Duet Web Control 2.0.0-RC3 is ready
I would concur ref the results of a auto cal routing from the drop down no results are displayed doing a G32 from the Gcode console works
@as-3d-druck said in Duet Web Control 2.0.0-RC3 is ready:
@biggsis said in Duet Web Control 2.0.0-RC3 is ready:
I could not find, if somebody already mentioned it, but in Europe the time (in the temp chart) is not displayed in "AM/PM" format. Maybe make it selectable, thanks.
Re-reading his post I think there may be a slight language issue. I think he was asking for the temp chart time display to be selectable between the am/pm style and the (more favoured in Europe) 24 hour style.
FWIW I would also prefer to see 24 hour time.
@dragonn I think it's supposed to scale with whatever you have your max temp set to?
@phaedrux said in Duet Web Control 2.0.0-RC3 is ready:
I have in my config:
M143 H1 S350
So it doesn't look like it is working this way.
@dragonn I guess that's how it was supposed to work on the v1 DWC. Here's where I remembered seeing it. https://forum.duet3d.com/topic/2969/allow-scrolling-resizing-and-scaling-of-the-temperature-graph
I checked the source code for DWC2 and it is supposed to work the same way. 300°C is the default max but can be overridden by the machines highest temperature. Obviously something is not working as intended.
I have though found another issue: I have a macro that more or less does the same thing as a
G32
for assisted bed leveling would do. It takes to my adjustment screws and displays a Z movement dialog. In this dialog I can click every button exactly once. Then it turns into a spinner and can no longer be used.
It only happens withM291
inside the macro. If I runM291
directly via GCode input field it works as expected.Here is my macro
G28 G0 F6000 G0 Z2 G0 X7 Y110 ; Middle-left M291 S3 Z1 R"Leveling Phase 1" P"Level point 1/3 and press OK" G0 Z2 G0 X215 Y3 ; Front-right M291 S3 Z1 R"Leveling Phase 1" P"Level point 2/3 and press OK" G0 Z2 G0 X215 Y215 ; Back-right M291 S3 Z1 R"Leveling Phase 1" P"Level point 3/3 and press OK" G0 Z2 G0 X215 Y3 ; Front-right G0 Z0 M291 S3 Z1 R"Leveling Fine-tuning" P"Fine-tune point 1/2 and press OK" G0 Z2 G0 X7 Y110 ; Middle-left G0 Z0 M291 S2 Z1 R"Leveling Fine-tuning" P"Fine-tune point 2/2 and press OK"
P.S.: Same behavior when running
G32
. I do not have a probe so I useM558 P0
to use manual mode.P.P.S.: As with
G32
when used on a Delta it will also not report required adjustments forG32
assisted bed leveling. -
This post is deleted! -
I cannot see how I can pin/lock/override the fan speed..
I'm finding that with DWC 2.x on my Maestro the DWC will stop working without affecting the print. And it eventually returns. Is there a know issue that kills the web server, but it eventually recovers? The page just stops being served and then starts again eventually. I tend to use the reprap link. I recall reading discussions about buffer overflow in the web server?
@3dmntbighker, I think the issue you refer to was buffer exhaustion in the firmware that runs on the WiFi module of the Duet WiFi.
Is the web interface reliable when you run DWC 1.22.6?
It runs on v0.6 systems ok aside from a no available sessions message today after 4 hours work.
Aside from that only complaint is the temperature values being clipped when the window is resized so 230 was clipped down to 23.
@dc42 said in Duet Web Control 2.0.0-RC3 is ready:
Ah right. No I have not tried to back rev. The print ran all night. The laser sensor paused it this morning (grrr), and now that I have the display connected I could resume the print to completion. But the DWC stopped working around 11 last night.
Hi, I just updated to 2.0.0-RC3 just to check it out(still on an incomplete printer hardware build at the moment), and only one quibble so far. I got one error in a red message box in the corner: "Failed to get file list Directory 0:/filaments not found"
I was able to pull the sd card, pop into my PC to add the directory to the root, but could the WebControl possibly just create the directory automatically if it doesn't exist rather than throwing an error? Its just a slight inconvenience because root directories can't be added through the interface either as far as I can tell.
- If I go to G-Code Console, select a whole line by first clicking right of it and dragging all the way left and some more, then hit CTRL+C, then select the input box and hit CTRL+V, there's an extra TAB character in the copied text.
- The mesh grid calibration results are no longer displayed after running it. I need to hit F5 so that it gets the latest data and then manually go to the Height Map.
- I can't find a Diagnostics button anywhere.
- Extrude and retract buttons are unusable. config: 0_1547976629806_config_edit.g
The g-code console no longer logs a message at start of build. I found that behaviour useful.
Edit: Saves going through:
(current time) - (elapsed time) + (simulated time) = (accurate finish time) -
One minor headache I have with RC3 is that I can no longer enter tab characters using the config text editor.
I'm having an odd issue.
Duet Wifi 1.04
Firmware 2.02
Wifi server 1.22
DWC 2.0.0RC3Sometimes I want to adjust the home position for the Z axis manually, instead of letting the Z probe do it. (I know, I shouldn't need to, and I should just change the Z offset, but I get different results at different temperatures, so...)
Anyway, entering into the G code console:
M558 P0
Then using the "home Z" button or the "home all" button.
It mostly works as expected, but for whatever reason, on the dialog box to jog the Z axis, I can only press each button once. After that there is a spinning circle in place of the adjust amount, and it will not respond to another click.
It does work when running a G29 mesh level, and I can press the same button repeatedly with the probe set to 0/manual, but it does not work with homing the Z axis.
I didn't end up trying alternate browsers, I only used Chrome, but I did use the Chrome on my PC, and I also tried my phone.
@supraguy You share this issue with me and at least one other user.
I am also having a problem with the height adjustment buttons. If I try to run auto calibration and check height manually, my height adjustment buttons will not refresh. If I run the calibration and exit and then use the homeall or home X Y or Z axis the button will not refresh.
