    Fitting a duetwifi into a Wanhao D6
    5.5k
    • gzcwnkundefined
      gzcwnk
      So my wanhao D6's motherbaord finally died, starting to install the duetwifi, lucky I had it here….bummer oh well.
      • Corexyundefined
        Corexy
        @gzcwnk:
        You won't be sorry.
        I'm loving my converted Zortrax so far, and I haven't got my simplify3d settings totally tweaked yet.
        • gzcwnkundefined
          gzcwnk
          So some dumb Qs, the Wanhao D6 is a cartesian type printer?
          • gzcwnkundefined
            gzcwnk
            Wiring is mostly done. Pt100 daughter-board not installed so no hotend temp. Bed says 17C which sounds right. limits switches are all NO so Ive set that OK?
            As,
            M574 X2 Y2 Z2 S0 ; set endstop configuration D6 normally open - ssj
            I want to get it moving….but,
            I need to set X and Y zero and stops as being the front, left hand side point of the bed, cant see how to do that yet.
            I need to set the bed as 190x190mm from the front lhs point ,
            I need to set Z as zero as maximum up and travel 170mm down.
            So,
            M208 X190 Y190 Z-170 ?
            or is Z just "170"?
            • gzcwnkundefined
              gzcwnk
              duetWifi networking
              I want to set a static IP so,
              ;*** Wifi Networking
              M552 S1 P192.168.1.127 ; Enable WiFi set static IP.
              M553 P255.255.255.0 ; set netmask
              M554 P192.168.1.1 ; set gateway
              is OK?
              • gzcwnkundefined
                gzcwnk
                if i stuff up networking i have to re-install the sdcard?
                • gzcwnkundefined
                  gzcwnk
                  hmm OK so all 3 axis all went the wrong way…..bugger...still at least it moved and didnt explode!
                  • gzcwnkundefined
                    gzcwnk
                    uh when I move any axis say 10mm th head moves in three dimensions????
                    • gzcwnkundefined
                      gzcwnk
                      Uh removed the delta setting?
                      ; M665 R105.6 L215.0 B85 H240 ; set delta radius, diagonal rod length, printable radius and homed height
                      So X and Y look OK Z is scaled wrong 100mm moves maybe 10mm but now it wont home?
                      I get,
                      G28
                      Macro file homeall.g not found.
                      • gzcwnkundefined
                        gzcwnk
                        As an aside the wanhao motherboards axis movement seemed "rough" this movement just seems like silk….or maybe its just my imagination...lol
                        • gzcwnkundefined
                          gzcwnk
                          config file so far,
                          ; Configuration file for Mini Kossel kit from Think3DPrint3D for testing Duet WiFi
                          ; Communication and general
                          M111 S0 ; Debug off
                          M550 D6 ; Machine name and Netbios name (can be anything you like)
                          M551 Preprap ; Machine password (used for FTP)
                          ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                          M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
                          M552 S1 ; Enable WiFi set static IP.
                          ; M552 S1 P192.168.1.127 ; Enable WiFi set static IP.
                          ; M553 P255.255.255.0 ; set netmask
                          ; M554 P192.168.1.1 ; set gateway
                          M555 P2 ; Set output to look like Marlin
                          M575 P1 B57600 S1 ; Comms parameters for PanelDue
                          G21 ; Work in millimetres
                          G90 ; Send absolute coordinates…
                          ; Axis and motor configuration
                          M569 P0 S0 ; Drive 0 goes forwards
                          M569 P1 S0 ; Drive 1 goes forwards
                          M569 P2 S0 ; Drive 2 goes forwards
                          ; M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
                          ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
                          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                          M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
                          M92 X80.4 Y80.4 Z800 ; Set axis steps/mm
                          M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
                          M201 X1000 Y1000 Z100 E1000 ; Accelerations (mm/s^2)
                          M203 X20000 Y20000 Z2000 E3600 ; Maximum speeds (mm/min)
                          M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
                          ; M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
                          ; M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
                          ; M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
                          M208 X190 Y190 Z170 ; set bed dimensions ssj
                          8><-------
                            Looks like you are making progress, however I suggest you use https://configurator.reprapfirmware.org to generate a new config.g file and homing files.
                            Static ip does not work yet on the Duet WiFi.
                            • gzcwnkundefined
                              gzcwnk
                              M574 X0 Z0 Y0 S0 ; Define active low and unused microswitches
                              what does this actually mean in plain english please?
                              or where can i find this sort of thing?
                              I have NOpen switches so S0 is right?
                              does X0 mean its unused so I should have X1? indeed 1 for all of them?
                              really this stuff doesnt explain anything…..
                              • Qdeathstarundefined
                                Qdeathstar
                                http://reprap.org/wiki/G-code#M574:_Set_endstop_configuration
                                I just found this page recently, and everything is spelled out pretty well there 😄
                                Parameters
                                Xnnn Switch type for X axis
                                Ynnn Switch type for Y axis
                                Znnn Switch type for Z axis
                                E Select extruder endstops to define active high or low
                                Snnn Logic level
                                Example
                                M574 X1 Y2 Z0 S1
                                This defines the type of endstop switch or opto sensor that the printer has for each axis: 0 = none, 1 = low end, 2 = high end. The optional S parameter defines whether the endstop input is active high (S1, the default) or low (S0). Intended for use with boards that provide a single endstop input for each axis that may be used for either a high or a low end endstop, such as the Duet. Supported by RepRapFirmware. On delta printers, the XYZ parameters refer to the towers and the endstops should normally all be high end. For the extruders endstops, S0 is for active low and S1 for active high. M574 E S1 select active high (used when endstop is a Z-probe, needed from v.1.14) - for all extruder endstops
                                  T3P3Tony administrators
                                  Have a look at the M574 description:
                                  The S parameters says if the endstop is active low (S0) or high (S1). Active high, normally closed, are safer as most failure modes result in them failing as triggered. Assuming you have active high end stops this example will use S1 but you need to check what you have.
                                  So if you have endstops on X and Y, but a probe not an endstop on Z, and the endstops are triggered at X Min and Y Min then you would use
                                  M574 X1 Y1 Z0 S1
                                  Or if you have endstops on all 3 axis minimum then:
                                  M574 X1 Y1 Z1 S1
                                  If you have endstops at Max instead of Min then:
                                  M574 X2 Y2 Z2 S1
                                  You should also check M208:
                                  http://reprap.org/wiki/G-code#M208:_Set_axis_max_travel
                                  As that is useful for setting what Max (and Min if <0) distances each of the printer axis are.
                                  • gzcwnkundefined
                                    gzcwnk
                                    So I have Xmoving and homing perfectly.
                                    Y moved fine but when I hit home it moves the wrong way, back towards the rear of the printer and not forward.
                                    I cant see how to fix this, so how do I fix this please?
                                    • gzcwnkundefined
                                      gzcwnk
                                      I have set M208,
                                      • gzcwnkundefined
                                        gzcwnk
                                        programming, i knew this would be the hard part ;(
                                        • gzcwnkundefined
                                          gzcwnk
                                          ok so homey.g was 200 when it should have been -200
                                          So Y is now good.
                                          Z moves the right way, (up) but ignores its end stop switch, ho hum, led lights so switch and circuit are ok.
                                          so Y has stopped doing the fast initial movement….weird.....so Y is now broken....odd
                                          • gzcwnkundefined
                                            gzcwnk
                                            Ok so the web config tool's default was a probe and not a switch removed that so Z is done.
