    Fitting a duetwifi into a Wanhao D6
    5.5k
      V2 of what? There is no V2 of the Duet WiFi. If you mean PanelDue, all boards shipped from last week have been V2.
      • curieosundefined
        curieos
        https://duet3d.com/wiki/Duet_WiFi_wiring_diagrams I think they're referring to this page. Just read the text, the V2 prototype boards are white and from the beta. Is your board white or blue?
        She/Her
        I work at a local 3D printing shop.
        Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
        • Corexyundefined
          Corexy
          I'll be doing the same with a Zortrax M200, which is what Wanhao D6 is a crude copy of.
          Wanhao is absolute rubbish, and they are shameless thieves of other companies designs.
          What's this with the new version of the Paneldue??
          I'm wondering if i bought the old version just recently….
          • gzcwnkundefined
            gzcwnk
            Dunno about crude copy, the chassis itself is very well made and finished. Bearing in mind its 1/3rd the price of the M200 so as for absolute rubbish, sorry I do not agree, when it prints it prints very well, and many other ppl are getting great results for 1/3rd the price. I just seem to have been unlucky and have an fault that is hard to trace. Wanhao's support is however yes rubbish. I'll accept that no issues.
            • Corexyundefined
              Corexy
              @gzcwnk:
              Certainly didn't mean to sound confrontational, but I am the unfortunate owner of a D5S.
              When it immediately and continuously broke down and I investigated the wiring in particular, I found "burn your house down" atrocities that defied belief.
              BUT…as a donor chassis for a DuetWiFi conversion, yes 1/3 the price is a good thing for sure.
              I just really don't like their history of stealing other companies designs, and their crappy execution despite the price.
              • gzcwnkundefined
                gzcwnk
                Do I need to buy a microSD card? the docs sort of hint I do? if so how big? and if so does the speed of it matter?
                  A micro SD card is included with each Duet WiFi.
                  • gzcwnkundefined
                    gzcwnk
                    So my wanhao D6's motherbaord finally died, starting to install the duetwifi, lucky I had it here….bummer oh well.
                    • Corexyundefined
                      Corexy
                      @gzcwnk:
                      You won't be sorry.
                      I'm loving my converted Zortrax so far, and I haven't got my simplify3d settings totally tweaked yet.
                      • gzcwnkundefined
                        gzcwnk
                        So some dumb Qs, the Wanhao D6 is a cartesian type printer?
                        • gzcwnkundefined
                          gzcwnk
                          Wiring is mostly done. Pt100 daughter-board not installed so no hotend temp. Bed says 17C which sounds right. limits switches are all NO so Ive set that OK?
                          As,
                          M574 X2 Y2 Z2 S0 ; set endstop configuration D6 normally open - ssj
                          I want to get it moving….but,
                          I need to set X and Y zero and stops as being the front, left hand side point of the bed, cant see how to do that yet.
                          I need to set the bed as 190x190mm from the front lhs point ,
                          I need to set Z as zero as maximum up and travel 170mm down.
                          So,
                          M208 X190 Y190 Z-170 ?
                          or is Z just "170"?
                          • gzcwnkundefined
                            gzcwnk
                            duetWifi networking
                            I want to set a static IP so,
                            ;*** Wifi Networking
                            M552 S1 P192.168.1.127 ; Enable WiFi set static IP.
                            M553 P255.255.255.0 ; set netmask
                            M554 P192.168.1.1 ; set gateway
                            is OK?
                            • gzcwnkundefined
                              gzcwnk
                              if i stuff up networking i have to re-install the sdcard?
                              • gzcwnkundefined
                                gzcwnk
                                hmm OK so all 3 axis all went the wrong way…..bugger...still at least it moved and didnt explode!
                                • gzcwnkundefined
                                  gzcwnk
                                  uh when I move any axis say 10mm th head moves in three dimensions????
                                  • gzcwnkundefined
                                    gzcwnk
                                    Uh removed the delta setting?
                                    ; M665 R105.6 L215.0 B85 H240 ; set delta radius, diagonal rod length, printable radius and homed height
                                    So X and Y look OK Z is scaled wrong 100mm moves maybe 10mm but now it wont home?
                                    I get,
                                    G28
                                    Macro file homeall.g not found.
                                    • gzcwnkundefined
                                      gzcwnk
                                      As an aside the wanhao motherboards axis movement seemed "rough" this movement just seems like silk….or maybe its just my imagination...lol
                                      • gzcwnkundefined
                                        gzcwnk
                                        config file so far,
                                        ; Configuration file for Mini Kossel kit from Think3DPrint3D for testing Duet WiFi
                                        ; Communication and general
                                        M111 S0 ; Debug off
                                        M550 D6 ; Machine name and Netbios name (can be anything you like)
                                        M551 Preprap ; Machine password (used for FTP)
                                        ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                                        M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
                                        M552 S1 ; Enable WiFi set static IP.
                                        ; M552 S1 P192.168.1.127 ; Enable WiFi set static IP.
                                        ; M553 P255.255.255.0 ; set netmask
                                        ; M554 P192.168.1.1 ; set gateway
                                        M555 P2 ; Set output to look like Marlin
                                        M575 P1 B57600 S1 ; Comms parameters for PanelDue
                                        G21 ; Work in millimetres
                                        G90 ; Send absolute coordinates…
                                        ; Axis and motor configuration
                                        M569 P0 S0 ; Drive 0 goes forwards
                                        M569 P1 S0 ; Drive 1 goes forwards
                                        M569 P2 S0 ; Drive 2 goes forwards
                                        ; M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
                                        ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
                                        M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                                        M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
                                        M92 X80.4 Y80.4 Z800 ; Set axis steps/mm
                                        M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
                                        M201 X1000 Y1000 Z100 E1000 ; Accelerations (mm/s^2)
                                        M203 X20000 Y20000 Z2000 E3600 ; Maximum speeds (mm/min)
                                        M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
                                        ; M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
                                        ; M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
                                        ; M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
                                        M208 X190 Y190 Z170 ; set bed dimensions ssj
                                        8><-------
                                          Looks like you are making progress, however I suggest you use https://configurator.reprapfirmware.org to generate a new config.g file and homing files.
                                          Static ip does not work yet on the Duet WiFi.
                                          • gzcwnkundefined
                                            gzcwnk
                                            M574 X0 Z0 Y0 S0 ; Define active low and unused microswitches
                                            what does this actually mean in plain english please?
                                            or where can i find this sort of thing?
                                            I have NOpen switches so S0 is right?
                                            does X0 mean its unused so I should have X1? indeed 1 for all of them?
                                            really this stuff doesnt explain anything…..
