    Problems with the E3D-V6 Temperature
    1.7k
    • lui2004undefined
      lui2004
      @tjschweizer said in Problems with the E3D-V6 Temperature:
      M303 H1 S200
      i try
      • lui2004undefined
        lui2004
        i got this
        23:13:25Auto tune phase 3, peak temperature was 221.4
        23:13:19Auto tune phase 2, heater off
        23:10:11Auto tune phase 1, heater on
        23:10:05M303 H1 P0.5 S240
        Auto tuning heater 1 using target temperature 240.0°C and PWM 0.50 - do not leave printer unattended
        • sigxcpuundefined
          sigxcpu @lui2004
          @lui2004 said in Problems with the E3D-V6 Temperature:
          You have multiple mistakes in your config file:
          M208 X-34 Y-1,5 Z0 S1 ; Set axis minima
          M143 H1 S28 0 ; Set temperature limit for heater 1 to 280C
          • lui2004undefined
            lui2004
            @sigxcpu said in Problems with the E3D-V6 Temperature:
            whats wrong here ?
              Phaedrux Moderator @lui2004
              @lui2004 Possibly the comma instead of a period. , versus .
              • lui2004undefined
                lui2004
                Now i See my mistake.
                And for E3d-v6 What i can do to solve my problem any idea?
                sigxcpuundefined 1 Reply Last reply Reply Quote 0
                  If it really is an authentic E3D hotend and thermistor I think your M305 settings are off.
                  You have M305 P1 B4725 C7.060000e-8
                  But should have M305 P1 T100000 B4388 C7.060000e-8 R4700 Or at least that's what the configurator gives for the semitek thermistor E3D uses.
                  • lui2004undefined
                    lui2004
                    @phaedrux said in Problems with the E3D-V6 Temperature:
                    ok i have change it
                    send this gcode for autotuning:
                    M303 H1 S240
                    result:
                    Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 472C.
                    Auto tune heater 1 completed in 223 sec
                    Use M307 H1 to see the result, or M500 to save the result in config-override.g
                    Gcode M307 H1 Result is:
                    M307 H1
                    Heater 1 model: gain 447.7, time constant 133.2, dead time 13.0, max PWM 1.00, calibration voltage 12.3, mode PID, inverted no, frequency default
                    Computed PID parameters for setpoint change: P4.1, I0.098, D37.2
                    Computed PID parameters for load change: P4.1
                    • peirofundefined
                      peirof
                      Have you double check voltage of termopar/PSU printer?
                        That looks like a normal warning. Is the temp stable now or does it still fault?
                        • lui2004undefined
                          lui2004
                          till 5 minutes 235C stable
                          i will make a test print
                          • lui2004undefined
                            lui2004
                            seems to be ok still print the calibration cube
                            other thin my print is not in the center of my bed
                              @lui2004 https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
                              • sigxcpuundefined
                                sigxcpu @lui2004
                                I assume you fixed this one too?
                                • lui2004undefined
                                  lui2004
                                  Yes i fix it
