    Stop Thermal Transfer from Bed to Frame
    31
    3.1k
    • percarundefined
      percar @richardmckenna
      @richardmckenna
      I have had the same issue my printer is 300mm x 600mm also with an aluminum bed. I had exactly the same issue of heat transfer to the aluminum profile extrusion frame. I found some round garolite rod about 25mm long 15mm diameter. (you can get various sizes from McMaster Carr althought there are other suppliers that are cheaper. I drilled the rod and inserted Heli Coils in both ends. For the end that goes to the profile aluminum I used the profile nut with a set screw of the proper size. I threaded the Garolite rod onto the set screw and tightened the just bolted the cast aluminum plate to the other end of the garolite. There is absolutely no heat transfer. Make sure that the set screw and bolt do not touch as this will defeat the purpose.
      • percarundefined
        percar
        Here is an image of the setup that I used for the garolite
        https://1drv.ms/u/s!ArsUUgUVyLkdhq02CHFbp6Ctv00auw
        • Ricky_Grade10undefined
          Ricky_Grade10
          As you guys know, I only got my grade 10 but my thinking thoughts are saying that if the heat transfers to the frame then could it be possible for the frame to experience thermal expansion on some level or another and then obviously it could be for to say that the frame might flex or mess with the calibration?
          richardmckennaundefined 1 Reply Last reply Reply Quote 1
          • richardmckennaundefined
            richardmckenna @Ricky_Grade10
            @ricky_grade10 exactly. and hopefully by using one of the methods others have described above I'll be able to stop it as much as possible.
            Dougal1957undefined Surgikillundefined 2 Replies Last reply Reply Quote 0
            • Dougal1957undefined
              Dougal1957 @richardmckenna
              @richardmckenna yes indeed and just to further my suggestion I used a 25mmm hole drill to cut some discs out of 10mm thick PTFE Sheet works like a dream.
              Doug
              richardmckennaundefined 1 Reply Last reply Reply Quote 0
                richardmckenna @Dougal1957
                @dougal1957 Thanks Doug. I found some 10mm and 20mm thick PTFE offcuts as well as some stainless steel spacers on ebay. So I'll give them a go when they arrive.
                I was just going to cut blocks out of the PTFE but I do like the idea of them being round.
                Dougal1957undefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                  @richardmckenna I had a holes in the tool box which is why I used it drilled the hole in the middle (it is a little big but it allows some wiggle room to move the disc so it doesn't overhang the extrusions)
                  and cut the round at the same time easy lol
                  • Vetiundefined
                    Veti
                    you can find ceramic spacers at mouser
                    https://www.mouser.de/Electromechanical/Hardware/Standoffs-Spacers/_/N-aictf?P=1z0z0py
                    • Surgikillundefined
                      Surgikill @richardmckenna
                      @richardmckenna Assuming a temperature delta of 40 degrees and a length of extrusion 500mm in length you aren't even looking at 1mm of expansion. As far as accuracy of the frame goes that is going to matter. However, if you keep the bed bolted down and the frame does not expand with the bed you can end up with issues like the bed buckling. Unless you are noticeable seeing defects in your print because of it just let it be.
                        deckingman @richardmckenna
                        @richardmckenna Still can't remember the name of the stuff I used but do a google search for under "floor heating insulation" or some such. I did find a picture though 0_1547728887316_bed sandwich.jpg
                        So it's two layers of thermal insulation, then the 10mm thick aluminium plate, then 6mm of glass on top. Counter sunk bolts go through the aluminium and insulation and screw into T nuts in the frame. Thermal transfer to the frame only happens through the bolts (which are stainless steel) so it's negligible.
                        Nice and simple. It may not be any good to you though, depending on your bed levelling arrangement. I have 3 screws and a single belt and simply slacken the grub screws holding the pulleys onto the screws, adjust each screw and tighten the grub screws up. I've only had to do that about 3 times - each one after disassembling the machine to move it.
                        • SplatHammerundefined
                          SplatHammer
                          Just a thought, but I wonder if rubber vibration insulators (basically a piece of hard rubber with 2 bolts moulded in top and bottom) would work? There are small ones holding a plastic cover to the top of the engine in my car. They can take lots of heat and are moulded so they should be exactly the same size. Something like this:
                          https://www.ebay.co.uk/itm/Aeromotive-Fuel-Pump-Vibration-Dampener-Mounting-Kit-11601/362096382511?epid=1168728755&hash=item544ea0522f:g:zkIAAOSwWaRZsnyp:rk:3:pf:0
                          but cheaper!
                          • Da Sid Monundefined
                            Da Sid Mon
                            PEEK Spacers ... https://www.mcmaster.com/90144a130
                            • jrjones88undefined
                              jrjones88
                              Could also use wood or melamine spacers.
                              • whosrdaddyundefined
                                whosrdaddy
                                I use printed TPU spacers, no problem with heat whatsoever...
