony
                                    @t3p3tony I had merged your changes manually into the original SCAD file by David. It did not improve the results in my tests. They were actually a little bit worse.
                                    But currently my printing is completely on hold and will be for another couple of weeks. After that I will compare your updated version with the one I had created.
                                    Manuel
                                    My Tool Collection
