Duet/RRF Big printing problems
4.6k
    Phaedrux Moderator @Monster Delta
    @monster-delta said in Duet/RRF Big printing problems:
    @pro3d https://duet3d.dozuki.com/Wiki/Gcode#Section_M207_Set_retract_length
    In order to use firmware retraction with Cura you will need the printer settings plugin which will add a check box for it.
      Are you using the same values for speed, etc that were used previously in Marlin on your old controller?
      Perhaps experiment with increasing your speed, accel, and jerk settings for the Z axis and extruder to limit the amount of time spent on layer changes and retractions.
      Is Cura set to print outer layer first?
      Is coasting enabled in Cura?
      Is Cura set to always retract before outer layer?
      Are you using Combing in Cura travel settings?
      One way to limit the impact of the layer seam is to force Cura to place the seam in a particular XY location so that it stacks up in a column rather than being spread out in random spots on the surface.
      You may want to try retracting quickly, 60mm/s and unretracting slower 25mm/s
      undefined 2 Replies Last reply 5 Feb 2019, 23:00 Reply Quote 0
        pro3d @Phaedrux
        @phaedrux
        I am using standard everything that should work. Nothing special and same as with ramps
        I am out of options experimenting. I have used a lot of time troubleshooting no luck I am sorry. It is very sad I cant get this thing going normal
        Not done anything with outer layer - stock pla profile
        I disabled coasting in cura after enabling preassure advance. Tried with and without when no pa
        I have tried combing, no combing, within infill and not in skin so all of them are bad
        Valkyrie DIY High Temp 3D Printer
        R&D - Engineering Designer - Viking 3D Printers
        https://vkingprinter.com/
          pro3d @Phaedrux
          @phaedrux
          I will try and change the extruder but e3d have a big backlog... Have some clowns I could try
            pro3d
            This guy seem to have had the same issues as I do:
            https://forum.duet3d.com/topic/3998/retraction-issues-800mm-bowden-bondtech-bmg
            @Plecto ? solved?
              bartolomeus
              If you really want to solve this problem, please share your whole config.g. You are only providing half the information to the people who are trying to help you. From your post in the Facebook group it looks like you are using different values for the e3d thermistor, so that might be a starting point. Unless you are using a different thermistor. Hard to tell without the right information.
              undefined 1 Reply Last reply 6 Feb 2019, 05:49 Reply Quote 0
                pro3d @bartolomeus
                @bartolomeus
                What do you miss?
                I have just followed the steps in the guide, then changed some by advice but nothing in heaters
                M305 P0 T100000 B3925 R4700
                M143 H0 S120
                M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                M143 H1 S280
                undefined undefined 2 Replies Last reply 6 Feb 2019, 09:51 Reply Quote 0
                  deckingman @pro3d
                  @pro3d Thus far I have been reluctant to offer advice to someone with the esteemed title of "R&D - Lead Engineering Designer - V-King 3D Printers" but you seem to be getting desperate so here goes anyway.
                  I think you should go back to basics. Stop trying to solve everything by printing one particular model and print test parts that allow you to find settings for parameters in isolation of other factors.
                  So start by find what temperature works best on this particular machine. Every thermistor is different. Using a realistic but modest speed like 60mm/sec, print temperature towers and pick the lowest temperature that gives you a good surface finish. Temperature is hugely important as it affect the viscosity of the material and therefore it's tendency to ooze out of the nozzle of it's own volition. Make notes and keep a record of why you selected a particular temperature.
                  Then move on to printing retraction test parts. There are numerous examples on thingiverse and everyone has their own favourite. I prefer just two simple cubes spaced some distance apart. Firmware retraction (M207) is ideally suited to this because you can make changes on the fly and observe the effect. You need to set your slicer to use firmware retraction and it will insert G10 G11 commands.
                  Start with zero retraction then gradually increase it until stringing and blobs disappear. Do not go too high as you run the risk of pulling molten filament back up beyond the heat break where it will solidify. Try different retract and un-retract speeds. If you retract too fast you can end up stretching the molten filament rather than pulling it back up. Make sure your extruder speed and jerk settings are sufficiently high that the retraction speed is not being limited. Once you have found the ideal retract/un-retract settings you can then either use those settings in your slicer or continue to use firmware retraction. Again, take copious notes and annotate your config.g so that in the future you'll know why you've chosen certain values.
                  If you are unable to completely eliminate stringing and/or blobs, then there are a couple of things you could try. I hesitate to make suggestions here as you must know the machine better than I. One possibility is that during your testing, you may have pulled some filament up into the heat break and whilst it hasn't caused a complete blockage, it may be restricting the throat so the filament isn't sliding as smoothly as it could be. So it might be worth running a cleaning floss through the hot end. I don't have any direct experience of using it but I am assured by someone who is very knowledgable about such things that it can work wonders. This is what I'm talking about https://rigid.ink/products/floss-superior-cleaning-filament
                  One other thing that will help if it's possible is to reduce the length or straighten out the Bowden tube. TBH, it's always going to be difficult to get good prints with an 800mm long Bowden tube bent in half the way it seems to be from the picture I've seen of the V-King. If you can find a way to take the extruder off the frame and mount it centrally above the bed, I believe that would work wonders. It might look odd but it would work much better.
                  You could also try using Capricorn tubing which is made to a tighter tolerance. I didn't have much success with it myself but my Bowden tubes are only about 150 mm long. Other people have reported noticeable benefits, especially with longer tubes.
                  Oh and you have eliminated and movement of the Bowden tube itself within the fittings haven't you?
                  HTH
                  undefined 1 Reply Last reply 6 Feb 2019, 19:33 Reply Quote 3
                    bartolomeus @pro3d
                    @pro3d It is not what I miss, but you are only providing small bits of information. If you want help from experienced users here, provide the information they ask. So post your whole config.g instead of just parts of it.
                    From your heater settings, if you have the standard e3d thermistor, these should be the right settings: M305 P1 B4725 C7.060000e-8 (https://e3d-online.dozuki.com/Guide/V6+RepRap+Firmware+Configuration/26?lang=en)
                    Your setting is different, but I can't tell if this will affect the sensor readings. Maybe others can.
                      pro3d @Monster Delta
                      @monster-delta
                      Thanks but what am I supposed to do with M207 - where does that go and how do I use it - with G10/11?
                      undefined 1 Reply Last reply 6 Feb 2019, 19:28 Reply Quote 0
                        Phaedrux Moderator @pro3d
                        @pro3d said in Duet/RRF Big printing problems:
                        @monster-delta
                        M207 sets the parameters used for firmware retraction. To use G10/11 the slicer needs to be set to use firmware retraction which I described above for Cura which needs a plugin called printer settings.
                          pro3d @deckingman
                          @deckingman
                          Thanks for taking time to write a long feedback on my troublesome journey. This time around I did everything by the book and kept it simple stupid from the configurator with no extra features or specials to test the plug and play experience
                          I will try to change my hotend as it is my last hope to find it was a component and not the firmware
                          I want this to be a plug and play experience as the marlin controller is for this machine printing beautiful with same setup so I am not going to use so much time on the detailed calibration that you suggest I am sorry. Then I rather just add back the 8 bit controller and print
                          It is a shame to have this expensive controller and not be able to use it and be outperformed by a 16 dollar controller so I will try to get it working without going so deep in the tank as you want me to - it should not be necessary for a decent setup
                          • Firmware retraction
                            I still cant figure out how this is applied, it would be great to have
                          • Components
                            I will try another hotend as I also mistake this new thing to be cluttered and see if it helps
                            I have ordered a new extruder as well
                          • Bowden tube
                            The 800 mm bowden has been my friend long time with no issues with 6mm retraction in marlin no problem for 5000 hours at least. Does the rrf not support the same setup?
                            As of capricorn I have that as well but find it to tight and have a medial solution with 1.9mm as should work fine. Its the same as I have on the other machine
                            The play in the fittings has been eliminated
                          Thanks for trying to help me one more time
                          /roy
                            Perhaps you can post your configuration.h from Marlin along with your config.g from RepRapFirmware and we can compare to see if there is something amiss. Without giving useful information to us, you are only complaining, and not actually trying to find a solution.
                            I explained how to enable firmware retraction twice now. Here is a 3rd attempt at explaining: https://forum.duet3d.com/topic/5993/firmware-retraction-tuning-with-macros
                            undefined 1 Reply Last reply 6 Feb 2019, 20:02 Reply Quote 0
                              pro3d @Phaedrux
                              @phaedrux
                              I am all about giving useful information but dont know what before someone ask for it so I am sorry if it seams complaining - I am troubleshooting like crazy for long time now trying to find a solution
                              How am I not trying to find a solution?
                              The link you now posted gives me new info. I did not se this before and I have to put it aside for later
                              Here are all firmware info:
                              https://github.com/RoyBerntsenDesign/V-King/tree/master/Firmware Files
                                Thanks for the config files, I will take a look at them.
                                Next, what thermistor are you using and what parameters have you configured? If the temperature is being misreported that could explain the additional oozing.
                                undefined 2 Replies Last reply 6 Feb 2019, 20:08 Reply Quote 0
                                  pro3d @Phaedrux
                                  @phaedrux
                                  Also did you see this thread? looks like identical issues
                                  undefined 1 Reply Last reply 6 Feb 2019, 20:13 Reply Quote 0
                                    pro3d @Phaedrux
                                    @phaedrux
                                    Thermistor is what comes with the e3d V6 - Semitec GT something and configured with the online tool
                                    Edit: M305 P1 T100000 B4388 C7.060000e-8 R4700
                                    undefined 1 Reply Last reply 6 Feb 2019, 20:15 Reply Quote 0
                                      @phaedrux
                                      Yes, I saw that thread.
                                      Did you try the retraction tuning as David suggested in the thread?
                                      dc42 ADMINISTRATORS 5 Feb 2018, 06:26
                                      Some suggestions:
                                      Are the blobs are occurring immediately before retractions and travel moves? if so then they are probably mostly retraction-related.
                                      Increase extruder max speed in M203 to 3600 (i.e. 60mm/sec), and configure 60mm/sec retraction in speed in your slicer, or in M208 if you use firmware retraction
                                      800mm is a long Bowden tube, and you will need to tune your retraction settings and pressure advance well to get good results
                                      What retraction amounts have you tried? With no pressure advance applied and an 800mm Bowden tube I would expect you to need around 9mm retraction. Less if you use Capricorn tubing and/or pressure advance.
                                      With a Bowden tube that long, Capricorn tubing may help significantly.
                                      It's probably best to tune retraction using the Lite 6 first, because if you use too much retraction with the all-metal V6 you are likely to get an extruder blockage. When you have found a good combination of pressure advance and minimum needed retraction, you can try the same combination on the V6.
                                      I suggest initially you use no pressure advance, to find the minimum retraction you need to avoid getting zits just before travel moves. When you have found that value, add pressure advance (try 0.2) and see how much you can reduce retraction before the zits reappear.
                                      HTH David
                                      It also looks like someone commented that switch to capricorn tubing helped greatly for such a long bowden tube.
                                        @phaedrux
                                        That looks correct. Now have you run a PID tune on the hotend?
                                        undefined 2 Replies Last reply 6 Feb 2019, 20:31 Reply Quote 0
                                          pro3d @Phaedrux
                                          @phaedrux
                                          Yes PID has been applied
                                          As of the tip in the thread I have not been digging to much into it. I disabled PA now to start over again so I will take a closer look. The tube I have should work just fine as for X1000 hours before I think? It is a 1.9mm tube I like to use as the Capricorn can be to tight for my taste
                                          What I dont understand is that the proven settings from marlin will not work with rrf - like the retraction and speed and temp and everything. Does this have to do with that rrf use relative extrusion? Can I turn this off?
                                          undefined 1 Reply Last reply 6 Feb 2019, 20:40 Reply Quote 0
                                          14 out of 55
