    Duet Web Control 2.0.0-RC6
    Duet Web Control
    35
    64
    11.4k
    • AlexLinundefined
      AlexLin
      how can I 'pin' the fan speedin DWC 2?
      • EDHundefined
        EDH
        Extrusion control buttons 'Retract' and 'Extrude' are greyed out after RC6. Even when the hotend is hot. While /reprap.htm is working fine.
        • c310undefined
          c310
          what had happened to language files / localization ?
          • c310undefined
            c310
            unchecking ToolFan in "change visibility" shows error $t('panel.fans.noFans') }}
            • garyd9undefined
              garyd9 @chrishamm
              @chrishamm
              DWC2 RC6, MacOS, Chrome 72.0.3626.121
              Is there any way to adjust the size of the navigation panel on the left side of DWC2? I know I can completely remove it, but I'd rather just make it smaller (so it takes up less horizontal space.) The reason for asking is that when the navigation panel is exposed (which I prefer), the rest of the browser page looks poorly squeezed into the available space. Here's an example from my (very old) MBP:
              Notice that the temperatures numbers (middle box) are all truncated and the the temperature graph looks very thin. (Also, what's going on with the temp graph legend for MCU? It doesn't look like a dashed line at all... The first time I saw it, I thought my son had attacked my screen with a magic marker.)
              Thank you
              Gary
              • gideonundefined
                gideon
                the macro continues to load and nothing can be seen
                • chrishammundefined
                  chrishamm administrators
                  @NicoLab28 @c310 Thanks, I'll fix both in the next version.
                  @c310 Localization support has been implemented but I haven't added any translations yet. If you wish to contribute, feel free to translate this file https://github.com/chrishamm/DuetWebControl/blob/next/src/i18n/en.js and send it over to me. We still need to find a solution for keeping them up-to-date though - perhaps a mailing list would be good.
                  @garyd9 You can hide the navigation menu by clicking on the button in the top left corner. That is supposed to happen automatically when the screen width becomes too low. Can you tell me what resolution you use on your MBP?
                  @gideon That's quite odd. Do you have a lot of files in your macros directory?
                  Duet software engineer
                  c310undefined AlexLinundefined gideonundefined garyd9undefined 4 Replies Last reply Reply Quote 0
                  • c310undefined
                    c310 @chrishamm
                    @chrishamm said in Duet Web Control 2.0.0-RC6:
                    i can do Russian, but belive @Monderlog have done that.
                    perhaps you can publish ru.js on github and we will review that
                    • AlexLinundefined
                      AlexLin @chrishamm
                      @chrishamm probably trivial but : how can I 'pin' the fan speed in DWC 2?
                      • gideonundefined
                        gideon @chrishamm
                        @chrishamm i have 10 macro's
                        gideonundefined 1 Reply Last reply Reply Quote 0
                        • dragonnundefined
                          dragonn
                          @chrishamm
                          small bug:
                          I added a chamber heater with some fans on it.
                          This fan is created with that commands:
                              M307 H3 A-1 C-1 D-1
                              M106 P3 S0 I0 F100  H-1 B0.5 C"Chamber" A3 L0.23; Heated chamber fan
                          And it doesn't show up when I select it in visibility
                          • gideonundefined
                            gideon @gideon
                            @gideon said in Duet Web Control 2.0.0-RC6:
                            now it works.
                            • tonypundefined
                              tonyp
                              This is great! I was considering forking and doing a more modern UI.
                              Will test and write back with any issues 👍
                              • garyd9undefined
                                garyd9 @chrishamm
                                1440x900. (It's an older MBP.)
                                Take care
                                Gary
                                • Red Sand Robotundefined
                                  Red Sand Robot
                                  I commented on an earlier release of DWC, I believe RC4 or 5? Anyway, my issue was that the height map was storing correcting and applying software correction to my print, but the image of the height map would not display.
                                  It turns out this was due to the browser I was using! Apparently Brave (a browser based on chromium that natively blocks ads/popups/trackers) does not allow for that image to refresh or display for some reason. When I pulled up DWC with Firefox it displayed perfectly fine.
                                  almost an engineer
                                  • Mikeundefined
                                    Mike
                                    A minor note - is the Fan RPM reading gone for good? There seems to be no way to either toggle or display it in DWC 2.
                                    • wilrikerundefined
                                      wilriker @Mike
                                      @mike I miss that as well. Jumped through all the hoops to read it out and no it's no longer displayed - I would very happily treat it for the Z probe value since I do not even have a Z probe. 😂
                                      Manuel
                                      My Tool Collection
                                      • fotomasundefined
                                        fotomas
                                        Feature request / idea: temperature of heater in degrees or percent o taget temp in the title/heading.
                                        So when a print is started I can se the progress of heating up, then when the printing starts it switches to print progress as of today.
                                        Great new GUI, keep up the good work!
                                        • smoki3undefined
                                          smoki3
                                          mponents (also fixes a bug that caused all inputs to stop working once the heightmap was activated)
                                          Changed click behaviour of file list items to be activated on a single click again
                                          Added touch events to event+file lists to show the context menu on devices that do not support the native JS contextmenu event
                                          Print information is no longer cleared when a print finishes
                                          Simplified file list reset when the connection is interrupted
                                          Print+Simulate options are hidden when a job file is being processed
                                          Escape closes the text editor again
                                          Height map is automatically reloaded once 'heightmap.csv' shows up in a G-code response
                                          Minor other changes
                                          Bug fix: Notification when editing a large file was not displayed during download
                                          Bug fix: Macro list did not return to the root directory when the connection was interrupted
                                          Bug fix: Warm-up time was not displayed
                                          Bug fix: Selected tool was no longer highlighted when the light theme was selected
                                          Bug fix: Drag&Drop was completely broken in Chrome and the drag animation stopped working anywhere
                                          For me drag and drop in chrome is still not working. It always shows me the opended gcode
                                          JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                                          • JohnOCFIIundefined
                                            JohnOCFII @smoki3
                                            Agreed - in Chrome or Safari on my Mac, drag and drop to drag files from my desktop to the GCode files directory does not work.
                                            @smoki3 said in Duet Web Control 2.0.0-RC6:
                                            smoki3undefined 1 Reply Last reply Reply Quote 0
