    Multi color printing with Prusa's MMU V2 & Duet?
    91
    23.3k
    • gavatron3000undefined
      gavatron3000
      look at the link above the info is there, but the files ill add are only for filament changes that affect T4 so 90% of printing is unaffected. if you getting strings you need to tune your ramming settings correctly. this you need to do on your slicer to suit your machine
      @nicolab28 said in Multi color printing with Prusa's MMU V2 & Duet?:
      You are in live drive, I looked at your Tipsmoothing.g
      10s break anyway, it's just for testing, or is it really necessary?
      probably not its just a value that definitely works, i was finding that if i retracted too quickly through the extruder it was mashing my tips and causing jams
        gavatron3000
        adding a cutter to the macros wouldnt be hard youd just need to add a fast selector move across the mmu that chops the tip off if thats what you want but again it'll just build up under the selector anyway. better off just tuning the ramming right
        • fmaundefined
          fma
          Quality of the tips also depends on the time the filament spents in the nozzle (without extruding). Especially with PLA. I have a simple settings which work great, unless the PLA is sitting in the nozzle for 2 or 3 minutes (in this case, I get oozing).
          The solution is to pre-retract the filament at the end of a print.
          Frédéric
          • Scachiundefined
            Scachi
            Where do you buy 1.8mmx3mm ptfe tubing from ?
            I can't find a source for that. A german shop would be nice but shipping to Germany is good enough
              gavatron3000
              theres a link in the document above
              Scachiundefined 1 Reply Last reply Reply Quote 0
              • Scachiundefined
                Scachi @gavatron3000
                @gavatron3000 said in Multi color printing with Prusa's MMU V2 & Duet?:
                Thank you.
                  gavatron3000
                  @dc42 regarding triggers, are they meant to go off with immediate effect?
                  in my document above for loading the MMU2 they work and function as intended but it seems they are delayed until the tool change has completed. is this expected behaviour? id prefer being able to set it off immediately
                  NicoLab28undefined 1 Reply Last reply Reply Quote 0
                    The movement system is locked during a tool change, therefore if the trigger macro has any movement commands or other commands that affect motion, those commands will wait until the tool change is complete.
                    gavatron3000undefined 1 Reply Last reply Reply Quote 0
                      gavatron3000
                      The triggers in question are like this
                      M400
                      M291 "message and wait till ok is pressed"
                      Should I just remove the m400?
                      • NicoLab28undefined
                        NicoLab28 @gavatron3000
                        You're saying that you have the same problem as me, (my post "M581 M582 M291, What am I doing wrong?") To know that the dialog comes at the end of the tool change.
                        Too late, because the script continued to execute, after the error, which should have been blocking.
                          gavatron3000
                          I'm going to try removing the V1 from the M291 as well as the M400 too. But I can't test this until tomorrow
                            dc42 administrators @gavatron3000
                            M400 means wait until all queued motion has completed. So if you send it when a tool change is on progress, it will wait until it has completed.
                              gavatron3000
                              I'm hoping that if I remove the m400 and only have a M291 message within the trigger macro that it will pause the tool change if the condition is met.
                              I'll test shortly when I get a chance
                                gavatron3000 @dc42
                                @dc42 said in Multi color printing with Prusa's MMU V2 & Duet?:
                                ok so i removed all the movement commands and M400 from the trigger but to no avail. is it possible allow the triggers in the future to interrupt the tool change and pause when conditions arent met? and then resumed when prompted? that would make this MMU2 work perfectly then
                                • Wyvernundefined
                                  Wyvern
                                  The MMU is interesting, but using Duet components are you not able to use purge blocks and such?
                                    gavatron3000
                                    Purge blocks and the like are generated by the slicer or post processing scripts
                                    • Wyvernundefined
                                      Wyvern
                                      Ah. Thanks.
                                      Would be great for TPU printing as supports with TPU are useless- just use pla.
                                      • Computigerundefined
                                        Computiger
                                        https://docs.google.com/document/d/13r_6BTYTO-xlD6cQeNwOx4qeCEYYGrxOcHc0mC-tT8Q/edit?usp=drivesdk
                                        Hmm...
                                        I didn´t understand as I have to.
                                        Can somebody tell me where I have to plug in the Pinda probe. For now I putted him to E0 Endstop, but I can´t home the selector (drive U).
                                        In the description I have to plug him to V but
                                        Here some details of config.g
                                        M574 X1 Y1 S1 ; Set active high endstops
                                        M574 U1 V1 W1 S3 ; Set additional axes as sensorless endstops
                                        M574 Z1 S2 ; Set endstops controlled by probe
                                        ;Drives
                                        M569 P4 S0 ; Drive 4 goes backwards V
                                        M569 P5 S1 ; Drive 5 goes forwards U
                                        M569 P6 S0 ; Drive 6 goes backwards W
                                        M584 X0 Y1 Z2 E3 V4 U7 W6 ; Apply custom drive mapping
                                          gavatron3000 @Computiger
                                          @computiger said in Multi color printing with Prusa's MMU V2 & Duet?:
                                          Hmm...
                                          ;Drives
                                          the pinda is used as the V axis endstop in certain situations during loading so it must be plugged into that axis endstop input. U axis uses sensorless homing
                                          • nikschaundefined
                                            nikscha @gavatron3000
                                            I don't use the cutter, for me I didn't think it's necessary as the ramming before retraction forms the tip anyways. Abs just works but pla is more difficult. Make sure you use the correct I.D PTFE tube in the Hotend as well. 1.8mm to 1.85mm. capricorn tubing isnt narrow enough either, ive tried.
                                            I almost forgot! I'm adding some modded STL and scad files soon so the filament change will function perfectly as the filament ejection will snag on T4 without a small mod to the selector and main body of the mmu2
                                            Hey there,
                                            first of all, awesome work!
                                            Second, where are the stl's you mentioned here? Are they important?
                                            Thanks in advance!
                                            Stay in school
