    Extruder's stepper - 1.8deg or 0.9deg?
    4.2k
      Phaedrux Moderator @zapta
      @zapta pancake steppers are pretty popular with geared extruders because the hearing makes up for the loss of torque. It should work fine.
      zaptaundefined 2 Replies Last reply Reply Quote 0
      • zaptaundefined
        zapta @Phaedrux
        Thanks @phaedrux. I will give it a try.
        • fcwiltundefined
          fcwilt
          You also might like to check out the Zesty Nimble family. It combines the best of direct drive and Bowden "drive" with few of the shortcomings.
          It's a geared unit and my steps/mm setting is 2700. For me a retraction setting of 1mm at 30mm/sec works well.
          I recently equipped both of my printers with them. I'm as happy as clam at high tide with the results.
          • zaptaundefined
            zapta @fcwilt
            @fcwilt, I recently saw a video about it, IIRC it was a MRRF interview. Very interesting. I cam currently stabilizing a new CoreXy printer but once it will settle down Zesty will definitely be on the short list.
            My Bowden is 60cm long so I presume I need the Nimble 75cm cable, and will also need some loose ID PTFE tube for the filament feed.
            How is it attached to the X carriage? Some holding screws or just being attached to the top of the hotend (e.g. V6)?
            • Vetiundefined
              Veti
              @zapta said in Extruder's stepper - 1.8deg or 0.9deg?:
              they are making all adapter available on thingiverse.
              https://www.thingiverse.com/ZestyTech/collections/adaptors-for-the-nimble
              • zaptaundefined
                zapta @Veti
                @veti, that's very useful, thanks. I do see mounting screws which is good. It's interesting that the use the sidewinder for the HEVO. I would think everything going up and tied together (extruder cable, electric wires and filament PTFE tube).
                • fcwiltundefined
                  fcwilt @zapta
                  I recently fitted a Nimble feeding a E3D V6 to my FT-5. I designed and printed the mount.
                  I used a vertical Nimble and used the drive cable as a support for the wires going to the hotend.
                  I did not use any sort of tubing as a filament guide, I just feed directly off the spool. A tube might be a good idea.
                  After I got Nimble up and running I decided the mount would be a good place to add a pair of fans for part cooling.
                  As I type I am printing the parts involved in that.
                  Attached is a picture of the experiment to see how a part cooling fan would work before I undertook modifying the mount to accept the fans.
                  • Vetiundefined
                    Veti
                    @fcwilt said in Extruder's stepper - 1.8deg or 0.9deg?:
                    in toms mrrf video they said they will design an adapter for every printer. you just have to contact them.
                    Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @Veti
                      @veti They even have an adapter for a Titan Aero! ROFL!
                      • fcwiltundefined
                        fcwilt @Veti
                        @veti said in Extruder's stepper - 1.8deg or 0.9deg?:
                        I do remember hearing that.
                        I'm fine with designing my own parts.
                        Adding the fans led to some conflicts with existing original parts of the printer. I had to work out a fix for those issues which led to designing other parts.
                        Great fun when it all comes together.
                        • zaptaundefined
                          zapta @fcwilt
                          What kind of a stepper do you use for the nimble? With the 30:1 gear ration I presume that a small pancake 1.8deg stepper is more than enough.
                          • fcwiltundefined
                            fcwilt @zapta
                            I would imagine. I just used what I had on hand - nothing special - a typical 1.8 stepper.
                            • zaptaundefined
                              zapta @Phaedrux
                              I tried installing a half length 0.9deg stepper but the one I got didn't have a flat side on the shaft, shaft was barely long enough and the depth of the 4 mounting screw was not as deep as a standard stepper. Will get to it another time. It looks nicer though on my printer than the full size stepper.
                              https://www.amazon.com/gp/product/B00W96BBF6
                              • gtj0undefined
                                gtj0
                                +1 for the Nimble. Been using it for a while now and it's working great...
                                It's a little hard to see but that's because it's so small. It tucks right between my hotend and part cooling ducts,
