    Controlling a Cetus3D with Duet3D 0.8.5
    61
    8.8k
    • dragonnundefined
      dragonn
      @flopo76 said in Controlling a Cetus3D with Duet3D 0.8.5:
      Cetu3d's original stepper motor are 12v,
      They is no such thing like 12V stepper motors, stepper motors are current driven so it doesn't meter with voltage are you driving them (even 48V would hurt them, but doesn't Duet doesn't handle such high voltage).
      And BTW, on the photos this isn't Duet 0.8.5 but Duet2
      flopo76undefined 1 Reply Last reply Reply Quote 0
        @fotomas, I suspect you have the current set much too high for those motors in the M906 command, which will have the effect of making them behave as if you are sending them full steps. I wasn't able to find any data for that motor, but if the phase voltage is 12V then 400mA current may be about right; but you will need 24V power to drive the motors smoothly.
        You can get an estimate of the motor rated current by measuring the resistance of one phase and the length of the motor, and then searching a stepper motor catalog (e.g. omc-stepperonline.com) for motors of similar size and phase resistance.
        • flopo76undefined
          flopo76 @dragonn
          @dragonn On my Cetus3d with original steppers and wifi duet, powered at 12v it made a lot of noise and vibration.Instead with the original main board powered at 19v, no vibrations and noises.The original steppers of Cetus are at 38ohm per phase.Then I mounted motors with 3.4 ohms per phase and no longer feels when it works.At 38 ohms per phase, to make no noise the steppers must be set to 0.34A, but my hotend is very heavy and z axis was not up. I know that my printer is with Duet wifi and his with Duet 0.8.5
          Sorry for my English.
          • fotomasundefined
            fotomas
            Thank you for the help, issue solved.
            Now it moves much smoother. Lowering the mA on the stepper motors was the trick.
            Moving Z-axis down make a bit of a chunky sound and that is the friction based contraption that prevents the Z-axis from falling when powering off. Moving Z-axis upwards is as smooth as the other axis.
            Time will tell if this will be a problem during print, especially if lifting Z during transportation moves. Otherwise moving Z downwards during prints don't happen (I think?)
            Here's a video of homing with a setting of about 350 mA and voltage of 18v. After homing Z is moved 50 mm upwards, to show that Z+ moves as smooth as X & Y.
            [https://youtu.be/SXkN2tT7tvY](link url)
              I see you are using one of my Ormerod hot end boards!
              The Y axis is still much noisier than I expect from a Duet.
              fotomasundefined 1 Reply Last reply Reply Quote 0
              • fotomasundefined
                fotomas @dc42
                @dc42 Yep, I needed as sensor and since my Ormerod has been collecting dust since I got the Cetus I borrowed the hot end board. One of my "goals" with this conversion of the Cetus is to make it reversible so I haven't bothered wiring up all the other features of the hot end board. I do have some wires unused in the TP-cable i scavenged for the hot end board so maybe some lightning would be nice.
                As of now I am running the duet from a Lab-powersource so I can crank up the voltage to 24. But my goal was to use the Cetus powerbrick which is at 18V.
                • fotomasundefined
                  fotomas
                  I have happily been printing for a few days, tinkering with settings, fans, PanelDue etc.
                  It was when I printed a part I designed for the printer I realized that my part come out mirrored. First asymetric print 🙂 I thought this was an easy fix but I can to seem to ge my head around it. 😭 😭
                  So can anyone please help. What do I do to reverse my Y-axis to go the other way?
                  I have tried to revere the stepper motor with M569 P1 S1 => M569 P1 S0, that works but I haven't been able to get all the other parts in order. I Changed the M574 Y1 Z1 S2 => M574 Z1 Y2 S1, to no apparent effect.... I reversed the connector on going in to the duet and then reversed it back in config (I guess that it cancels out each other)
                  I have tried som many things I am not sure what I have done or in which order. So an explanation on how all this ties together would be much appreciated.
                  Is there more to it than using M569, M574 and coordinates in homing files?
                  This is the config I had before trying to fix this, all is well except mirrored Y-axis.
                  ;Drives
                  M569 P0 S1                               ; Drive 0 goes forwards
                  M569 P1 S0                               ; Drive 1 goes backwards (Y-axis)
                  M569 P2 S1                               ; Drive 2 goes forwards
                  M569 P3 S1                               ; Drive 3 goes forwards
                  ;M92 X80.00 Y80.00 Z80.00 E118.00
                  M566 X90.00 Y90.00 Z90.00 E120.00
                  M203 X18000.00 Y18000.00 Z10000.00 E5000.00
                  M201 X150.00 Y150.00 Z100.00 E250.00
                  M906 X340.00 Y340.00 Z500.00 E400.00 I30
                  M84 S30
                  M208 X0 Y0 Z0 S1
                  M208 X180 Y180 Z180 S0
                  M574 X1 S0
                  M574 Y2 Z1 S2
                  M558 P1 H5 F250 T6000
                  G31 P538 X0 Y0 Z3.65
                  M557 X55:180 Y15:180 S20
                    dc42 administrators @fotomas
                    @fotomas said in Controlling a Cetus3D with Duet3D 0.8.5:
                    To reverse the direction of the Y axis you also need to adjust M569, M574, and in homey.g and homeall.g reverse the directions of the Y homing moves and any Y homing stop backoff moves. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_X_and_Y and https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_The_homeall_g_file.
                    • fotomasundefined
                      fotomas
                      After a night sleep and some distance to the whole thing I sorted it out. I had almost right, the one thing that threw me of was one line I had added in homeall.g G92 X-3 Y-5. It was just an adjustment since my Y-axis home outside the printable area. But it surley messed things up 🙂
                      dc42 Thank you for your quick reply, now I am on the right track again.
                      Oh, and this is the piece I drew to print verifying that the axis are in right order. It was after the print finished it dawned on me both letter X and Y can be mirrored, without showing. Bad luck when thinking, I guess 🙂 🙂
                      • Onnoundefined
                        Onno
                        HI,
                        I'm considering doing the same, swapping out the default electronics with a Duet. I intend to use the sensorless homing feature, but I am not sure if that will work for the Z axis. For the Z-axis I still got three difference Z-axis sensors, the original three wire ormerod sensors, the 4 wire one, and the DC42 sensorboard with ultrasonic sensor. Am I right assuming you're using the latter as sensor? Or did you try sensorless home for that one as well?
                        And how may steps per mm did you configure for the extruder?
                        • fotomasundefined
                          fotomas @Onno
                          @onno
                          I am using the earliest sensor made by dc42, dor an Ormerod with dual extruders. Link. I use it to home Z and Y axis, for the X axis I have mounted a micro switch besede the x-axis stepper motor.
                          I will post the STL's for the sensor board, micro switch, power inlet and casing, if anyone is interested.
                          My config for the cetus looks like this, note the quite exotic heater values, but hey the work and have beed calibrated pretty well. I am using the cetus almost as delivered. 18v powerbrick, same extruder, same stepper motors. And tuned in it works very well, both with PLA and TPU, on original table without raft.
                          I am happy to answer any question you may have.
                          G90                                      ; Send absolute coordinates...
                          M83                                      ; ...but relative extruder moves
                          M550 PCEDUT                              ; Set machine name Cetus + Duet => cedut ;)
                          M551 Preprap                             ; Set password
                          M552 P192.168.0.65 S1                    ; Enable network and set IP address
                          M553 P255.255.255.0                      ; Set netmask
                          M554 P192.168.0.1                        ; Set gateway
                          M586 P0 S1                               ; Enable HTTP
                          M586 P1 S0                               ; Disable FTP
                          M586 P2 S0                               ; Disable Telnet
                          M569 P1 S1                               ; Drive 1 goes backwards (Y)
                          M92 X79.72 Y79.72 Z79.72 E118.00       ; Set steps per mm; used to be E127
                          M566 X230.00 Y230.00 Z90.00 E120.00      ; Set maximum instantaneous speed changes (mm/min)
                          M203 X28000.00 Y28000.00 Z15000.00 E10000.00  ; Set maximum speeds (mm/min)
                          M201 X200.00 Y200.00 Z100.00 E250.00      ; Set accelerations (mm/s^2)
                          M906 X340.00 Y340.00 Z500.00 E500.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30                                  ; Set idle timeout
                          M208 X-10 Y0 Z0 S1                         ; Set axis minima
                          M208 X185 Y184 Z180 S0                   ; Set axis maxima
                          M574 X1 S0                               ; Set active high endstops
                          M574 Y2 Z1 S2                            ; Set endstops controlled by probe
                          M558 P1 H5 F250 T6000                    ; Set Z probe type to unmodulated and the dive height + speeds
                          G31 P538 X0 Y0 Z3.82                     ; Set Z probe trigger value, offset and trigger height
                          M557 X50:180 Y10:165 S40                 ; Define mesh grid
                          G29 S1 					; Load stored mesh grid from SD Card
                          M140 H-1                                 ; Disable heated bed
                          M305 P1 R4700  T112 B-425 C7.060000e-8 ; post multimeter measurement
                          M143 H1 S280                             ; Set temperature limit for heater 1 to 280C
                          M106 P0 T50 H1 ; Thermostatic control is on, turn on at 50cC
                          M563 P0 D0 H1                            ; Define tool 0
                          G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
                          G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
                          ; Pressure advance
                          M572 D0 S0.05
                          • Onnoundefined
                            Onno
                            Thanks for the info, this provides a great starting point once I get the Duet in (still need to order it).
                            Right now the printer is still too busy to take it out, but like you, I'm trying to stay close to the original Cetus initially, although I foresee switching to an E3D Titan Aero at a later stage as well, along with 0.9deg steppers, and a heated bed.
                            Once again, thanks!
                            • cookieundefined
                              cookie
                              @fotomas Thanks a lot for helpful infos. I’m getting Cetus MK3, which should arrive next month, and joined Cetus Duet club 🙂
                              How you connect Cetus powerbrick to Duet? Any modification needed?
                              Cookie
                              • fotomasundefined
                                fotomas @cookie
                                @cookie
                                I took a DC jack from an old DELL laptop docking station. 3D Printed a holder so I could screw it down to the Cetus bottom plate using an already existing hole.
                                The Cetus bottom plate has four holes for the original controller board. Two of them fits the Duet 0.8.5 board as is. The 3D printed part for the DC jack reaches in underneath the the Duet offering support.
                                cookieundefined 1 Reply Last reply Reply Quote 0
                                • cookieundefined
                                  cookie @fotomas
                                  @fotomas great! Any photo of this dc jack? So I can google it and try to get one.
                                  • fotomasundefined
                                    fotomas @cookie
                                    @cookie
                                    I de-soldered one like in the pic below. But an Ebay or google search for "DC Jack female 7.4 mm" give you some other options.
                                    • dsmudgerundefined
                                      dsmudger
                                      Another Cetus MK3 owner here. Just got my Duet Wifi, but of course don't want to start pulling cables and boards out of a working printer before I know I have everything and it's reasonably likely to work.
                                      I think I'm going to need at least a different power supply (not a problem, I'll bring over a bench supply tomorrow). But is that probably it?
                                      I'd also be super grateful if someone in the know, could post the high level overview of the process? I mean like what are the chapter titles; then I can go off and bang my head against figuring out the finer details of all that until it works..
                                      Thanks 😓
                                      Dan
                                      • fotomasundefined
                                        fotomas
                                        dsmudger
                                        I would say these are major steps
                                        • Homing switches (I use a microswitch for X and an old dc42 IR sensor for Z and Y)
                                        • Make adapters or get new cables to stepper motors
                                        • Make adapter or new cable for hot end
                                        • Power supply (I am using the original Cetus power supply)
                                        • Configure the Duet3d (steps/mm and heater values you can see above, the rest I think may vary in your case)
                                        Original connectors can be forced into the Duet board, but I ended up making adapters both for the steppers and the hot end. Pictures below show before the adapters during "proof of concept phase". On the hotend it self I made a new board using experimental circuit board and matching connectors. There was too much interference in the ribbon cable for the signal from the IR board so I added an ethernet (twisted pair) cable for that.
                                        If there are any questions I would be happy to help.
                                        cookieundefined 1 Reply Last reply Reply Quote 2
                                        • dsmudgerundefined
                                          dsmudger
                                          Thanks a lot, that's beyond useful.
                                          • Cetus MK3 already has 3x homing switches, so sounds like I might even already have all I need.
                                          • Adapters seems the right way to go so it's easily reversible, but eh, 'ain't gonna need it 🤞'.
                                          • Duet 2 Wifi came with a little bag of JST connectors; if I'm lucky, the metal crimp terminals might be the same. If so I'll just need to change the plastic shells over (while carefully counting on my fingers which colour goes to which pin). If I'm extra lucky and Cetus doesn't change their wiring too often, maybe it'll even match your photos and help confirm I'm on the right track 👍
                                          Big thanks again for that, I'll try to post something once I get things going 😀
                                          cookieundefined A Former User? 2 Replies Last reply Reply Quote 0
                                          • cookieundefined
                                            cookie @dsmudger
                                            @dsmudger I just got my MK3 running and the Duet Wifi is laying around. Seem like I’ve to figure out the right crimping tools or learn how to crimp without them. I’m so novice when come to wiring works. Will keep you update when there is progress.
                                            Thanks 🙂
