    Problems with the E3D-V6 Temperature
    1.6k
    • lui2004undefined
      lui2004
      Now i See my mistake.
      And for E3d-v6 What i can do to solve my problem any idea?
      sigxcpuundefined 1 Reply Last reply Reply Quote 0
        If it really is an authentic E3D hotend and thermistor I think your M305 settings are off.
        You have M305 P1 B4725 C7.060000e-8
        But should have M305 P1 T100000 B4388 C7.060000e-8 R4700 Or at least that's what the configurator gives for the semitek thermistor E3D uses.
        • lui2004undefined
          lui2004
          @phaedrux said in Problems with the E3D-V6 Temperature:
          ok i have change it
          send this gcode for autotuning:
          M303 H1 S240
          result:
          Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 472C.
          Auto tune heater 1 completed in 223 sec
          Use M307 H1 to see the result, or M500 to save the result in config-override.g
          Gcode M307 H1 Result is:
          M307 H1
          Heater 1 model: gain 447.7, time constant 133.2, dead time 13.0, max PWM 1.00, calibration voltage 12.3, mode PID, inverted no, frequency default
          Computed PID parameters for setpoint change: P4.1, I0.098, D37.2
          Computed PID parameters for load change: P4.1
          • peirofundefined
            peirof
            Have you double check voltage of termopar/PSU printer?
              That looks like a normal warning. Is the temp stable now or does it still fault?
              • lui2004undefined
                lui2004
                till 5 minutes 235C stable
                i will make a test print
                • lui2004undefined
                  lui2004
                  seems to be ok still print the calibration cube
                  other thin my print is not in the center of my bed
                    Phaedrux Moderator @lui2004
                    @lui2004 https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
                    • sigxcpuundefined
                      sigxcpu @lui2004
                      @lui2004 said in Problems with the E3D-V6 Temperature:
                      I assume you fixed this one too?
                      M143 H1 S28 0 ; Set temperature limit for heater 1 to 280C
                      • lui2004undefined
                        lui2004
                        Yes i fix it
