    Duet Maestro users: can you share a set of menu files?
    32
    5.0k
    • jottesmanundefined
      jottesman @dc42
      @dc42 Unfortunately I believe I am running the latest firmware and still have the issue.
      The Hex file reads: 05 08 1F 1F 1F 1F 1F 1F 1F 1F
      Firmware Name: RepRapFirmware for Duet 2 Maestro
      Firmware Electronics: Duet Maestro 1.0
      Firmware Version: 2.02RC6(RTOS) (2018-12-15b2)
      Web Interface Version: 1.22.6
      mudcruzrundefined 2 Replies Last reply Reply Quote 0
      • mudcruzrundefined
        mudcruzr @jottesman
        @jottesman Sorry, but 2.02RC6 isn't the latest version, 2.02a is. See https://github.com/dc42/RepRapFirmware/releases
        If you want to try images that definitely work on my 12864, download my menu files from my earlier post and you'll find a few .img files in there.
          jottesman
          Ahha, gotcha.
          I'll try and finish my menu this weekend. Is there a way yet to use an Image as a button?
          • mudcruzrundefined
            mudcruzr @jottesman
            @jottesman I recreated your hex file (05 08 1F 1F 1F 1F 1F 1F 1F 1F) on my system and I get no blank lines. It displays 3 off pixels, 2 on pixels on each row for 8 rows. i.e. a vertical line 2 pixels wide and 8 pixels high offset to the right by three blank pixels.
            • mudcruzrundefined
              mudcruzr
              0_1547829464630_Maestro_Menu_v1.1.zip.txt
              Above please find v1.1 of my maestro menu files, as before I had to append the .txt to the end of the filename to allow the upload. Remove the .txt and unzip it, then upload the contents to your Display folder (/menu).
              The changes are:
              COOLDOWN added to the PREHEAT menu page and a poor attempt at the D3D logo on the main/info page.
              enjoy
              3dmntbighkerundefined 1 Reply Last reply Reply Quote 2
              • 3dmntbighkerundefined
                3dmntbighker
                Is it possible to have the menu system filter everything with "._" prefix, or the equivalent Mac meta data files? Or better still, to delete them, since they serve no purpose on a printer. Actually anything that starts with a "." could go.
                Scratch built CoreXY with Maestro
                Heavily modified Ender 3 with Maestro
                MPCNC work in progress with Duet WiFi
                  3dmntbighker @mudcruzr
                  @mudcruzr said in Duet Maestro users: can you share a set of menu files?:
                  The changes are:
                  enjoy
                  If you could squeeze it in somewhere I would sure like to see the current baby step value on the main page.
                  mudcruzrundefined 1 Reply Last reply Reply Quote 0
                  • mudcruzrundefined
                    mudcruzr @3dmntbighker
                    @3dmntbighker Ask and Ye shall receive.... (Wow! talk about service)
                    2 files: A new version of main to replace your current one and a new image baby.img for the B/S (Babystep) graphic. You know the routine by now - delete the .txt, unzip and upload to the /menu directory.
                    BTW I've made the babysteps field alterable so you can tune Z from the main screen if you want.
                    0_1547845613823_babysteps.zip.txt
                    3dmntbighkerundefined 1 Reply Last reply Reply Quote 1
                      Dude 😉
                      Looking at the main page it looks like you can't get another line in there at the bottom. I'm wondering if you may as well drop everything a bit and make the icons a bit larger? Just giving feedback since you are putting in the effort. Shame to waste that blank bit at the bottom.
                      • mudcruzrundefined
                        @3dmntbighker That blank bit at the bottom is where M117 messages display. I may yet do away with it as the only messages I ever see are the ones I have in my slicer start G-code and end G-code: "Print started" and "Print finished" lol
                          Hmm, actually, that being the case I vote to keep that in place. #thumbsup
                            jottesman
                            I'm a little late to the party but finally sharing a set of menu files for the 12864 type displays.
                            https://github.com/tinkerlifeprojects/DUET3D_12864LCD_MenuFiles
                            They design is loosely based on the "TinkerFirmware" for the ultimaker printers. It has two "Main" pages with shortcuts to common functions and then a set of menus for controlling more aspects of the printer.
                            Any suggestions or requests are welcome
                            mudcruzrundefined Agniusmundefined 2 Replies Last reply Reply Quote 1
                            • mudcruzrundefined
                              mudcruzr @jottesman
                              @jottesman said in Duet Maestro users: can you share a set of menu files?:
                              Nice menus, but your bed.img file is missing from the repo mate.
                              jottesmanundefined 1 Reply Last reply Reply Quote 0
                                jottesman @mudcruzr
                                @mudcruzr Good spot. I've uploaded the "bed.img" file to the repository. I think it may actually be the one you uploaded (I liked it so much)
                                • secretmanundefined
                                  secretman
                                  love the open source thing every one put is toutch for a great cause i just canot code anything i want to give my apreciation to all of you guy's!
                                  • Agniusmundefined
                                    Agniusm @jottesman
                                    @jottesman
                                    WOW man, those are great. Have not chance to look into it deep but first impressions are WOW.
                                    What have you used to convert bitmaps?
                                      jottesman @Agniusm
                                      @agniusm very glad you like them. I will continue to try and update them, especially if you find any bugs or have any requests etc. Just let me know.
                                      My method of creating the images was far from streamlined. But because they were small images it didn't matter too much.
                                      I started in paint3D (Any photo editor will do but paint 3D has a pixel brush and lets you zoom in far enough that a 10x10 grid is big enough to see properly.)
                                      Moved to paint to convert to monochrome bitmap
                                      uploaded file to this site to convert to hex
                                      Then manually copied into a Online hex editor and added the width and height at the start. (Just be careful to write the width and height in hex, ie 10 is 0A)
                                      If anyone has a more streamline method though I'd be eager to hear it.
                                      • oc_geekundefined
                                        oc_geek
                                        i know this topic is pretty old, but hadn't find anything better around. The method sounds good only problem is the monocrome .bmp i get out of paint are way bigger than they shall be according to pixel dimension and byte rules in the begin of the thread... any help ?
