Adapting 2 wire PT100 to 4 wire
(Duet 2 Ethernet doesn't have PT100 inputs, you need the PT100 daughter board, which is what version I was asking about)
@bearer
That's it, thank you ! It's exactly what I've been looking for and haven't found. Can you link me to it please.
Keith
@bearer Yep, I have the appropriate daughterboard
It is described in the wiki; but ref picture in post above.
However depending on the version of the PT100 board you may have to remove jumpers, cut bridges or even desolder bridge/0R resistors for it to work as a 4-wire input. (All of that is also described in the Wiki)
@bearer Yep, I'm up to date with the daughterboard, I actually have 3, a pre-production where you cut the track, the first production with the solder bridge jobby and the current version with the jumpers, which I'm using in my latest printer.
What I'd like to see is the page where you found the pic, I never came across that after searching for sever hours across the net. Could you give me the link to the page you got the pic. Thanks
Keith
At the end of the day there is absolutely no difference between a 4 wire and 2 wire sensor itself. The probe is the same. All they do is add the extra wires like in the photo above when they make them. I work in the irrigation industry and we use them for our submersible pumps. Generally we use 3 wire pt100โs which we assemble ourselves. We have pumps that can be over 200m from the controller and 3 wire sensors are accurate enough. We are working on a 5-10 degree temp increase from standard running temp to trip temp (most motors will run at 35 degrees) so we do need some accuracy. All it is doing is measuring the resistance down the pair of legs to help compensate to make the reading more accurate. When you actually look at the lengths of the runs we use for the printers, it is not necessary to run a 4 wire sensor. At the temps we run 0.4 ohms equates to about 1 degree (I think it is slightly bigger as it gets into the negatives) and I donโt think you would even have that much resistance down the cables so it wonโt effect your reading enough to warrant to do it. Plus I have sausage fingers and trying to get the wires into those tiny terminal blocks is hard enough just with 2
Kind Regards,
Sam -
@kayjay said in Adapting 2 wire PT100 to 4 wire:
I copied the hotend picture from Davids blog, and the PT100 picture from the wiki, and placed them next to each other. It is only described with words how to do the wiring in the wiki. Hopefully the collage makes it clearer.
@bearer that's what's odd about the pic with the hot end. If you follow that link I put in the first post it leads to David's blog but that pic isn't there, that's why I wanted the link, so I could see the page it came from. I've searched high and low to find that info, I'm amazed you found it for me, you certainly have my thanks but can you give me the link please, I'd like to get to the bottom of why I can't see it and you can.
@samlogan87 Thanks Sam, I read somewhere on here about the 0.4 ohms equating to 1 degree, I suppose an extra foot of wire needed to reach the controller wouldn't make that much difference as you say. I think I'll forget all about adding the extra wires, I don't have sausage fingers but I have 67 year old eyes that don't work all that well even with my reading glasses on
Keith
@samlogan87 said in Adapting 2 wire PT100 to 4 wire:
It's not just about the length, it also helps reject the electrical noise interference from being run alongside other wires like the heaters and endstops and steppers.
@phaedrux I would be very interested to know how much of an effect it has. We have 3 wire ones running parallel to sometimes 500A continuous loads and we donโt tend to have to many issues with temperature.
Kind Regards,
Sam -
Well going from reports here on the forum switching to 4 wire has helped some people.
I'm not an electrical engineer though. My understanding stops at 2 wires good, 4 wires better.
For what it's worth I run about 2 meters of 4 wire PT100 in a bundle to the hotend along with the heater, BLTouch, 2 fans, and stepper wires, and haven't had any issues.
I combined to two for you to help illustrate the instructions in the wiki.
@bearer Yes, it had just come to me that that was what you had done. So in actual fact, that may not be the solution. It could still be that it is wired the same as a two wire.
Never mind, I'll stick with it as a two wire, if I get discrepancies I'll search out a genuine four wire PT100
Thanks again
Keith
No, that photo is correct.
From the PT100 wiki page: https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
To connect a 4-wire PT100 sensor:
Connect the two wires that go to one end of the PT100 resistance element to pins 1 and 2 (it doesn't normally matter which wire in each pair goes to which terminal)
Connect the two wires that go to the other end of the PT100 resistance element to pins 3 and 4 -
@bearer Do you mind if I add your image to the PT100 wiki?
@Phaedrux I think that would be up to whomever I "stole" the pictures from (David/Wiki) to help illustrate.
But it that side of things is okay, then as far as I'm concerned use it as you see fit.
@phaedrux It may not be an accurate image, unless David can confirm that is how he connected his conjured 2/4 wire PT100.
It may well be correct but without confirmation it may lead someone up the wrong path so to speak.
Keith
Keith
Yes the image is accurate.
@phaedrux Is there actually a PT100 wiki or is it just part of another, bigger wiki. Just looked for it and can't see it. If there is one can you give me the link please?
Thanks very much
Keith
