    Duet Web Control 2.0.0-RC6
    Duet Web Control
    35
    64
    11.3k
    • garyd9undefined
      garyd9 @chrishamm
      @chrishamm
      DWC2 RC6, MacOS, Chrome 72.0.3626.121
      Is there any way to adjust the size of the navigation panel on the left side of DWC2? I know I can completely remove it, but I'd rather just make it smaller (so it takes up less horizontal space.) The reason for asking is that when the navigation panel is exposed (which I prefer), the rest of the browser page looks poorly squeezed into the available space. Here's an example from my (very old) MBP:
      Notice that the temperatures numbers (middle box) are all truncated and the the temperature graph looks very thin. (Also, what's going on with the temp graph legend for MCU? It doesn't look like a dashed line at all... The first time I saw it, I thought my son had attacked my screen with a magic marker.)
      Thank you
      Gary
      • gideonundefined
        gideon
        the macro continues to load and nothing can be seen
        • chrishammundefined
          chrishamm administrators
          @NicoLab28 @c310 Thanks, I'll fix both in the next version.
          @c310 Localization support has been implemented but I haven't added any translations yet. If you wish to contribute, feel free to translate this file https://github.com/chrishamm/DuetWebControl/blob/next/src/i18n/en.js and send it over to me. We still need to find a solution for keeping them up-to-date though - perhaps a mailing list would be good.
          @garyd9 You can hide the navigation menu by clicking on the button in the top left corner. That is supposed to happen automatically when the screen width becomes too low. Can you tell me what resolution you use on your MBP?
          @gideon That's quite odd. Do you have a lot of files in your macros directory?
          Duet software engineer
          c310undefined AlexLinundefined gideonundefined garyd9undefined 4 Replies Last reply Reply Quote 0
          • c310undefined
            c310 @chrishamm
            @chrishamm said in Duet Web Control 2.0.0-RC6:
            i can do Russian, but belive @Monderlog have done that.
            perhaps you can publish ru.js on github and we will review that
            • AlexLinundefined
              AlexLin @chrishamm
              @chrishamm probably trivial but : how can I 'pin' the fan speed in DWC 2?
              • gideonundefined
                gideon @chrishamm
                @chrishamm i have 10 macro's
                gideonundefined 1 Reply Last reply Reply Quote 0
                • dragonnundefined
                  dragonn
                  @chrishamm
                  small bug:
                  I added a chamber heater with some fans on it.
                  This fan is created with that commands:
                      M307 H3 A-1 C-1 D-1
                      M106 P3 S0 I0 F100  H-1 B0.5 C"Chamber" A3 L0.23; Heated chamber fan
                  And it doesn't show up when I select it in visibility
                  • gideonundefined
                    gideon @gideon
                    @gideon said in Duet Web Control 2.0.0-RC6:
                    now it works.
                    • tonypundefined
                      tonyp
                      This is great! I was considering forking and doing a more modern UI.
                      Will test and write back with any issues 👍
                      • garyd9undefined
                        garyd9 @chrishamm
                        1440x900. (It's an older MBP.)
                        Take care
                        Gary
                        • Red Sand Robotundefined
                          Red Sand Robot
                          I commented on an earlier release of DWC, I believe RC4 or 5? Anyway, my issue was that the height map was storing correcting and applying software correction to my print, but the image of the height map would not display.
                          It turns out this was due to the browser I was using! Apparently Brave (a browser based on chromium that natively blocks ads/popups/trackers) does not allow for that image to refresh or display for some reason. When I pulled up DWC with Firefox it displayed perfectly fine.
                          almost an engineer
                          • Mikeundefined
                            Mike
                            A minor note - is the Fan RPM reading gone for good? There seems to be no way to either toggle or display it in DWC 2.
                            • wilrikerundefined
                              wilriker @Mike
                              @mike I miss that as well. Jumped through all the hoops to read it out and no it's no longer displayed - I would very happily treat it for the Z probe value since I do not even have a Z probe. 😂
                              Manuel
                              My Tool Collection
                              • fotomasundefined
                                fotomas
                                Feature request / idea: temperature of heater in degrees or percent o taget temp in the title/heading.
                                So when a print is started I can se the progress of heating up, then when the printing starts it switches to print progress as of today.
                                Great new GUI, keep up the good work!
                                • smoki3undefined
                                  smoki3
                                  mponents (also fixes a bug that caused all inputs to stop working once the heightmap was activated)
                                  Changed click behaviour of file list items to be activated on a single click again
                                  Added touch events to event+file lists to show the context menu on devices that do not support the native JS contextmenu event
                                  Print information is no longer cleared when a print finishes
                                  Simplified file list reset when the connection is interrupted
                                  Print+Simulate options are hidden when a job file is being processed
                                  Escape closes the text editor again
                                  Height map is automatically reloaded once 'heightmap.csv' shows up in a G-code response
                                  Minor other changes
                                  Bug fix: Notification when editing a large file was not displayed during download
                                  Bug fix: Macro list did not return to the root directory when the connection was interrupted
                                  Bug fix: Warm-up time was not displayed
                                  Bug fix: Selected tool was no longer highlighted when the light theme was selected
                                  Bug fix: Drag&Drop was completely broken in Chrome and the drag animation stopped working anywhere
                                  For me drag and drop in chrome is still not working. It always shows me the opended gcode
                                  JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                                  • JohnOCFIIundefined
                                    JohnOCFII @smoki3
                                    Agreed - in Chrome or Safari on my Mac, drag and drop to drag files from my desktop to the GCode files directory does not work.
                                    @smoki3 said in Duet Web Control 2.0.0-RC6:
                                    smoki3undefined 1 Reply Last reply Reply Quote 0
                                    • smoki3undefined
                                      smoki3 @JohnOCFII
                                      @johnocfii yes I am only on mac.
                                      @chrishamm I also noticed that I can not move the cursor my the arrow keys in the editor
                                      • Synapsisundefined
                                        Synapsis
                                        I looked everywhere but can't find Machine Properties to endstops ecc.
                                        Also is it possible to make the webcam image fill the space?0_1552945755266_webcam.PNG
                                        In DWC2 the cam image takes much longer to loads than the old interface.
                                        Thanks
                                        • quarky42undefined
                                          quarky42
                                          At the risk of asking a dumb question, What is the minimum Duet 2 Maestro firmware I should be running before installing the Duet Web Control 2.0.0-RC6 firmware? (I think I'm on RC5 of the Web Control, but I am not in front my printer right now. I suspect that my Duet 2 Maestro firmware is 2.02, but I would verify that before applying any Duet Web Control firmware upgrade.
                                            Phaedrux Moderator @quarky42
                                            @quarky42 2.02 and DWC 2RC6 will be fine together
