    2.03RC2 leveling issue
    1.7k
    • Cavemanundefined
      Caveman
      Since I installed 2.03RC builds I have an issue with leveling. My bed is with first level above 0, second level below 0 it makes it really hard to lay down a good first layer.
      See:
      https://github.com/dc42/RepRapFirmware/issues/285
      Installed 2.02 and leveling works flawlessly.
      TheMrCaveman created this issue in dc42/RepRapFirmware
      closed 2.03RC2 bed level issue!!! #285
        Can you provide some more information?
        What kind if probe?
        Can you post your config and homing files?
          There has been no intentional change to the way bed compensation is handled in 2.03RC2 compared to 2.02. Please make sure you can reproduce this, i.e. that it always happens using 2.03RC2, and never happens using 2.02.
          If you are able to reproduce this then I need a lot more information, in particular your config.g and homing files.
          • boldnutsundefined
            boldnuts
            I am using 2.03RC2 on both my Delta and P3Steel and I don't see this issue, best to check your machine over carefully.
            • Cavemanundefined
              Caveman
              Checked twice today, switched from 2.02 to 2.03 and isse stays the same.
              I use my original probe @ the moment.
              See attachement for config and home files.
              https://drive.google.com/open?id=1MoBhVsmPUkoPWcCYIs23YyBy48CSpjiV
                Thanks for those files.
                What is the exact sequence you are going through that causes this issue? Is it auto calibration that causes the height shift, or G29 mesh bed probing, or both?
                • PaulHewundefined
                  PaulHew
                  I must admit I am having levelling issues also.
                  Cartesian Printer. BL Touch v2, glass bed, locked bed nuts.
                  I knew something was not right so I dropped the Z axis to 0 using paneldue and could get a number of sheets of paper between the nozzle and the bed.
                  Went throught this procedure again. https://forum.duet3d.com/topic/10017/bl-touch-issues where I thought I had nailed the process.
                  Changed the G31 P500 X-48 Y-10 Z1.28 to my new value, rebooted.
                  Ran mesh level, waited for it to finish, piece of paper under the nozzle, Z axis to 0 and still a large gap.
                  Re did it all again and it was still off.
                  And again and it worked, maybe a little close but at least the filament is sticking!
                  Was going to write a post whether it is possible to keep the BL touch as my Z but using manual bed levelling instead.
                  • Cavemanundefined
                    Caveman
                    first bed level, home, then mesh level
                    this works ok on 2.02 but not on 2.03
                    mesh level is when this problem occurs
                      dc42 administrators @Caveman
                      @caveman said in 2.03RC2 leveling issue:
                      Your machine is a delta. When you say "first bed level", do you mean autocalibrate?
                        @Caveman, I have tried to reproduce this issue, but failed. I have done multiple G29 bed probes, with or without homing between then, with or without a deliberate height error in the M665 command. The height map comes out the same every time I probe, apart from an offset equal to any deliberate height error I set.
                          dc42 administrators @PaulHew
                          @paulhew said in 2.03RC2 leveling issue:
                          Is this behaviour consistent when you use 2.03RC2, and absent when you revert to 2.02?
                          PaulHewundefined 1 Reply Last reply Reply Quote 0
                          • PaulHewundefined
                            PaulHew @dc42
                            @dc42 You asked me to use 2.03 RC1last week because of another problem.
                            It has happened again, I put my borosilicate glass back on, piece of paper, jog Z to lightly grip paper, reset Z, test probing to configure G31. etc, reboot.
                            Home all, move to centre, piece of paper, jog to Z0 and there is a gap again. Grrr!!
                            Did not run mesh bed levelling.
                            Does not seem to take on 1st second or 3rd tries.
                            Rebooted everything and started afresh.
                              deckingman @PaulHew
                              @paulhew Are you using config.override.g by any chance? It sounds to me a bit like you have a G31 or something in there that is overriding what is in config.g.
                              • PaulHewundefined
                                PaulHew @deckingman
                                @deckingman said in 2.03RC2 leveling issue:
                                I have checked that file multiple times. I also just realised I am running RC1.
                                This is contents of my config.overide.g
                                ; Heater model parameters
                                M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                                M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                Also it is not just once or twice I have had this problem, but I perfected my routine when I had the problem a few weeks ago.
                                The amount of post its with 10 sets of probe numbers is unreal!!!
                                  deckingman @PaulHew
                                  @paulhew Ahh, OK - there is nothing sinister in your config-override that might cause the issue. I suspect it must be something to do with levelliing or mesh compensation in that case, but I don't use either so can't advise. I just happened across this thread and had an idea but it isn't that.
                                  • PaulHewundefined
                                    PaulHew
                                    Not a problem, anything to get to the bottom of this issue will be good!
                                    Tempted to scrap the BL Touch and go back to Manual Mesh Bed Levelling!
                                    • Vetiundefined
                                      Veti
                                      have a look at a Film Pressure Probe. they can be bought for 2 euros.
                                      • PaulHewundefined
                                        PaulHew @Veti
                                        @veti Thats what the Two Trees Saphire uses, I think. DPT did a review and I quite like it, the printer that is. (Your not the guy behind DPT are you?)
                                        Overnight I was thinking about my issue, I am pretty sure it is not the Bed Levelling routine, as I have not even got to that stage.
                                        It is something in the initial setup when setting up the probe height.
                                        Piece of paper etc etc, set height in the G31 command, reboot and drop nozzle to bed with paper under and at Z0 it was 0.2 - 0.3 higher. I had to disable axis limits to get it to go down.
                                        Eventually it goes to where it should be after a couple of tries.
                                        I do not know everything, but from your and others help I have this routine down to an art and have questioned myself if I had done it right many a time.
                                        Maybe it is something to do with the BL Touch.
                                        Tempted to order another BLT and see if it is that, but I am off to France on Monday for a week to sort a network out so will prob order another end of week ready for me at the weekend to try again.
                                          @PaulHew, do you home Z using the BLTouch or using an endstop switch?
                                          • PaulHewundefined
                                            PaulHew @dc42
                                            @dc42 Morning David, I use the BL Touch.
