    Duet Web Control 2.0.0-RC6
    Duet Web Control
    35
    64
    11.3k
    • chrishammundefined
      chrishamm administrators
      @NicoLab28 @c310 Thanks, I'll fix both in the next version.
      @c310 Localization support has been implemented but I haven't added any translations yet. If you wish to contribute, feel free to translate this file https://github.com/chrishamm/DuetWebControl/blob/next/src/i18n/en.js and send it over to me. We still need to find a solution for keeping them up-to-date though - perhaps a mailing list would be good.
      @garyd9 You can hide the navigation menu by clicking on the button in the top left corner. That is supposed to happen automatically when the screen width becomes too low. Can you tell me what resolution you use on your MBP?
      @gideon That's quite odd. Do you have a lot of files in your macros directory?
      Duet software engineer
      c310undefined AlexLinundefined gideonundefined garyd9undefined 4 Replies Last reply Reply Quote 0
      • c310undefined
        c310 @chrishamm
        @chrishamm said in Duet Web Control 2.0.0-RC6:
        i can do Russian, but belive @Monderlog have done that.
        perhaps you can publish ru.js on github and we will review that
        • AlexLinundefined
          AlexLin @chrishamm
          @chrishamm probably trivial but : how can I 'pin' the fan speed in DWC 2?
          • gideonundefined
            gideon @chrishamm
            @chrishamm i have 10 macro's
            gideonundefined 1 Reply Last reply Reply Quote 0
            • dragonnundefined
              dragonn
              @chrishamm
              small bug:
              I added a chamber heater with some fans on it.
              This fan is created with that commands:
                  M307 H3 A-1 C-1 D-1
                  M106 P3 S0 I0 F100  H-1 B0.5 C"Chamber" A3 L0.23; Heated chamber fan
              And it doesn't show up when I select it in visibility
              • gideonundefined
                gideon @gideon
                @gideon said in Duet Web Control 2.0.0-RC6:
                now it works.
                • tonypundefined
                  tonyp
                  This is great! I was considering forking and doing a more modern UI.
                  Will test and write back with any issues 👍
                  • garyd9undefined
                    garyd9 @chrishamm
                    1440x900. (It's an older MBP.)
                    Take care
                    Gary
                    • Red Sand Robotundefined
                      Red Sand Robot
                      I commented on an earlier release of DWC, I believe RC4 or 5? Anyway, my issue was that the height map was storing correcting and applying software correction to my print, but the image of the height map would not display.
                      It turns out this was due to the browser I was using! Apparently Brave (a browser based on chromium that natively blocks ads/popups/trackers) does not allow for that image to refresh or display for some reason. When I pulled up DWC with Firefox it displayed perfectly fine.
                      almost an engineer
                      • Mikeundefined
                        Mike
                        A minor note - is the Fan RPM reading gone for good? There seems to be no way to either toggle or display it in DWC 2.
                        • wilrikerundefined
                          wilriker @Mike
                          @mike I miss that as well. Jumped through all the hoops to read it out and no it's no longer displayed - I would very happily treat it for the Z probe value since I do not even have a Z probe. 😂
                          Manuel
                          My Tool Collection
                          • fotomasundefined
                            fotomas
                            Feature request / idea: temperature of heater in degrees or percent o taget temp in the title/heading.
                            So when a print is started I can se the progress of heating up, then when the printing starts it switches to print progress as of today.
                            Great new GUI, keep up the good work!
                            • smoki3undefined
                              smoki3
                              mponents (also fixes a bug that caused all inputs to stop working once the heightmap was activated)
                              Changed click behaviour of file list items to be activated on a single click again
                              Added touch events to event+file lists to show the context menu on devices that do not support the native JS contextmenu event
                              Print information is no longer cleared when a print finishes
                              Simplified file list reset when the connection is interrupted
                              Print+Simulate options are hidden when a job file is being processed
                              Escape closes the text editor again
                              Height map is automatically reloaded once 'heightmap.csv' shows up in a G-code response
                              Minor other changes
                              Bug fix: Notification when editing a large file was not displayed during download
                              Bug fix: Macro list did not return to the root directory when the connection was interrupted
                              Bug fix: Warm-up time was not displayed
                              Bug fix: Selected tool was no longer highlighted when the light theme was selected
                              Bug fix: Drag&Drop was completely broken in Chrome and the drag animation stopped working anywhere
                              For me drag and drop in chrome is still not working. It always shows me the opended gcode
                              JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                              • JohnOCFIIundefined
                                JohnOCFII @smoki3
                                Agreed - in Chrome or Safari on my Mac, drag and drop to drag files from my desktop to the GCode files directory does not work.
                                @smoki3 said in Duet Web Control 2.0.0-RC6:
                                smoki3undefined 1 Reply Last reply Reply Quote 0
                                • smoki3undefined
                                  smoki3 @JohnOCFII
                                  @johnocfii yes I am only on mac.
                                  @chrishamm I also noticed that I can not move the cursor my the arrow keys in the editor
                                  • Synapsisundefined
                                    Synapsis
                                    I looked everywhere but can't find Machine Properties to endstops ecc.
                                    Also is it possible to make the webcam image fill the space?0_1552945755266_webcam.PNG
                                    In DWC2 the cam image takes much longer to loads than the old interface.
                                    Thanks
                                    • quarky42undefined
                                      quarky42
                                      At the risk of asking a dumb question, What is the minimum Duet 2 Maestro firmware I should be running before installing the Duet Web Control 2.0.0-RC6 firmware? (I think I'm on RC5 of the Web Control, but I am not in front my printer right now. I suspect that my Duet 2 Maestro firmware is 2.02, but I would verify that before applying any Duet Web Control firmware upgrade.
                                        Phaedrux Moderator @quarky42
                                        @quarky42 2.02 and DWC 2RC6 will be fine together
                                        • c310undefined
                                          c310
                                          i think "show mesh bed compensation" map is missing in "compensation & calibration"
                                          c310undefined 1 Reply Last reply Reply Quote 0
                                          • c310undefined
                                            c310
                                            moving speed slider to "1" generates error message - M220 S1 invalid speed factor
                                            i think there should be a simple check - if speed is below 1, speed = 1 🙂 this should be done before sending speed to firmware.
