    How to pause a program/macro?
    976
    • handyandyundefined
      handyandy
      Unfortunately that does not work. It just stops the program but does not allow any user inputs whilst stopped. Press ok and it just continues. ☹
        handyandy
        Apologies - That does work! I was just putting Z and the line end and not Z1
        Thanks alot
        deckingmanundefined 1 Reply Last reply Reply Quote 1
          deckingman @handyandy
          @handyandy said in How to pause a program/macro?:
          Thanks alot
          Oh brilliant! Hoped it would work but it's not something I have personal experience of using. Is that using the jog buttons? If so, what resolution does it give you for jogging Z?
          Edit - or does it just allow you to use the "normal" jog buttons that DWC and/or panel due provide?
          • wilrikerundefined
            wilriker @deckingman
            @deckingman said in How to pause a program/macro?:
            It will give you separate jog buttons included in the dialog that share the resolution of the normal ones. Only thing is that you cannot change the values in the dialog so the resolution must be set beforehand.
            EDIT: Just run
            M291 S3 Z1 R"Jog Buttons" P"Give me jog buttons!"
            and you'll see. It won't bite. 😉
            EDIT2: If necessary you can even get jog buttons for as many axes as you like. Just add the appropriate axis names to the command (each followed by the number 1).
            Manuel
            My Tool Collection
              deckingman @wilriker
              @wilriker For info, I do use M291 a lot - just never used the jog buttons before. I would have tried it but for reasons other than fear of being bitten, I am unable to do so right now☺
              Edit..........but thanks for confirming that the resolution of the jog buttons is inherited from DWC.
              • GaryKundefined
                GaryK
                Hi!
                This is really a nice thing with the query pops. What I unfortunately find very bad about the jog buttons is the division 0.05 >0.5,... better would be 0.01>0.10,..,
                On my PanelDue 7i completely different values are displayed 0.02>0.2,... The buttons don't work.
                Firmware 1.22.1(28b1).
                In the browser the buttons work as they should.
                What is the reason for this?
                Is there also a possibility to say in the dialogs go to line,... I have a huge collection of macros, but I only checked a few.
                Sorry about my bad English!
                • wilrikerundefined
                  wilriker @GaryK
                  @garyk said in How to pause a program/macro?:
                  As I mentioned above you can configure the values of the jog buttons. Though not inside the dialog. Just go to the normal jog buttons on the Machine Control tab and right-click them. This will open a dialog to enter a new value for this button (and its corresponding +/- button). The buttons in the M291 dialog share the same values.
                  If you are happy with the values you have to save them via Settings -> Apply Settings or they will be lost upon reload of DWC.
                  As to your PanelDue question I am out of that because I don't have a PanelDue.
                  Manuel
                  My Tool Collection
                  • GaryKundefined
                    GaryK
                    Thanks for the info! I didn't know this feature yet. Maybe there is a manual for the Panel Due. I must say that I own my board only since last week and I am enthusiastic about it.
                    I just tested something and changed the jog buttons in the browser.
                    On the panel only the values of X and Y are taken over. At Z are the 0.5,... steps still available. In the Jog menu under the tab "movement", the buttons work however as already mentioned with Z 0.05 although 0.01 was set.
                    Seems to be a bug?
                    The bug is known see also:
                    https://forum.duet3d.com/topic/9480/paneldue-request-m291-x-y-jogmenue-like-in-webinterface
                    Sry!
                      I've found that if you start a macro on the DWC, the jog buttons that show up on the panel due will not work. However, if you start the macro on the PanelDue, they will. Also, it doesn't seem like the PanelDue movement increments are obtained from the DWC. If I start the macro from the DWC, the job buttons will take their resolution from the DWC settings, but the Panel due will still be 0.2, 2, etc.
                      • wilrikerundefined
                        wilriker @Phaedrux
                        @phaedrux said in How to pause a program/macro?:
                        That sounds like a bug.
                        But that sounds normal/expected since DWC and PanelDue are completely separate communication channels to the Duet. I think they don't even know about each other's existence.
                        Manuel
                        My Tool Collection
