    PEI coated flex-plate system
    3D Printing General Chat
    13
    50
    6.3k
    • gavatron3000undefined
      gavatron3000
      I shared your Kickstarter with 3d printing Australia group also. A few people interested there
      klcjr89undefined 1 Reply Last reply Reply Quote 0
      • klcjr89undefined
        klcjr89 @gavatron3000
        @gavatron3000 said in PEI coated flex-plate system:
        You have no idea how much that means to me. I am very humbled ☺
        Thank you!
        • Dougal1957undefined
          Dougal1957 @klcjr89
          @klcjr89 I have also shared it on the 3D-Printers Discord server
          3Dprinting
          • klcjr89undefined
            klcjr89 @Dougal1957
            @dougal1957 Doug, thank you for that!
            Are you still enjoying your Nimble?
              Dougal1957 @klcjr89
              @klcjr89 Oh yes best upgrade I ever made in fact I have a sidewinder waiting for me to finish my CoreXY Build.
              Any chance you could do your bed plates any larger my delta is 370 diamater and my CoreXY will be 450x450
              • klcjr89undefined
                klcjr89 @Dougal1957
                @dougal1957 said in PEI coated flex-plate system:
                Doug, we can make any size in the future if the campaign is funded. To make sizes greater than 310mm requires the purchase of 10 tons of steel in larger widths, as that is the minimum order quantity unfortunately.
                  Dougal1957 @klcjr89
                  @klcjr89 Yeah I can see why that would be prohibitive. Have seen your comments on the discord as well (I'm lil doug on there)
                  • klcjr89undefined
                    klcjr89
                    Update: we are now offering double sided coated options to satisfy as many people as possible. 🙂
                    • klcjr89undefined
                      klcjr89
                      Update: we are now offering sizes up to 350mm and have lowered the costs of rewards! We have streamlined the reward tiers to make it less cluttered. You can also buy just a flex-plate now, whereas before we required the purchase of two at a time. ☺
                      Martin1454undefined 1 Reply Last reply Reply Quote 1
                      • Martin1454undefined
                        Martin1454 @klcjr89
                        @klcjr89 hope it will succeed 🙂
                        Also - Can you share an image of how the underside of a print looks when it is printed on the surface? 🙂
                        klcjr89undefined 2 Replies Last reply Reply Quote 0
                        • andornotundefined
                          andornot
                          I already have a flexible bed system available for duplicator 3i, ender 3 and cr10. The magnetic sheet can be cut to size to suit and any printer with a bed size up 310mm x 310mm and i will customise the flexible steel top to suit other printer requirements if required. It does not have a PEI sheet but these can be purchased separately, along with other bed materials to suit your requirement.
                          SpatialOne custom delta printer, upgrading to print PEEK, PEKK & Ultem
                            deckingman
                            No criticising the product in any way but looking at the video in the first post, that first layer was being printed soooo slowly compared to what I'm used to. Is that normal for PEI? What sort of speeds do you guys print your first layers at?
                            klcjr89undefined 1 Reply Last reply Reply Quote 1
                            • klcjr89undefined
                              klcjr89 @deckingman
                              @deckingman said in PEI coated flex-plate system:
                              That is slow motion filming, not slow printing 🙂
                              • klcjr89undefined
                                klcjr89 @Martin1454
                                @martin1454 said in PEI coated flex-plate system:
                                There is a shot in the video that shows this, but I'll try to get a still image.
                                  deckingman @klcjr89
                                  @klcjr89 said in PEI coated flex-plate system:
                                  Ahh OK. But can you or anyone else answer my second question. i.e. what sort of first layer speed is reasonable when using PEI?
                                  Like I said, this is on no way any sort of criticism of the product - just wondering that's all.
                                  • klcjr89undefined
                                    klcjr89 @deckingman
                                    @deckingman For PETG, I print the first layer at 25 mm/s, which is 50% of my normal printing speed of 50 mm/s.
                                      deckingman @klcjr89
                                      Thanks. I never did get PrintBite to work - maybe that's the reason (I just didn't slow things down enough). Good luck with your Kickstarter campaign. I mean that sincerely as it looks like a good product even though it's not for me.
                                      • klcjr89undefined
                                        klcjr89 @Martin1454
                                        Will this image suffice? 🙂
                                          Martin1454 @klcjr89
                                          @klcjr89 Perfect! - just what is was looking for 🙂
                                          • klcjr89undefined
                                            klcjr89 @Martin1454
                                            What do you think of the texture? 🙂
                                            Martin1454undefined 1 Reply Last reply Reply Quote 0
