    Duet Web Control 2.0.0-RC3 is ready
    Duet Web Control
    50
    147
    27.3k
    • burtoogleundefined
      burtoogle
      Apologies if this has already been mentioned but I think there's a problem with the layer time chart. It appears to work OK at the start but then later it goes blank. I noticed when I reprinted a job that the second (and subsequent) prints did not have a layer time chart displayed.
      • wilrikerundefined
        wilriker @burtoogle
        @burtoogle said in Duet Web Control 2.0.0-RC3 is ready:
        I mentioned this above somewhere. This can already happen within the same print by switching to another section of DWC and then returning to Job Status. At least in this case reloading DWC solves the issue.
        Manuel
        My Tool Collection
        burtoogleundefined 1 Reply Last reply Reply Quote 0
          burtoogle @wilriker
          @wilriker said in Duet Web Control 2.0.0-RC3 is ready:
          Yes, I think I had seen that behaviour also but couldn't remember for sure.
          • brandonhundefined
            brandonh @chrishamm
            @chrishamm By speed graphing, I mean the ability to see the speed of the printer over time, on the UI, just like the temperature graph. This is really useful for debugging because the instantaneous readout can be hard to keep up, and just knowing how fast the printer is going can be useful for debugging slicing and machine settings. Plus if you change these settings but want to run an older g-code file it can be handy too.
            I did take a look at the code and it seems pretty reasonable to add, but I doubt this is something I'd work on anytime soon.
            • Biggsisundefined
              Biggsis
              I could not find, if somebody already mentioned it, but in Europe the time (in the temp chart) is not displayed in "AM/PM" format. Maybe make it selectable, thanks.
              Hypercube Evolution User Group : https://www.facebook.com/groups/Hypercubeevolution/
              Kossel Delta XL / XXL User Group : [https://www.facebook.com/groups/KosselXXL/]
              AS-3D Druckundefined 1 Reply Last reply Reply Quote 1
              • AS-3D Druckundefined
                AS-3D Druck @Biggsis
                @biggsis said in Duet Web Control 2.0.0-RC3 is ready:
                I got AM and PM in my Temp Chart.
                Bild Text
                Best regards
                AS-3D Druck / Andre
                mudcruzrundefined 1 Reply Last reply Reply Quote 0
                • garyd9undefined
                  garyd9
                  @chrishamm
                  I finally got around to trying this out and thought I'd share my (very early) initial impressions. These are my own impressions without taking into account things that others might have posted. While this type of feedback might result in duplicate comments, it also prevents my impressions from being "contaminated" by what I might have already read. I'm using the "Chrome" web browser on Windows 10 and MacOS against firmware 2.02. and DWC 2.0.0-RC3
                  First, I like what I think you're trying to do here. Overall, it looks positive.
                  However, I encountered three items that I feel are steps backward.
                  It's more clumsy now than it was to initiate the G32 command (delta calibration, manual bed leveling assistant, etc. It runs G32.) Previously, it was a simple single button click on the primary/dashboard screen. Now, it requires multiple clicks to first drop down the "compensation & calibration" list, a mouse movement, and a second click to select the proper option. This is more annoying when you consider that "mesh" compensation isn't used on my machine and isn't enabled. (There's no mesh area defined.) To resolve this, I'd suggest reverting to the simple single function button by default and allowing an option to change this to the droplist if and only if a selection is made in the settings to enable mesh options. (Or, only present mesh options if a mesh area is defined, otherwise just be a simple button that runs G32.)
                  Related to the above, when I run G32 using the Compensation&calibration droplist from the Dashboard, the results of the calibration do not seem to appear in the "G-Code Console" tab. I usually check the output of a calibration to ensure that the before/after numbers are somewhat close to each other (and re-run g32 if they aren't.) It seems (with DWC 2RC3) that the only way to get the G32 results to appear in the console is to run the command from the console tab to begin with.
                  I'm not sure I like how the status/tools/temp layout renders. I get a LOT of empty whitespace and the temperature chart (which is the tallest window) gets squeezed on the far right. I've posted a screen snippet near the end of this post to illustrate the concern. Possible alternatives might be to limit the height of the temperature chart to be no higher than the max height of the status or tools box (whichever is taller) or stack the status and tools boxes over each other (which would work for single tool/single bed machines, but might be annoying for multiple tool machines.)
                  • Dougal1957undefined
                    Dougal1957
                    I would concur ref the results of a auto cal routing from the drop down no results are displayed doing a G32 from the Gcode console works
                    • mudcruzrundefined
                      mudcruzr @AS-3D Druck
                      @as-3d-druck said in Duet Web Control 2.0.0-RC3 is ready:
                      Bild Text
                      Re-reading his post I think there may be a slight language issue. I think he was asking for the temp chart time display to be selectable between the am/pm style and the (more favoured in Europe) 24 hour style.
                      FWIW I would also prefer to see 24 hour time.
                      • dragonnundefined
                        dragonn
                        Is the temp chart fixed to 300C max?
                        I am printing with PC at 300C. It would be nice if it could autoscale the max value.
                          Phaedrux Moderator @dragonn
                          @dragonn I think it's supposed to scale with whatever you have your max temp set to?
                          dragonnundefined 1 Reply Last reply Reply Quote 0
                          • dragonnundefined
                            dragonn @Phaedrux
                            @phaedrux said in Duet Web Control 2.0.0-RC3 is ready:
                            I have in my config:
                             M143 H1 S350
                            So it doesn't look like it is working this way.
                              @dragonn I guess that's how it was supposed to work on the v1 DWC. Here's where I remembered seeing it. https://forum.duet3d.com/topic/2969/allow-scrolling-resizing-and-scaling-of-the-temperature-graph
                              • wilrikerundefined
                                wilriker @Phaedrux
                                I checked the source code for DWC2 and it is supposed to work the same way. 300°C is the default max but can be overridden by the machines highest temperature. Obviously something is not working as intended.
                                I have though found another issue: I have a macro that more or less does the same thing as a G32 for assisted bed leveling would do. It takes to my adjustment screws and displays a Z movement dialog. In this dialog I can click every button exactly once. Then it turns into a spinner and can no longer be used.
                                It only happens with M291 inside the macro. If I run M291 directly via GCode input field it works as expected.
                                Here is my macro
                                G28
                                G0 F6000
                                G0 Z2
                                G0 X7 Y110 ; Middle-left
                                M291 S3 Z1 R"Leveling Phase 1" P"Level point 1/3 and press OK"
                                G0 Z2
                                G0 X215 Y3 ; Front-right
                                M291 S3 Z1 R"Leveling Phase 1" P"Level point 2/3 and press OK"
                                G0 Z2
                                G0 X215 Y215 ; Back-right
                                M291 S3 Z1 R"Leveling Phase 1" P"Level point 3/3 and press OK"
                                G0 Z2
                                G0 Z0
                                M291 S3 Z1 R"Leveling Fine-tuning" P"Fine-tune point 1/2 and press OK"
                                G0 Z2
                                G0 Z0
                                M291 S2 Z1 R"Leveling Fine-tuning" P"Fine-tune point 2/2 and press OK"
                                P.S.: Same behavior when running G32. I do not have a probe so I use M558 P0 to use manual mode.
                                P.P.S.: As with G32 when used on a Delta it will also not report required adjustments for G32 assisted bed leveling.
                                Manuel
                                My Tool Collection
                                • Alex.crundefined
                                  Alex.cr
                                  This post is deleted!
                                  • AlexLinundefined
                                    AlexLin
                                    I cannot see how I can pin/lock/override the fan speed..
                                    • 3dmntbighkerundefined
                                      3dmntbighker
                                      I'm finding that with DWC 2.x on my Maestro the DWC will stop working without affecting the print. And it eventually returns. Is there a know issue that kills the web server, but it eventually recovers? The page just stops being served and then starts again eventually. I tend to use the reprap link. I recall reading discussions about buffer overflow in the web server?
                                      Scratch built CoreXY with Maestro
                                      Heavily modified Ender 3 with Maestro
                                      MPCNC work in progress with Duet WiFi
                                        @3dmntbighker, I think the issue you refer to was buffer exhaustion in the firmware that runs on the WiFi module of the Duet WiFi.
                                        Is the web interface reliable when you run DWC 1.22.6?
                                        3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
                                        • DocTruckerundefined
                                          DocTrucker
                                          It runs on v0.6 systems ok aside from a no available sessions message today after 4 hours work.
                                          Aside from that only complaint is the temperature values being clipped when the window is resized so 230 was clipped down to 23.
                                            3dmntbighker @dc42
                                            @dc42 said in Duet Web Control 2.0.0-RC3 is ready:
                                            Ah right. No I have not tried to back rev. The print ran all night. The laser sensor paused it this morning (grrr), and now that I have the display connected I could resume the print to completion. But the DWC stopped working around 11 last night.
