    Problems installing the IR Probe on the Duet Ethernet
    IR Height Sensor
    2.1k
    • Bonzoundefined
      Bonzo
      Many thanks for the tip 🙂
      That was the mistake.
      • MikeBundefined
        MikeB
        i have the same issue. ...
        M574 Z1 S2 ; Set endstops controlled by probe
        M558 P1 H5 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
        G31 P500 X0 Y0 Z1.0 ; Set Z probe trigger value, offset and trigger height
        M557 X40:260 Y40:260 S42.5 ; Define mesh grid
        this is Cartesian duet wifi 2.0
        please help???
        • MikeBundefined
          MikeB
          it seems to just light up one time when i plug in usb.
          • MikeBundefined
            MikeB
            guess no reply means tuff _____.
              dc42 administrators @MikeB
              @mikeb said in Problems installing the IR Probe on the Duet Ethernet:
              Do you mean that the LED on the IR sensor flashes once, or lights up and stays lit? How bright is it? A continuous dimly-lit LED on the IR sensor means that it isn't getting the Vcc supply.
              • MikeBundefined
                MikeB
                it looks normal brightness. it lights up once and then goes off. never lights up again. been over everything ten times. now z motors just buzz. getting discuraged. spent all this money...
                • elmoretundefined
                  elmoret
                  Could you upload a few photos showing how you have it wired? (the connectors at each end of the cable)
                  • MikeBundefined
                    MikeB
                    • aidarundefined
                      aidar
                      Looks like you wires are connected to Duet incorrectly. Red wire (+3.3v) should be where your green (or is it blue) wire is, next pin should be free, then ground (black one) and finally closest to Paneldue connector should be green wire. Or to make it simple, you have to turn your connector 180 degrees.
                      MikeBundefined 1 Reply Last reply Reply Quote 0
                      • MikeBundefined
                        MikeB
                        • MikeBundefined
                          MikeB @MikeB
                          @mikeb guess e3d messed up.
                          • MikeBundefined
                            MikeB @aidar
                            @aidar i thank you very much !
                            • MikeBundefined
                              MikeB
                              you fixed me bud. i owe you one! thanks again!
                              • BLVundefined
                                BLV
                                I have to say that David's mini IR module is the best height sensor to use with the duet board. I am getting the most accurate readings..
                                MikeBundefined dc42undefined 2 Replies Last reply Reply Quote 1
                                • MikeBundefined
                                  MikeB @BLV
                                  @blv how is your bed setup? PICS?
                                  and i agree is does seem to be accurate but i have much to learn...
                                    dc42 administrators @BLV
                                    @blv said in Problems installing the IR Probe on the Duet Ethernet:
                                    Thanks! But in fairness, there are some surfaces that it doesn't work well with, e.g. glass with a coating of glue stick or hairspray on top.
                                    • MikeBundefined
                                      MikeB @dc42
                                      @dc42 yes i have read about this. i bought black paper build surface that it seems to work well with. im fighting z axes shutter right now... no printing at all.
