    Duet Web Control 2.0.0-RC6
    Duet Web Control
    35
    64
    11.2k
    • dragonnundefined
      dragonn
      @chrishamm
      small bug:
      I added a chamber heater with some fans on it.
      This fan is created with that commands:
          M307 H3 A-1 C-1 D-1
          M106 P3 S0 I0 F100  H-1 B0.5 C"Chamber" A3 L0.23; Heated chamber fan
      And it doesn't show up when I select it in visibility
      • gideonundefined
        gideon @gideon
        @gideon said in Duet Web Control 2.0.0-RC6:
        @chrishamm i have 10 macro's
        now it works.
        • tonypundefined
          tonyp
          This is great! I was considering forking and doing a more modern UI.
          Will test and write back with any issues 👍
          • garyd9undefined
            garyd9 @chrishamm
            @chrishamm said in Duet Web Control 2.0.0-RC6:
            @garyd9 You can hide the navigation menu by clicking on the button in the top left corner. That is supposed to happen automatically when the screen width becomes too low. Can you tell me what resolution you use on your MBP?
            1440x900. (It's an older MBP.)
            Take care
            Gary
            • Red Sand Robotundefined
              Red Sand Robot
              I commented on an earlier release of DWC, I believe RC4 or 5? Anyway, my issue was that the height map was storing correcting and applying software correction to my print, but the image of the height map would not display.
              It turns out this was due to the browser I was using! Apparently Brave (a browser based on chromium that natively blocks ads/popups/trackers) does not allow for that image to refresh or display for some reason. When I pulled up DWC with Firefox it displayed perfectly fine.
              almost an engineer
              • Mikeundefined
                Mike
                A minor note - is the Fan RPM reading gone for good? There seems to be no way to either toggle or display it in DWC 2.
                • wilrikerundefined
                  wilriker @Mike
                  @mike I miss that as well. Jumped through all the hoops to read it out and no it's no longer displayed - I would very happily treat it for the Z probe value since I do not even have a Z probe. 😂
                  Manuel
                  My Tool Collection
                  • fotomasundefined
                    fotomas
                    Feature request / idea: temperature of heater in degrees or percent o taget temp in the title/heading.
                    So when a print is started I can se the progress of heating up, then when the printing starts it switches to print progress as of today.
                    Great new GUI, keep up the good work!
                    • smoki3undefined
                      smoki3
                      mponents (also fixes a bug that caused all inputs to stop working once the heightmap was activated)
                      Changed click behaviour of file list items to be activated on a single click again
                      Added touch events to event+file lists to show the context menu on devices that do not support the native JS contextmenu event
                      Print information is no longer cleared when a print finishes
                      Simplified file list reset when the connection is interrupted
                      Print+Simulate options are hidden when a job file is being processed
                      Escape closes the text editor again
                      Height map is automatically reloaded once 'heightmap.csv' shows up in a G-code response
                      Minor other changes
                      Bug fix: Notification when editing a large file was not displayed during download
                      Bug fix: Macro list did not return to the root directory when the connection was interrupted
                      Bug fix: Warm-up time was not displayed
                      Bug fix: Selected tool was no longer highlighted when the light theme was selected
                      Bug fix: Drag&Drop was completely broken in Chrome and the drag animation stopped working anywhere
                      For me drag and drop in chrome is still not working. It always shows me the opended gcode
                      JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                      • JohnOCFIIundefined
                        JohnOCFII @smoki3
                        Agreed - in Chrome or Safari on my Mac, drag and drop to drag files from my desktop to the GCode files directory does not work.
                        @smoki3 said in Duet Web Control 2.0.0-RC6:
                        smoki3undefined 1 Reply Last reply Reply Quote 0
                        • smoki3undefined
                          smoki3 @JohnOCFII
                          @johnocfii yes I am only on mac.
                          @chrishamm I also noticed that I can not move the cursor my the arrow keys in the editor
                          • Synapsisundefined
                            Synapsis
                            I looked everywhere but can't find Machine Properties to endstops ecc.
                            Also is it possible to make the webcam image fill the space?0_1552945755266_webcam.PNG
                            In DWC2 the cam image takes much longer to loads than the old interface.
                            Thanks
                            • quarky42undefined
                              quarky42
                              At the risk of asking a dumb question, What is the minimum Duet 2 Maestro firmware I should be running before installing the Duet Web Control 2.0.0-RC6 firmware? (I think I'm on RC5 of the Web Control, but I am not in front my printer right now. I suspect that my Duet 2 Maestro firmware is 2.02, but I would verify that before applying any Duet Web Control firmware upgrade.
                                Phaedrux Moderator @quarky42
                                @quarky42 2.02 and DWC 2RC6 will be fine together
                                • c310undefined
                                  c310
                                  i think "show mesh bed compensation" map is missing in "compensation & calibration"
                                  c310undefined 1 Reply Last reply Reply Quote 0
                                  • c310undefined
                                    c310
                                    moving speed slider to "1" generates error message - M220 S1 invalid speed factor
                                    i think there should be a simple check - if speed is below 1, speed = 1 🙂 this should be done before sending speed to firmware.
                                    • c310undefined
                                      c310
                                      suggestion to the time estimation section... too many words now and not easy to read
                                      1. add words based on after "Estimations" --> "Estimations based on:"
                                      2. remove these words afterwards
                                        "Based on filament usage" ---> "...filament usage"
                                      3. change color of list items OR color of data: "filament usage" can be white and time value can be light yellow or other non-white color
                                      • c310undefined
                                        c310 @c310
                                        @c310 said in Duet Web Control 2.0.0-RC6:
                                        height map has no use in main menu.
                                        • brunofportoundefined
                                          brunofporto
                                          This is just gorgeous!!! Congratulations!
                                          Thank you very much!
                                            brunofporto
                                            The Slicer or simulation time estimations showed during print starts counting during warm-up time.
