CoreXY - X-Axis Vibration Issues
49
7.2k
    Veti
    its allowed to move in one direction to counteract slight alignment issues but it can not rotate.
    undefined 2 Replies Last reply 12 Feb 2019, 12:12 Reply Quote 0
      Syko_Symatic
      I think I understand, I am trying to look at your thingiverse link but the site is sooooo slow a the moment!
      undefined 1 Reply Last reply 13 Feb 2019, 10:59 Reply Quote 0
        Syko_Symatic @Veti
        @veti OK! So I have created a quick and dirty solution! I am going to print it in a few minutes and we will see if that solves the issue!
          Syko_Symatic @Veti
          @veti So unfortunately it didn't help. My solution wasn't perfect by any means but it didn't change at all. Hmm... any other ideas? I know without the belts in ran perfectly, so it's obviously being pulled by the belts (as I understand is pretty normal with corexy).
          undefined 1 Reply Last reply 12 Feb 2019, 14:41 Reply Quote 0
            deckingman @Syko_Symatic
            @syko_symatic Difficult to advise without a bit more information. All we know is that it's a CoreXY. Can you post some pictures -especially showing the belt arrangements. A bit better description of the problem would also help.
            Without having much to go on, I could make a shot in the dark and say that it might might be uneven belt tension that is imparting a twisting force which in turn is causing the guides to bind. The "classic" CoreXY belt patter usually shows the X carriage belts being quite a distance either side of the centre line of the X carriage. So if your belts are aligned like that, and the tension is uneven, then you might be getting a twisting force, which might be causing the guides to bind. I use stacked belts running along the centre line of the X carriage but you may not be able to do that easily.
            undefined 1 Reply Last reply 12 Feb 2019, 15:13 Reply Quote 0
              Veti
              also check that there is no twisting of the belts on direction change.
              i.e make a gcode file with rapid 5mm movement back and forth at high speed and look at the belts during this.
                Syko_Symatic @deckingman
                @deckingman Thanks, I will try and add some more info.
                The belt arrangment is stacked and looks almost exactly like e3d's tool changer machine. I have included a short video from the other night. The noise isn't an issue in that video as it doesn't occur until it's moving a little faster.
                Link
                I have tried increasing and decreasing belt tension to no avail. Could it possibly be motor setting related?
                  Veti
                  create a gcode that can replicate the noise.
                  Then while its making the noise try to narrow down the location.
                  the frame looks like it could be resonating at certain frequencies.
                  undefined 1 Reply Last reply 12 Feb 2019, 16:09 Reply Quote 0
                    Syko_Symatic @Veti
                    @veti It definitely sounds like it's coming from the x-axis carriage. I am going to give tuning the acceleration and max speed a go. Any suggestions of a good starting point?
                      mrehorstdmd
                      Is the X axis linear guide a "preload" type? How is the X axis rail mounted so that it can slide? If it is free to move, it may be free to rattle, depending on how it's mounted.
                      undefined 1 Reply Last reply 12 Feb 2019, 18:46 Reply Quote 0
                        Veti
                        how stable is the x carriage? Push the nozzle in different directions and see if there is play.
                        Also check the fans. I had some fans that created a rattle caused by the blades moving inside the fan at higher speeds. and banging on the casing
                          Syko_Symatic @mrehorstdmd
                          @mrehorstdmd yes it’s preloaded. It is secured to a cross-brace by a few cap head screws.
                            fcwilt
                            It's hard to tell from the video but are the belts on either side of the X slide parallel to the slide?
                            undefined 1 Reply Last reply 12 Feb 2019, 21:56 Reply Quote 0
                              Syko_Symatic @fcwilt
                              @fcwilt as best as I can get them. I’m going to try re-aligning everything again. Annoying, but I am going to wait for some new gates pulleys from E3D to make sure everything is the best it can be.
                              Or maybe I will re-align it all first? I can’t decide. Either way I will keep trying.
                              undefined 1 Reply Last reply 12 Feb 2019, 22:00 Reply Quote 0
                                fcwilt @Syko_Symatic
                                @syko_symatic
                                Well I think it has to be something about your build.
                                I built a D-Bot CoreXY printer and it has no binding issues at all. BUT it uses wheels-on-extrusion tech, not slides.
                                My next CoreXY will try slides.
                                undefined 2 Replies Last reply 12 Feb 2019, 22:02 Reply Quote 0
                                  @fcwilt my thoughts exactly hence the slight rebuild. At least I can do it by only removing the top plate!
                                    Gear @Syko_Symatic
                                    @syko_symatic just press f5 untill it loads ...
                                      @fcwilt Having a think about it, the E3D design uses the fabtotum style corexy which places the belts in front and behind the x carriage. It is technically possible to move them both behind the carriage, would that help?
                                      undefined undefined 2 Replies Last reply 14 Feb 2019, 10:28 Reply Quote 0
                                        @syko_symatic said in CoreXY - X-Axis Vibration Issues:
                                        It might. But moving both belts to the centre line of the X carriage would be better - as per my post of 12th Feb above.
                                        undefined 1 Reply Last reply 14 Feb 2019, 11:37 Reply Quote 0
                                          @deckingman Without a massive change to the placement of pulleys and such it's unfortunately not possible.
                                          13 out of 49
