    Extruder's stepper - 1.8deg or 0.9deg?
    4.2k
      I'd probably use the 0.9 with x16 microsteps to start. That would get you in the 800 steps per mm range with the 3:1 gearing of the extruder.
      • zaptaundefined
        zapta
        @Phaedrux, the 0.9 degrees extruder motor https://www.amazon.com/gp/product/B00W98OYE4 is installs and working great. Thanks.
        I may also try this smaller version https://www.omc-stepperonline.com/nema-17-bipolar-09deg-11ncm-156ozin-12a-36v-42x42x21mm-4-wires-17hm08-1204s.html . Any downside to the smaller one? I don't expect to print faster than 100-150mm/s on X/Y and 50-75mm/s retraction works fine for me.
          Phaedrux Moderator @zapta
          @zapta pancake steppers are pretty popular with geared extruders because the hearing makes up for the loss of torque. It should work fine.
          zaptaundefined 2 Replies Last reply Reply Quote 0
          • zaptaundefined
            zapta @Phaedrux
            Thanks @phaedrux. I will give it a try.
            • fcwiltundefined
              fcwilt
              You also might like to check out the Zesty Nimble family. It combines the best of direct drive and Bowden "drive" with few of the shortcomings.
              It's a geared unit and my steps/mm setting is 2700. For me a retraction setting of 1mm at 30mm/sec works well.
              I recently equipped both of my printers with them. I'm as happy as clam at high tide with the results.
              • zaptaundefined
                zapta @fcwilt
                @fcwilt, I recently saw a video about it, IIRC it was a MRRF interview. Very interesting. I cam currently stabilizing a new CoreXy printer but once it will settle down Zesty will definitely be on the short list.
                My Bowden is 60cm long so I presume I need the Nimble 75cm cable, and will also need some loose ID PTFE tube for the filament feed.
                How is it attached to the X carriage? Some holding screws or just being attached to the top of the hotend (e.g. V6)?
                • Vetiundefined
                  Veti
                  @zapta said in Extruder's stepper - 1.8deg or 0.9deg?:
                  they are making all adapter available on thingiverse.
                  https://www.thingiverse.com/ZestyTech/collections/adaptors-for-the-nimble
                  • zaptaundefined
                    zapta @Veti
                    @veti, that's very useful, thanks. I do see mounting screws which is good. It's interesting that the use the sidewinder for the HEVO. I would think everything going up and tied together (extruder cable, electric wires and filament PTFE tube).
                    • fcwiltundefined
                      fcwilt @zapta
                      I recently fitted a Nimble feeding a E3D V6 to my FT-5. I designed and printed the mount.
                      I used a vertical Nimble and used the drive cable as a support for the wires going to the hotend.
                      I did not use any sort of tubing as a filament guide, I just feed directly off the spool. A tube might be a good idea.
                      After I got Nimble up and running I decided the mount would be a good place to add a pair of fans for part cooling.
                      As I type I am printing the parts involved in that.
                      Attached is a picture of the experiment to see how a part cooling fan would work before I undertook modifying the mount to accept the fans.
                      • Vetiundefined
                        Veti
                        @fcwilt said in Extruder's stepper - 1.8deg or 0.9deg?:
                        in toms mrrf video they said they will design an adapter for every printer. you just have to contact them.
                        Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @Veti
                          @veti They even have an adapter for a Titan Aero! ROFL!
                          • fcwiltundefined
                            fcwilt @Veti
                            @veti said in Extruder's stepper - 1.8deg or 0.9deg?:
                            I do remember hearing that.
                            I'm fine with designing my own parts.
                            Adding the fans led to some conflicts with existing original parts of the printer. I had to work out a fix for those issues which led to designing other parts.
                            Great fun when it all comes together.
                            • zaptaundefined
                              zapta @fcwilt
                              What kind of a stepper do you use for the nimble? With the 30:1 gear ration I presume that a small pancake 1.8deg stepper is more than enough.
                              • fcwiltundefined
                                fcwilt @zapta
                                I would imagine. I just used what I had on hand - nothing special - a typical 1.8 stepper.
                                • zaptaundefined
                                  zapta @Phaedrux
                                  I tried installing a half length 0.9deg stepper but the one I got didn't have a flat side on the shaft, shaft was barely long enough and the depth of the 4 mounting screw was not as deep as a standard stepper. Will get to it another time. It looks nicer though on my printer than the full size stepper.
                                  https://www.amazon.com/gp/product/B00W96BBF6
                                  • gtj0undefined
                                    gtj0
                                    +1 for the Nimble. Been using it for a while now and it's working great...
                                    It's a little hard to see but that's because it's so small. It tucks right between my hotend and part cooling ducts,
