    CoreXY - X-Axis Vibration Issues
    49
    7.3k
    • Syko_Symaticundefined
      Syko_Symatic @Veti
      @veti OK! So I have created a quick and dirty solution! I am going to print it in a few minutes and we will see if that solves the issue!
        Syko_Symatic @Veti
        @veti So unfortunately it didn't help. My solution wasn't perfect by any means but it didn't change at all. Hmm... any other ideas? I know without the belts in ran perfectly, so it's obviously being pulled by the belts (as I understand is pretty normal with corexy).
          deckingman @Syko_Symatic
          @syko_symatic Difficult to advise without a bit more information. All we know is that it's a CoreXY. Can you post some pictures -especially showing the belt arrangements. A bit better description of the problem would also help.
          Without having much to go on, I could make a shot in the dark and say that it might might be uneven belt tension that is imparting a twisting force which in turn is causing the guides to bind. The "classic" CoreXY belt patter usually shows the X carriage belts being quite a distance either side of the centre line of the X carriage. So if your belts are aligned like that, and the tension is uneven, then you might be getting a twisting force, which might be causing the guides to bind. I use stacked belts running along the centre line of the X carriage but you may not be able to do that easily.
          Syko_Symaticundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti
            also check that there is no twisting of the belts on direction change.
            i.e make a gcode file with rapid 5mm movement back and forth at high speed and look at the belts during this.
              Syko_Symatic @deckingman
              @deckingman Thanks, I will try and add some more info.
              The belt arrangment is stacked and looks almost exactly like e3d's tool changer machine. I have included a short video from the other night. The noise isn't an issue in that video as it doesn't occur until it's moving a little faster.
              Link
              I have tried increasing and decreasing belt tension to no avail. Could it possibly be motor setting related?
              • Vetiundefined
                Veti
                create a gcode that can replicate the noise.
                Then while its making the noise try to narrow down the location.
                the frame looks like it could be resonating at certain frequencies.
                  Syko_Symatic @Veti
                  @veti It definitely sounds like it's coming from the x-axis carriage. I am going to give tuning the acceleration and max speed a go. Any suggestions of a good starting point?
                  • mrehorstdmdundefined
                    mrehorstdmd
                    Is the X axis linear guide a "preload" type? How is the X axis rail mounted so that it can slide? If it is free to move, it may be free to rattle, depending on how it's mounted.
                    • Vetiundefined
                      Veti
                      how stable is the x carriage? Push the nozzle in different directions and see if there is play.
                      Also check the fans. I had some fans that created a rattle caused by the blades moving inside the fan at higher speeds. and banging on the casing
                        Syko_Symatic @mrehorstdmd
                        @mrehorstdmd yes it’s preloaded. It is secured to a cross-brace by a few cap head screws.
                        • fcwiltundefined
                          fcwilt
                          It's hard to tell from the video but are the belts on either side of the X slide parallel to the slide?
                            Syko_Symatic @fcwilt
                            @fcwilt as best as I can get them. I’m going to try re-aligning everything again. Annoying, but I am going to wait for some new gates pulleys from E3D to make sure everything is the best it can be.
                            Or maybe I will re-align it all first? I can’t decide. Either way I will keep trying.
                            • fcwiltundefined
                              fcwilt @Syko_Symatic
                              @syko_symatic
                              Well I think it has to be something about your build.
                              I built a D-Bot CoreXY printer and it has no binding issues at all. BUT it uses wheels-on-extrusion tech, not slides.
                              My next CoreXY will try slides.
                              Syko_Symaticundefined 2 Replies Last reply Reply Quote 0
                                @fcwilt my thoughts exactly hence the slight rebuild. At least I can do it by only removing the top plate!
                                • Gearundefined
                                  Gear @Syko_Symatic
                                  @syko_symatic just press f5 untill it loads ...
                                    @fcwilt Having a think about it, the E3D design uses the fabtotum style corexy which places the belts in front and behind the x carriage. It is technically possible to move them both behind the carriage, would that help?
                                    deckingmanundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                      @syko_symatic said in CoreXY - X-Axis Vibration Issues:
                                      It might. But moving both belts to the centre line of the X carriage would be better - as per my post of 12th Feb above.
                                        @deckingman Without a massive change to the placement of pulleys and such it's unfortunately not possible.
                                          mrehorstdmd
                                          I don't think belt attachment at the extruder carriage is an issue. My printer uses linear guides in all axes and the belts are offset both vertically and laterally and there's no problem with vibration or noise.
                                          Here are the belt clamps on the extruder carriage in my printer (the carriage has changed a lot since this photo but the belt attachment is the same).
                                          If your X axis rail is able to move that means it isn't clamped securely- the hole it sits in has to be bigger than the rail or the rail couldn't move. That means it can flop around inside the hole which will cause rattling/buzzing/vibrating. I'd probably start by clamping the rail securely there and see if the noise goes away.
                                          Here's my printer's XY stage. The X axis rail is bolted to the Y axis bearing block at P1, and it's attached to the other Y axis bearing block using an extra X axis bearing block at P2. The X axis rail can move in the X direction when the printer heats up and the Y axis rails move apart, but it can't move in any other direction. There's no noise or vibration, and the mechanism never binds.
                                          • fcwiltundefined
                                            My D-Bot has belts in front and behind. It seems to be working just fine.
                                            Have you visited this site, it has some good information:
                                            https://drmrehorst.blogspot.com/2018/08/corexy-mechanism-layout-and-belt.html
