    Ender 3 Pro configuration
    8.2k
    • JamesMundefined
      JamesM
      I guess I can try lowering the current. At some point I'm going to replace the X and Y stepper motors with 0.9 degree ones with more torque now that I'm using a direct drive extruder as well as glass with PEI on the bed.
      • baesjerkerundefined
        baesjerker @dc42
        @dc42 thanks. I will try that.
          baesjerker @Veti
          @veti you are right. I missed the 90% -_- thanks. My motors run extremely hot with what I already have so I will try with 600(x, y, z) and see.
          • NoSkillzEngineerundefined
            NoSkillzEngineer @baesjerker
            @baesjerker
            Haha so the 1000 mA I had set in my config mayyyyyy be toooo much is what you're trying to say 😂
            hmmmmm hahaha
            @jamesm said in Ender 3 Pro configuration:
            I've been using the following currents on my Ender 3 since I put the Duet wifi in it without issue.
            M906 X950.00 Y950.00 Z850.00 E900.00 I30
            I think the motors at their hottest hit mid 40C range so not hot for stepper motors.
            hmmm, I wonder why yours are fine...800 it is for now
              baesjerker
              The Y and Z motors do not get that hot using 700-800, but the X motor gets extremely hot. I can hold my hand on the back of the X motor for 2 seconds or so and then I have to let go. I have checked belts and everything else. 600 Seems to work great. It still gets hot, but not 800 HOT!
              • Vetiundefined
                Veti
                thats strange as the x and y should be the same motors.
                have you measured the resistance of the phase for both x and y motors? could be a production issue.
                baesjerkerundefined 1 Reply Last reply Reply Quote 0
                  baesjerker @Veti
                  @veti I will check on it later today. Do anyone know if I can use the Ender 3 Pro display with the duet?
                  Edit. Nevermind. Found out by searching 12864.
                  • Vetiundefined
                    Veti
                    with the duet maestro yes. you need another cable for the second exp and swap the plastic housing of exp1 and exp2 around. and connect those to the maestro
                    NoSkillzEngineerundefined 1 Reply Last reply Reply Quote 1
                      NoSkillzEngineer @Veti
                      @veti said in Ender 3 Pro configuration:
                      When I was looking to do this, there was very little, if any, documentation on how to do this. It was exceedingly frustrating as I was probably doing it quite early on. I would have like to do this because I gave my maestro away because I just said "f*** this!" and bought a wifi.
                      I have an issue with my printer now, since the SD card got wiped, that is making the nozzle crash into the bed and it is exceedingly frustrating.
                      • Vetiundefined
                        Veti
                        first check that your probe/endstop triggers using
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
                        then see
                        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                          then see
                          I suspect it has to do with the calibration of the z probe because it homes perfectly, the z end stop is at the top for this reason and I use the BLTouch strictly just to mesh the bed.
                          It is when I try to mesh the bed with the DWC that it just drives right into the bed, it did the first time, now I know it will happen as I tell it to stop 50 or 25 mm away from the bed, wait there for a couple moments, then go to the bed mesh. I am going to recalibrate the z probe after I watch this OpenAI live symposium:)
                            baesjerker
                            Hi guys. Back again with some more issues.
                            On the stock Ender 3 Pro board I never encountered stringing. Not once.
                            Now I have extreme stringing issues and blobs all over the place.
                            What I have done so far:
                            1. Calibrated extrusion.
                            2. Tried different extrusion distances.
                            3. Tried different print speeds.
                            4. Motor mA from 500- 900.
                            5. Changed nozzle. (Not clogged)
                            6. Changed tubing. No difference capricorn/stock.
                            7. Changed couplings.
                            8. Tried temps from 190-220.
                            9. Used 4 different PLA filaments from 3 different makers. Green, red, black and white.
                            10. More/less tension on x and y belt.
                            Edit: My wild guess is that this is something slicer related.
                            Edit 2: Cura = Extreme blobs and medium stringing. Slic3er = No blobs, but extreme stringing.
                              We'd need to see your config.g and your slicer profile to get an idea of what to change.
                              Try this cura profile. https://www.dropbox.com/s/2nk6szy3ag97lsj/Ender3Profile.curaprofile?dl=0
                                baesjerker
                                Hi. Thanks. My setup is based on the settings @PaulHew posted earlier. I have only changed motor mA, z height and the heaters resistance.
                                M305 P1 T100000 B4138 R4700
                                I will post my Cura profile first thing in the morning.
                                I will try that profile.
                                  baesjerker
                                  @veti with my “cheap” multimeter the two motors match up. They’re roughly the same.
                                    baesjerker
                                    @Phaedrux Which Cura version do the profile come from? I get a "Sucsessfully imported Cura profile" but it doesn't appaer in my profile list. I am trying to upload my Cura profile, but I only got iCloud.
                                    Edit: Didn't know version 4 was out. Updated to 4 and I was able to import the profile. Test printing now.
                                      baesjerker
                                      https://drive.google.com/open?id=1Y_DvW1XYmBW7zMpCKuLv6_RJBqDAOi8L Here is my last profile.
                                        In my experience of printing PLA, blobs are caused by insufficient retraction distance, and stringing is caused by extrusion temperature being too high or retraction being too slow.
                                        Why did you choose those thermistor parameters?
                                        baesjerkerundefined 1 Reply Last reply Reply Quote 1
                                          baesjerker @dc42
                                          @dc42 I found a video on YouTube. He used those settings. When I tried resistance settings @PaulHew uses, the hot end and bed didn’t get hot enough. What do you think would be best to use here?
                                            dc42 administrators @baesjerker
                                            @baesjerker said in Ender 3 Pro configuration:
                                            Have you tried this: M305 P1 T100000 B4148 C2.117e-7
