    Problems with the E3D-V6 Temperature
    1.6k
      Phaedrux Moderator @lui2004
      @lui2004 Possibly the comma instead of a period. , versus .
      • lui2004undefined
        lui2004
        Now i See my mistake.
        And for E3d-v6 What i can do to solve my problem any idea?
        sigxcpuundefined 1 Reply Last reply Reply Quote 0
          If it really is an authentic E3D hotend and thermistor I think your M305 settings are off.
          You have M305 P1 B4725 C7.060000e-8
          But should have M305 P1 T100000 B4388 C7.060000e-8 R4700 Or at least that's what the configurator gives for the semitek thermistor E3D uses.
          • lui2004undefined
            lui2004
            @phaedrux said in Problems with the E3D-V6 Temperature:
            ok i have change it
            send this gcode for autotuning:
            M303 H1 S240
            result:
            Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 472C.
            Auto tune heater 1 completed in 223 sec
            Use M307 H1 to see the result, or M500 to save the result in config-override.g
            Gcode M307 H1 Result is:
            M307 H1
            Heater 1 model: gain 447.7, time constant 133.2, dead time 13.0, max PWM 1.00, calibration voltage 12.3, mode PID, inverted no, frequency default
            Computed PID parameters for setpoint change: P4.1, I0.098, D37.2
            Computed PID parameters for load change: P4.1
            • peirofundefined
              peirof
              Have you double check voltage of termopar/PSU printer?
                That looks like a normal warning. Is the temp stable now or does it still fault?
                • lui2004undefined
                  lui2004
                  till 5 minutes 235C stable
                  i will make a test print
                  • lui2004undefined
                    lui2004
                    seems to be ok still print the calibration cube
                    other thin my print is not in the center of my bed
                      @lui2004 https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
                      • sigxcpuundefined
                        sigxcpu @lui2004
                        @lui2004 said in Problems with the E3D-V6 Temperature:
                        I assume you fixed this one too?
                        M143 H1 S28 0 ; Set temperature limit for heater 1 to 280C
                        • lui2004undefined
                          lui2004
                          Yes i fix it
